Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 27 - JeepForum.com
post #391 of 414 Old 08-05-2014, 12:51 PM
7xes
Do you think rustoleum hammered would be good as a top coat for cs?
7xes is offline
post #392 of 414 Old 03-06-2015, 12:33 PM
ekim
Originally Posted by magnetman View Post
We begin work this month on a salt removal product to treat surfaces with before painting. Will have photos of what we do with/without treatment. More info to be posted as we move forward. Stay tuned...
Any news on this?
After this winter I have a lot rust rehabilitation to do and I don't want to seal in salts if doing so wound be bad....
ekim is offline
post #393 of 414 Old 03-09-2015, 11:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
We're still working on this.
OMNIMAN or whoever posted yesterday with pics.. where did your post go?
That was some good info.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #394 of 414 Old 03-11-2015, 01:01 PM
ekim
The pics of the shocks coated with woodworking poly and flash rust?
That was me. I can put them back, Since that stuff is so different from the Chassis Saver, I didn't want to cause confusion. When I did the test and posted the results I thought it was basically just a clear version of a similar formula....
ekim is offline
post #395 of 414 Old 03-11-2015, 03:23 PM
ekim
Here's another question related to rust and salts that may still be on the metal.
My understanding is that the silver Chassis Saver is supposed to encapsulate better due the the aluminum flakes in the paint. If the surface is cleaned as much as possible (scrub , power wash, wire brush) does the silver Chassis Saver significantly improve the chances of keeping the rust at bay?
If no moisture or air can get to the salt, won't that stop it from further damage?
ekim is offline
post #396 of 414 Old 04-03-2015, 04:14 PM
ekim
Fiberglass Cloth???
What about using fiberglass cloth with Chassis Saver? For example two coats of CS followed by a couple of coats of CS with glass. This is for an oil pan - that cannot be removed without also removing the engine. The glass is for piece of mind because the rust is pretty bad in the corner and I'm afraid of pinholes or even a coin sized weak area. When I push on the worst spot I can hear a little "crunch".....
Here's the corner where the glass would go:
[EDIT]
It looks like POR15 claims that fiberglass can be used and I've seen at least one person document using it with success. They suggested carefully soaking the glass and then applying it vs trying to wet it out in place. They also gave the impression that the the paint was not that tacky (like a boat epoxy for example). Given that, I wonder if it it's tacky enough to hold up the wet out glass?
If it may not be tacky enough then what are my options for some kind of release agent (that can be scuffed at panted over). For example would wax paper work where I get everything applied in just the smallish area to be re-enforced and then apply wax paper (or other release material) and tape it to hold it in place / prevent sagging.
[/EDIT]
ekim is offline
post #397 of 414 Old 04-04-2015, 11:36 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I'm still thinking about this
Connect with us on:
post #398 of 414 Old 04-04-2015, 12:02 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Fiberglass cloth and Chassis Saver works well for some things but I'm not sure how long it would last for what you describe.
Look here
http://www.aremco.com/high-temp-restoration-products/
[EDIT]
[/EDIT]
Connect with us on:
post #399 of 414 Old 04-04-2015, 12:42 PM
ekim
Thanks!!,
Should I be looking at the epoxies (Aremco-Bond ~400 degrees), or the single stage higher temp stuff (Corr-Paint ~1400 degrees).
I would think for an oil pain 400 degrees should be more than enough.
Is it the oil pan temp that's an issue for CS?
[edit]
I did some more reading. Given my limited knowledge, I would go for the CP2070 Epoxy. Its got a continious duty rating of 300 degrees F and has a higher viscosity(800-1000) than Urethane based version in the 20xxx series(200-500). I suspect this will make it stay on the bottom sides a little better and have more tackiness for the glass.
Sorry to be asking about a product that not yours.... I did already buy some CS and still intend to use it on a frame job - so you're still helping out a customer..
Better yet - can i use the CS with no glass for not to at less stop the progression of rust asap and then figure out what I want to do with fiberglass later? for the areas I want to glass I can just abrade the CS and apply whatever product I end up with. Should that plan work ok?
As far as I know the CS is good for temps up to 400 degrees right?
[/edit]
ekim is offline
post #400 of 414 Old 04-04-2015, 10:20 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If I were you I would call Aremco and tell them what you are doing. Let them recommend a product.
Your main concern is the weak spot you found and I think maybe a metal filled epoxy putty to reinforce that spot would be best.
Epoxy will have far better adhesion than any urethane.
CS is not considered a high heat product for continuous or long term heat exposure. You want to do this right without inventing some technique and hope it stays put.
Connect with us on:
post #401 of 414 Old 04-04-2015, 11:17 PM
ekim
I'll call them first thing Monday. Thanks for helping me out.
ekim is offline
post #402 of 414 Old 09-14-2015, 08:40 PM
Slacksuperstar
Any update on the salt treatment also what promos are you running for cs?
Slacksuperstar is offline
post #403 of 414 Old 09-15-2015, 08:38 AM
bluejunior
bluejunior's Avatar
Magnetman,
How's Chassis Saver hold up to high temps once it's cured? I'm thinking undercoat with it but I'm worried about proximity to exhaust and a warm AW4 tranny.
Lifted, Locked, Stiffened
bluejunior is offline
post #404 of 414 Old 09-16-2015, 09:46 AM
lynskynbnd
1987 YJ Wrangler
Chassis Saver under Monstaliner
Chassis Saver under Monstaliner!
I applied two coats of Chassis Saver over the entire inside and outside of the tub, windshield frame, tail gate, fenders, hood, and doors. I did not coat the underside as it was in excellent condition with the original undercoating. I used gloss black everywhere except the engine compartment which i did in grey.
2 1/2 years later all is holding up well!!
Lots of scuffing!!
and then spraying.
After/Before picture
I need to strip this trailer and Chassis Saver it next!!!
lynskynbnd is offline
post #405 of 414 Old 09-02-2016, 04:54 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2016 Labor Day Weekend Blowout Has Begun!
2 for 1 CHASSIS SAVERô Sale
4 Days Only - Fri 9-02-16 thru Mon 9-05-16
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Effective Today thru Monday 9/05/16 @ Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $39.90) Choose 2 of same color/finish or 2 different
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $111.75) Choose 2 of same color/finish or 2 different
To get the free item, YOU MUST PUT 2 ITEMS INTO YOUR CART FIRST AS IF YOU ARE BUYING BOTH, THEN
APPLY THE COUPON CODE AND WATCH A DISCOUNT APPEAR FOR THE FULL PRICE OF 1 OF THE ITEMS
Standard UPS shipping rates apply - $12.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
Connect with us on:
Frame rust , frame rust paint how , monstaliner , POR 15 , por15 , rust prevention , rust proofing , rust repair
CHASSIS SAVERô 2 for 1 Sale Starts Now! - Insane Cyber Monday Mega Promo magnetman Vendor Display 62 02-09-2012 09:57 AM
Hurricane Irene CHASSIS SAVERô Blowout - 2-for-1 Sale - 4 Days Only! magnetman Vendor Display 0 08-26-2011 07:31 AM
Insane Black Friday Mega Promo - CHASSIS SAVER™ 2 for 1 Sale! magnetman Vendor Display 59 07-30-2011 04:55 PM
You may not post new threads
