ONBOARD-AIR.COM: Economy OBA System - JeepForum.com
post #1 of 16 Old 02-03-2012, 02:52 AM Thread Starter
Air Werkz
We just put together a new kit, that is geared towards Jeeps, with an affordable price. We know that space is limited on the Jeeps, so we took the fastest VIAIR compressor (400C) and paired that with the slightly smaller 2 gallon tank. The result is a high performing OBA system that can fill 35" tires and low pressure 37" tires.
This kit comes with just the basics to install an OBA system on your Jeep, which helps keep the cost down. This system uses the same compressor that is used in the Heavy Duty Onboard Air System (10005)!
Save $70 from 10005. It comes with compressor, tank, pressure switch, relay & air relocation kit with air coupler to remote mount anywhere you choose.
We are offering this kit at $299!
CLICK HERE TO CHECK IT OUT
2.54 CFM | 150 PSI
Included Parts:
- (1) 400C Compressor (Patents Pending Intercooler Head)
- (1) 2.0 Gallon VIAIR 150 PSI Air Tank
- (1) Air Source Relocation Kit
- (1) 40-Amp Relay with built-in 110 PSI - 145 PSI Pressure Switch
- (1) Tanks Fitting Kit (Drain, 175 PSI Saftey Valve, Plugs)
- (2) Air Filter Assemblies
- (2) Remote Mount Brackets
- (2) Sets of Remote Mount Fittings
- (2) Sets of Spare Air Filter Elements
- (8) Sets of Nuts, Bolts, Washers and Lock Washers
- (2) Stainless Steel Braided Leader Hoses with Inline Check Valve
- (6) Airline Clips
Specifications:
12-Volt
Permanent Magnetic Motor
Duty Cycle: 33% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 26 Amps
Max. CFM: 2.54
PM Us About Our Monthly Specials
[SIGPIC]https://lh3.googleusercontent.com/-04gWo3CF0mQ/UEf-ZkIh0PI/AAAAAAAAApU/MJeWNgrxWQQ/s500/signature.jpg[/SIGPIC]
Air Werkz is offline
post #2 of 16 Old 02-03-2012, 07:39 PM
David_M
What is considered "low pressure" 37" tires?
Thanks, David M
David_M is offline
post #3 of 16 Old 02-03-2012, 08:39 PM Thread Starter
Air Werkz
It can do 37's if you're filling to about 40 PSI. The duty cycle of the compressor can handle that without problems.
post #4 of 16 Old 02-05-2012, 07:13 AM
mogo116
Will this kit run air tools also if I wanted to mount the tank somewhere under the tub near the frame and the compressor under the hood do I loose some psi because of the distance between the 2?
mogo116 is offline
post #5 of 16 Old 02-05-2012, 12:08 PM Thread Starter
Air Werkz
Yes, this kit will run air tools. You can pull all 5 lugs before the systems starts to refresh up to 150 PSI.
No, you will not lose PSI because of distance. Your pressure switch will still kick on at 110 psi and fill all the way to 150, including the air in the line between the tank and compressor.
post #6 of 16 Old 02-05-2012, 12:22 PM
purplepig
I have a 450 Portable. Can I hook this kit up to it (minus the 400 compressor)?
purplepig is offline
post #7 of 16 Old 02-05-2012, 05:00 PM Thread Starter
Air Werkz
Not sure exactly what your'e asking in particular, I apologize.
A) You can fill the tank with your portable, if you want to have that 2 gallon air storage. In other words, you can hook up your portable as you normally would, but instead of running right to the tire, you can run it through the tank. Then you have a hose from compressor to the tank, then a hose from the tank to your tire. I think this is what you are inquiring about.
B) You could hard mount & hard wire your portable on your Jeep, and then run it into a tank, and essentially transform it into an OBA system.
I hope I answered your question.
Either way can be done, but if you're not needing the compressor from that system, I can just put together some parts for you to create what you are wanting to do.
post #8 of 16 Old 02-05-2012, 05:34 PM
purplepig
That is exactly what I was wanting to know.
I have it hard wired now. That would work.
post #9 of 16 Old 02-05-2012, 06:48 PM Thread Starter
Air Werkz
Option A can be done. In fact, you could use the built-in pressure switch on the 450P-A, so you can minus that part out of the kit also.
I can put together a parts list to make this work for you. Shouldn't take many at all.
PM Sent
post #10 of 16 Old 02-07-2012, 10:44 PM Thread Starter
Air Werkz
Thanks for the orders! You can also upgrade this kit to a 2.5 gallon tank for an extra $5.
post #11 of 16 Old 02-09-2012, 10:50 PM Thread Starter
Air Werkz
For the money, this system is hard to beat! Get the performance of VIAIR 10005 heavy duty system for $299!
post #12 of 16 Old 02-18-2012, 12:07 AM Thread Starter
Air Werkz
Thanks for the orders everyone!
post #13 of 16 Old 03-13-2012, 09:22 PM Thread Starter
Air Werkz
Just wanted to let everyone know, we still offer this kist at $299!
post #14 of 16 Old 03-14-2012, 06:56 AM
SMPress
Has anyone who bought this packlage done a write up on where, and how they installed, and any pictures?
Thanks
Andy
SMPress is offline
post #15 of 16 Old 03-14-2012, 09:27 AM
mogo116
I will shortly I been buggin these guys for weeks through Pm's haha I'm gonna be ordering a kit tomm I think when I get it I'll try a write up
mogo116 is offline
ONBOARD-AIR.COM: Wurton LED Lighting Air Werkz Vendor Display 1 02-16-2012 09:13 AM
Onboard-air.com: Prothane Products Air Werkz Vendor Display 2 01-30-2012 03:38 PM
New Vendor (Onboard-Air.com) Air Werkz Vendor Display 23 12-23-2011 11:38 PM
You may not post new threads
