Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 25 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-30-2012, 10:20 PM   #361
wheelerbob
wow, no more replys or updates. Im second guessing my choice of frame paint.
There's Nothing on TV!!!!
wheelerbob is offline   Reply With Quote
Unread 04-02-2012, 07:57 AM   #362
magnetman
Caveman Chemist
JeepForum 2012 Vendor Giveaway Participate
2011 JK Wrangler
Still doing research on this. It seems that even sandblasting or 40,000 PSI water pressure won't remove chloride contaminants.
There are chemical treatments that work. This is what we are looking into
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Visit our website: www.monstaliner.com
Read Full Promo Details Here
Connect with us on: Facebook
Watch How To Videos: Magnet Paints on YouTube
Join The MONSTAS Social Group on JeepForum.com
#1 Vendor Thread @ JeepForum.com
MONSTAterms Directory
magnetman is offline   Reply With Quote
Unread 04-14-2012, 08:00 AM   #363
Jeepican
1976 CJ5
Any problem with using acetone on bare metal instead of the mek or xylene?....
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
[URL="http://www.jeepforum.com/forum/f8/slow-76-cj5-rebuild-1118617"][COLOR="blue"]My Build Thread[/COLOR][/URL]
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline   Reply With Quote
Unread 04-14-2012, 08:48 AM   #364
magnetman
Caveman Chemist
2011 JK Wrangler
No problem, acetone works well
Just stay stay away from lacquer thinner with CS
Unread 04-25-2012, 05:34 AM   #365
The_Blacksmith
1993 XJ Cherokee
keep up the good work. I drove my jeep all winter and it dosent look like anything posted. I'm intrested in the salt remove tho, because would be nice to use before i do the next coat of chassis saver, and all the monstaliner.
Salt may be evil but its a hell of alot better than sand and grit.
http://www.jeepforum.com/forum/f11/replacing-floors-xj-pics-1122602/
http://www.jeepforum.com/forum/f11/building-recovery-bumpers-pics-1184330/
The_Blacksmith is offline   Reply With Quote
Unread 04-27-2012, 06:50 PM   #366
2000GrayTJ
Good discussion going on about this, I apologize Magnet for not replying sooner. I read that article in the Chloride (?) Salts and it makes sense to me that if they are bonded to the metal prior to application this could definitely be an issue. However, there are 2 people I know that have used POR-15 on their frames which have been exposed to the EXACT same road salt that mine has and they are not having any issues whatsoever.
I'm not going to mention that again just thought I'd share for a little comparison. At work I do frame-off restorations on mostly Jeeps (I had just started the job when I was doing my frame) and for the most part we get the frames blasted, then coated in a rust neutralizer and/or an epoxy paint/primer. Seems to hold up pretty well and I must say I won't hesitate to use CS again, just not in the same application I don't think.
From what I've observed it is a VERY tough coating and definitely remains flexible. It also seems to work the best (as was mentioned before) when it's able to fully encapsulate what it's covering. That being said, I am going to try it as a primer next and see how it performs when there is NO prior rust on the metal. If I could do it again I would have gotten the frame blasted then coated with 3-5 coats of CS plus topcoat.
What do you recommend I do with the current spots that are bleeding through? My instinct is to sand em down and re-coat the BARE metal and then re-topcoat. I appreciate your effort in explaining everything that's going on
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is online now   Reply With Quote
Unread 04-28-2012, 07:12 AM   #367
RedlegWJ
Another thing I was wondering was heat application affecting the chloride? A lot of the chassis area I plan to coat that is already rusted will see a lot of welding. Think the chloride cooks away to an extent?
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline   Reply With Quote
Unread 04-29-2012, 07:32 PM   #368
Smitty98TJ
2 days ago i did the monstaliner kit and free chassis saver with free shiping deal. Bought an extra quart of chassis saver too. The owner before me lived at the beach, backed his boat in and what not and looks like he never rinsed after, so if there is still some salt from the salt water on there, highly unlikely, what do i do? Or should i say what kind of prep solvent would be best?
http://www.jeepforum.com/forum/f22/1998-tj-sport-build-1097517/
Smitty98TJ is offline   Reply With Quote
Unread 05-01-2012, 08:17 PM   #369
Michigan4x4
I am on the verge of applying CS to a trailer but live in MI. Now I am super hesitant. Read all 20 something pages of this thread. Magnet man responded daily in the beginning.. Now, someone posts photos of rust coming through what seemed to be a well prepped frame and it has been a month with no response. Even though I already have the CS product, I may be looking at something else for frame protection.
Not trying to badmouth anyone or anyone's product, just seems Ironic that the "chloride issue" has been deemed the possible problem and the question has been asked "what to do about it?", yet the solution has not been discussed. I am not selling a rust preventative product so I am not really sure what to do about it. I guess I am just going to wait until Magnet man comes up with a solution.
In the meantime I am going to check out a product called "Fluid Film" for my frame inside and out. May still consider the CS but I really want to know why a product like CS is failing in states that use heavy salt and sodium/calcium chloride. I was under the impression that rust prevention was exactly what CS was meant to do...
Michigan4x4 is offline   Reply With Quote
Unread 05-02-2012, 07:08 AM   #370
RedlegWJ
The way I understood it when reading the article, is that the coating is irrelevent. The chloride makes it rust under everything. Still eagerly waiting on what will help.
Unread 05-02-2012, 07:36 AM   #371
hdrocknroll
I agree with you here.
I was going to use it on my Jeep,and also thought it would be good for the trailer.
Now it seems, it doesn't do what it's supposed to do, and no response.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote
Unread 05-02-2012, 10:21 AM   #372
Michigan4x4
My answer is this... I am going to prep my trailer per CS instructions this summer. Paint with CS (That I already have) At the end of summer I am going to buy a "Fluid Film" Undercoating kit complete with a "wand" with 360 spray tip for the insides of the frame rails. For somewhere around $100.00 I will have a kit capable of doing my trailer for several winter seasons that WILL protect against Road salt, corrosion and Calcium/sodium Chloride. Cheap insurance as far as I am concerned. If I didn't already have 2 quarts of the CS, I would probably use the Fluid Film only. They make some pretty impressive claims on their website. Their product is also tried and tested. Qiuck note, I am in no way associated with Fluid Film or the manufacturer. It was recommended to me by a friend that has used it for years with very good results.
check it out..
Per Their website:
"The advantage of a soft auto undercoating like Fluid Film, over a hard one, is that if a hard coating gets chipped, water gets trapped underneath the hard coating and the metal surface, leading to more of a auto rust problem.
Fluid Film auto undercoat remains active, migrating to inaccessible areas and protecting from moisture and road salts, even calcium chloride. Because it is a soft coating, it is going to have to be redone every year, or twice a year. Applied in fall, it will get you through a full winter season.
FLUID FILM rust proofing penetrates to the base metal, remaining active and migrating to inaccessible areas. Provides long term protection from the corrosive effects of salts, calcium chloride, moisture and fertilizers, resulting in a "no drip" application which will protect vehicle's undercoating from metal deterioration. "
http://www.kellsportproducts.com/autoundercoatfaq.html
Unread 05-05-2012, 10:19 AM   #373
Michigan4x4
Still nothing huh?
Unread 09-19-2012, 03:51 PM   #374
Jeepican
1976 CJ5
Pretty sure this has prob been asked..... but i am going to coat the underside of my tub with CS, topcoat with maybe rustoleum undercoat and use seam sealer on cracks and body work patches. Should i apply CS first then apply seam sealer? Also what about body work that has been done on rocker should i apply some cs before using seam sealer?
-Barney Fife-
