-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Offset Tie Rod Kit From RuffStuff! (http://www.jeepforum.com/forum/f43/offset-tie-rod-kit-ruffstuff-1539130/)
Dan Fredrickson 06-20-2013 03:40 PM
This is a very nice kit that takes the diameter of a larger Tie Rod and the size of an aftermarket Differential Cover into account.
This kit provides 2 offset GM 1 ton TRE's (1LH & 1 RH), the jam nuts, Hex Head weld bungs, and 54" of 1 1/2" X .25" wall Dom tube.
You may have to ream your knuckle's taper (depending on which knuckle you use) to accept the GM 1 ton TRE but the end result is more than worth the effort!
These have become the mandatory choice for the Jeep JK model as the only ones in the 1 ton size that will work with the factory knuckles.
http://www.ruffstuffspecialties.com/...0tie%20rod.jpg
Offset Tie Rod Kit - RuffStuff Specialties
Dan Fredrickson 06-21-2013 10:42 PM
These are one of our biggest sellers among Jeep Guys!
Dan Fredrickson 06-22-2013 11:32 AM
The JK guys are loving this so far!
Dan Fredrickson 06-25-2013 04:27 PM
These will get you the clearance you need!
Dan Fredrickson 07-01-2013 10:48 AM
Already Monday? This weekend went by quick!
Dan Fredrickson 07-10-2013 12:00 PM
Becoming a bigger hit every day!
Dan Fredrickson 07-18-2013 11:46 AM
A big deal for the wrangler guys!
Dan Fredrickson 07-25-2013 08:04 AM
Thanks for the orders!
Dan Fredrickson 12-03-2013 04:25 PM
Finally, the Offset TRE's are in stock again! We only have a few hundred so get'em while they last!
Dan Fredrickson 12-04-2013 03:08 PM
1st Day back in stock and 11 sets out!
Dan Fredrickson 12-06-2013 10:42 AM
Keep'em coming!
Dan Fredrickson 12-10-2013 10:13 PM
These are one of our most in demand products, thanks for making it so!
Dan Fredrickson 12-15-2013 06:00 PM
The right way to get that clearance you need!
Dan Fredrickson 01-05-2014 11:29 PM
Time to get it right! The Offset is just what the doctor ordered ;)
Dan Fredrickson 01-08-2014 08:22 PM
Thanks for ordering so many of these... :)
The time now is 07:35 AM.
