The Original 3/8" Ruffstuff Diff Cover! - Page 4 - JeepForum.com
post #46 of 792 Old 04-08-2011, 03:32 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Thankyou!
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #47 of 792 Old 04-09-2011, 10:16 AM Thread Starter
Dan Fredrickson
Vendor
Time to move out of that pretty powder coated look and step into serious steel!
Dan Fredrickson
post #48 of 792 Old 04-09-2011, 12:51 PM
scarrskey
Any chance you will build a 44A/44HD cover?
scarrskey is offline
post #49 of 792 Old 04-10-2011, 09:08 PM Thread Starter
Dan Fredrickson
Vendor
A good chance when we have the time to work it in..
Dan Fredrickson
post #50 of 792 Old 04-13-2011, 03:43 PM Thread Starter
Dan Fredrickson
Vendor
The D44A axle is in consideration but I am very leery of Aluminum as a axle center casting material. It simply wears away very quickly if used in the rocks...
Dan Fredrickson
post #51 of 792 Old 04-13-2011, 04:03 PM
scarrskey
My plan is to use the MVC truss/skid to reinforce it...........maybe you could make your own version of a truss/skid for it.
From what I have read they are a very capable axle once they are trussed, but aftermarket support is still lacking.
post #52 of 792 Old 04-14-2011, 10:37 AM Thread Starter
Dan Fredrickson
Vendor
Does the truss go under it? The 2 I have looked at were used by medium abuse wheelers and the housing was ablot half worn through from rocks.
Dan Fredrickson
post #53 of 792 Old 04-14-2011, 11:30 AM
scarrskey
Yea the truss does go under it. You can check out the thread below.
http://www.jeepforum.com/forum/f13/m...d-pics-735767/
post #54 of 792 Old 04-15-2011, 01:28 PM Thread Starter
Dan Fredrickson
Vendor
Seems like alot of clearance lost and the cost you are putting into it you could easily swap an 8.8 or non aluminum D44?
Dan Fredrickson
post #55 of 792 Old 04-15-2011, 01:36 PM
scarrskey
On ZJ's that works but the 8.8 is too narrow for WJ's. Some people have run them with 2" spacers on either side. But even then you also run into speedo, abs and ebrake problems. WJ runs its speedo off of the tone rings on the axle rather than the tcase. At that point you would need to modify a 231 tcase to fit in a WJ or splice the wires with front abs/speedo wires the retain the speedo. I wish it was more simple for us.
post #56 of 792 Old 04-16-2011, 04:36 PM Thread Starter
Dan Fredrickson
Vendor
Time to cover it up!
Dan Fredrickson
post #57 of 792 Old 04-20-2011, 06:10 PM Thread Starter
Dan Fredrickson
Vendor
The right way to go, better than bulletproof!
Dan Fredrickson
post #58 of 792 Old 04-22-2011, 11:43 AM Thread Starter
Dan Fredrickson
Vendor
Get with it and protect!
Dan Fredrickson
post #59 of 792 Old 04-23-2011, 10:10 AM
GregB_00XJ
Just installed my front D30 cover yesterday. Looks excellent and I feel a lot safer now with that cover on there!
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #60 of 792 Old 04-23-2011, 03:20 PM Thread Starter
Dan Fredrickson
Vendor
Just think of it as another bumper!
Dan Fredrickson
axle , covers , differential , gears
You may not post new threads
