Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 22 - JeepForum.com
post #316 of 414 Old 02-20-2012, 09:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Jeepican View Post
So any plans for a 2 for 1 during Tax season?
I can't do that but once a year on Black Fri or our dealers will get pissed
If you want to spend your tax return faster I can run an exclusive for you only
1 for 2
How about a 4 quart special for the price of a gallon?
$104.75 vs. $150 (4 qt price)
"The IRS Special"
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #317 of 414 Old 02-28-2012, 07:12 AM
Jeepican
1976 CJ5
UCP970 Antique-Satin Black – For factory original restorations on all underbody and engine compartment surfaces. Cures to a silky smooth sheen. Use silver-aluminum as a base coat/primer.
"Use silver-aluminum as a base coat/primer"
Is that necessary for the satin? Or just a suggestion? I would rather not buy two quarts silver/satin ........
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #318 of 414 Old 02-28-2012, 07:45 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Just a suggestion/option because the silver has high loading of aluminum flake it will have some fill properties on pitted rougher surfaces. For the satin to lay out smoothest and brush mark free the surface should be well sealed
2 coats of satin black still looks pretty god when brushed with black faom brushes.
Everyone, please remember no smooth, clean bare metal under Chassis Saver without coarsely abrading the surface first
Connect with us on:
post #319 of 414 Old 02-28-2012, 09:16 AM
Jeepican
1976 CJ5
So after wire wheeling the frame i should scuff w/ 60-80 grit before applying?
-Barney Fife-
Jeepican is offline
post #320 of 414 Old 02-28-2012, 07:09 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
60-80 is still too fine. 40 - 60 is needed if it;s clean smooth metal
What is the wire wheeling removing?
Connect with us on:
post #321 of 414 Old 02-28-2012, 08:36 PM
Jeepican
1976 CJ5
A mixture of rust, factory paint, cheap po paint, oil and sludge........u name it.......
-Barney Fife-
Jeepican is offline
post #322 of 414 Old 02-28-2012, 08:46 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If you degrease and just coarse it all you prob can avoid the wire wheel altogether?
Connect with us on:
post #323 of 414 Old 02-29-2012, 06:28 AM
Jeepican
1976 CJ5
I dont trust the layers of paint..... most of it just flakes off.... the rear end is mostly rust, not a lot of paint left on it. The front avoided rust, i guess because of all the oil leaks
-Barney Fife-
Jeepican is offline
post #324 of 414 Old 03-04-2012, 01:34 PM
Jeepican
1976 CJ5
So after i wire wheel and sand with 40 grit, then apply the cs i should be good to go? I sure dont want to do all this again.
-Barney Fife-
Jeepican is offline
post #325 of 414 Old 03-10-2012, 10:38 AM
jamesdart
i coated some stuff with cs a month or so ago, one coat just to keep the rust under control while i was working, im ready to finish it all up, it sounds like 180-220 scuff on the cs is required to get a good bond for the following coats?
jamesdart is offline
post #326 of 414 Old 03-10-2012, 10:46 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes you want to knock the gloss off it and generate a fine dust. Wipe down with any solvent EXCEPT lacquer thinner and let dry before coating
Connect with us on:
post #327 of 414 Old 03-12-2012, 10:45 PM
tangotag
What causes rust to come through Chassis Saver? Two separate instances are having spotted rust appearing. On my TJ rear crossmember two years old CS application top coated with rust-oleum. The other on a buddys pickup door (I suggested he buy CS after my initial experience) it was CS coated less than 8 months ago with a factory color match topcoat. Here is the strange part, same applications in other areas using the same methods have no rust coming through.
tangotag is offline
post #328 of 414 Old 03-12-2012, 11:48 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry you're having this issue. This happens on occasion with all products like Chassis Saver. It can only be that moisture somehow got through the coating. I tiny pinhole or a high spot where the coating did not fully cover a small sharp point of rust and moisture gets in.
It's the only thing that makes sense as to why it does not happen in other areas.
Is this gloss black? How many coats were used?
Connect with us on:
post #329 of 414 Old 03-13-2012, 12:37 PM
tangotag
Gloss Black was used on the TJ and the Pickup was Satin Black. Each had 2 coats.
I think in the future I am going with the silver for any future applications.
tangotag is offline
post #330 of 414 Old 03-14-2012, 12:28 PM
05WK98TJ
I have a few questions for ya
Would 1 quart of CS be enough to paint 2 layers on the outside of a frame on a TJ?
And would 2 layers be enough to withstand rocks and debris flying up from the tires or would a few coats of rust-o-leum professional enamel be recommended?
Can herculiner be applied over CS after it has cured?
Thanks a bunch
05WK98TJ is offline
Frame rust , frame rust paint how , monstaliner , POR 15 , por15 , rust prevention , rust proofing , rust repair
CHASSIS SAVER™ 2 for 1 Sale Starts Now! - Insane Cyber Monday Mega Promo magnetman Vendor Display 62 02-09-2012 09:57 AM
Hurricane Irene CHASSIS SAVER™ Blowout - 2-for-1 Sale - 4 Days Only! magnetman Vendor Display 0 08-26-2011 07:31 AM
Insane Black Friday Mega Promo - CHASSIS SAVER™ 2 for 1 Sale! magnetman Vendor Display 59 07-30-2011 04:55 PM
You may not post new threads
