Onboard-air.com: Economy 450C OBA System - JeepForum.com
post #1 of 2 Old 02-23-2012, 11:57 PM Thread Starter
Air Werkz
Since our 400C economy kit, we decided to put together a 100% duty cycle system using the VIAIR 450C. For the guys running 37" or larger tires, we paired the VIAIR 450C compressor (100% duty) with the slightly smaller 2 gallon tank. The result is a high performing OBA system that can fill 37" or larger tires.
This kit comes with just the basics to install an OBA system on your Jeep, which helps keep the cost down. This system uses the same compressor that is used in the Constant Duty Onboard Air System (10007)!
Save $70 from 10007. It comes with compressor, tank, pressure switch, relay & air relocation kit with air coupler to remote mount anywhere you choose.
We are offering this kit at $329!
CLICK HERE TO CHECK IT OUT
1.66 CFM | 150 PSI | 100% Duty
Included Parts:
- (1) 450C Compressor (Patents Pending Intercooler Head)
- (1) 2.0 Gallon VIAIR 150 PSI Air Tank
- (1) Air Source Relocation Kit
- (1) 40-Amp Relay with built-in 110 PSI - 145 PSI Pressure Switch
- (1) Tanks Fitting Kit (Drain, 175 PSI Saftey Valve, Plugs)
- (2) Air Filter Assemblies
- (2) Remote Mount Brackets
- (2) Sets of Remote Mount Fittings
- (2) Sets of Spare Air Filter Elements
- (8) Sets of Nuts, Bolts, Washers and Lock Washers
- (2) Stainless Steel Braided Leader Hoses with Inline Check Valve
- (6) Airline Clips
Specifications:
12-Volt
Permanent Magnetic Motor
Duty Cycle: 100% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 19 Amps
Max. CFM: 1.66
PM Us About Our Monthly Specials
[SIGPIC]https://lh3.googleusercontent.com/-04gWo3CF0mQ/UEf-ZkIh0PI/AAAAAAAAApU/MJeWNgrxWQQ/s500/signature.jpg[/SIGPIC]
Air Werkz is offline
post #2 of 2 Old 02-27-2012, 07:50 AM Thread Starter
Air Werkz
Can't beat this pricing for a 100% duty OBA system. Just wire it in & grab your fill hose, and you're all set!
ONBOARD-AIR.COM: Economy OBA System Air Werkz Vendor Display 15 03-14-2012 06:34 PM
Onboard-air.com: UTV Rhino OBA System Air Werkz Vendor Display 0 02-20-2012 10:13 PM
New Vendor (Onboard-Air.com) Air Werkz Vendor Display 23 12-23-2011 10:38 PM
You may not post new threads
