Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 01-14-2011, 11:53 AM   #31
LuckRider
LuckRider's Avatar
That is my understanding 2. There should actually be enough to do about 3 coats since you are supposed to do thin coats to prevent bubbling.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Unread 01-14-2011, 01:16 PM   #32
huntmaster86
liner
has anyone coated the inside of their tub? i wanna get mine done early this spring but not sure which product to use. something with grip and strong. Thx
huntmaster86 is offline   Reply With Quote
Unread 01-14-2011, 09:50 PM   #33
grundy1340
Picked up some chassis saver today at Arnie's auto body supply in Joliet Il. Spraying on Sunday
grundy1340 is offline   Reply With Quote
Unread 01-18-2011, 01:51 PM   #34
magnetman
Caveman Chemist
JeepForum 2012 Vendor Giveaway Participate
2011 JK Wrangler
Chassis Saver offers no grip. Need a bedliner.
Check out Monstaliner
www.monstaliner.com
and our vendor thread
http://www.jeepforum.com/forum/f43/i...d-liner-875162
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Visit our website: www.monstaliner.com
Read Full Promo Details Here
Connect with us on: Facebook
Watch How To Videos: Magnet Paints on YouTube
Join The MONSTAS Social Group on JeepForum.com
#1 Vendor Thread @ JeepForum.com
MONSTAterms Directory
magnetman is offline   Reply With Quote
Unread 01-18-2011, 03:23 PM   #35
LuckRider
LuckRider's Avatar
You won't be disappointing with the Monstaliner. I don't think there is a single customer that I have seen complain. The only bad thing I have seen was a couple of user error chips (like mine because it wasn't fully cured), and MagnetMan took care of them.
Support Our Troops!
Unread 01-22-2011, 02:05 PM   #36
parrotparty
How much coverage could I get with one quart of chassis saver? Does it have to be rolled on or sprayed?
Im sure its been covered but I'm just curious
[QUOTE=243;11273979] ....I don't know that my way is the right way, it is just the way I did it.[/QUOTE]
[QUOTE=freedommachine;12840223]If it makes you paranoid and requires forum discussions it belongs on a Jeep.[/QUOTE]
"Well boss, a diesel needs its oil like a sailor needs his rum."- Capt. Ron
parrotparty is offline   Reply With Quote
Unread 01-22-2011, 03:10 PM   #37
magnetman
Caveman Chemist
2011 JK Wrangler
1 quart covers 90 sq ft. So with the recommended 2 coat minimum over rust that would be 45 sq ft. coverage from 1 quart
A typical F150 frame uses 2.5 - 3 quarts to do everything in 2 coats.
I would never roll Chassis Saver, only brush. Rolling forces air into the liquid and it could cure with bubbles.
Spray is no problem just reduce 10 to 15% with our S8 Reducer or xylene/xylol
Unread 01-22-2011, 03:25 PM   #38
Tinga
Don't roll it. Husband tried rolling it and it DID end up having bubbles. Even with a smooth foam roller.
Brush turned out ALOT better.
Girls like STROKIN too!
[COLOR="Magenta"]http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/[/COLOR]
Tinga is offline   Reply With Quote
Unread 01-22-2011, 03:30 PM   #39
magnetman
Caveman Chemist
2011 JK Wrangler
Another reason why that happens is because it can go on too heavy with a roller.
Moisture cure urethanes react with moisture in atmosphere to cure. As that happens, carbon dioxide escapes the film and if
coating is on too heavy and is starting to thicken and set up, the bubbles can't break and get trapped in the cured film.
Brush or spray, thin coats only!
Unread 01-25-2011, 10:29 PM   #40
magnetman
Caveman Chemist
2011 JK Wrangler
Originally Posted by Boodyrider View Post
Ewwww!
Luckrider - I beat you to the underside of the tub!
Bottom of tub took only 1 full quart of Chassis Saver; I sprayed it at about 60 degrees, reduced with about 10% S8 reducer. Used a $40 Harbor Freight HVLP gun http://www.harborfreight.com/air-too...gun-66222.html using the included tip at around 45 psi. 2 coats, 1/2 quart each.
Boodyrider,
What ever happened to this jeep project for your dad. Did you ever get the Monstaliner installed?
Where are yoooou?
MM
Unread 01-26-2011, 07:23 PM   #41
magnetman
Caveman Chemist
2011 JK Wrangler
got rust?
Unread 01-26-2011, 08:12 PM   #42
rlfa83
MM,
Im looking to place my order here soon. Couple questions - its about 20 degrees here in Ohio, I can get the garage up to about 45-50, will this be a suitable temp to apply the Chassis Saver?
Also, if I plan to brush on the product, do I need the S8 reducer?
I appricate the info!
rlfa83 is offline   Reply With Quote
Unread 01-26-2011, 09:31 PM   #43
magnetman
Caveman Chemist
2011 JK Wrangler
Originally Posted by rlfa83 View Post
MM,
45-50 is ok and about lowest you want to be. There's no problem using Chassis Saver or Monstaliner at these temps except they will cure slower.
S8 reducer in not needed to brush CS. Only to thin for spray. Sometimes, and especially in cold weather, stored paints will be thicker and harder to
brush so at these times it may help to have some reducer on hand and at any time for cleanup. Store at room temp or slightly above
for 24 hrs bef use to avoid problems.
Xylol/xylene is the only suitable replacement for S8 and avail at Hm Depot or Lowes.
Unread 01-27-2011, 02:27 AM   #44
Boodyrider
Originally Posted by magnetman View Post
Boodyrider,
Where are yoooou?
MM
Monstaliner on the bottom, two coats over two coats silver Chassis Saver.
I brushed and rolled the Monstaliner. Didn't want to try to spray it as cold as my work area was.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Unread 01-27-2011, 02:30 AM   #45
Boodyrider
Or do you mean the black Chassis Saver I sprayed inside the tub as primer for Monsta?? Got too cold to do Monsta, that part's waiting for spring.
