Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 20 - JeepForum.com
post #286 of 414 Old 11-27-2011, 11:31 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Place Orders Online @ www.shop.monstaliner.com
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #287 of 414 Old 02-09-2012, 11:02 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's baaaack! Admin has come through in a big way! Thanks Austin!
Connect with us on:
post #288 of 414 Old 02-09-2012, 06:02 PM
Jeepican
1976 CJ5
Coooool..thanks....lot of info on here that was lost!
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #289 of 414 Old 02-09-2012, 06:11 PM
LuckRider
LuckRider's Avatar
Why, How, When did it disappear?
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #290 of 414 Old 02-09-2012, 06:23 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
When I first started this thread it was under my bigshot 2nd vendor account "chassissaver"
Then I did not renew the account after a while so the thread was deleted with the account but.... Admin here is very accommodating and they merged my deleted vendor account with MagnetMan act
Connect with us on:
post #291 of 414 Old 02-09-2012, 06:28 PM
LuckRider
LuckRider's Avatar
Ah. Goccha. I thought it might have had something to do with the old CS account but I wasn't sure.
Support Our Troops!
JFI Member #7:
post #292 of 414 Old 02-09-2012, 06:56 PM
k-bar
Can you roll on CS, or does it have to be sprayed?
k-bar is offline
post #293 of 414 Old 02-09-2012, 07:45 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I would not roll it
Reduce to spray or brush thin coats (with a bit of reducer). Make sure material is stored at room temp and you do not coat cold surfaces in the winter.
Connect with us on:
post #294 of 414 Old 02-09-2012, 08:14 PM
JPetru82
JPetru82's Avatar
waiting for my ML kit in the mail. going to start prep in the mean time. For the CS that comes with it, what do I need to do prep wise for it? are there parts that I shouldn't put CS on for any reason?
JPetru82 is offline
post #295 of 414 Old 02-09-2012, 10:43 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Oh that was a blast
Never use CS on bare smooth metal. It's fine over scuffed auto paint.
Great on tight rust that has been wire brushed to remove loose material.
And most important as we never really learned tonight, store all coatings at room temp, don't paint cold metal and if you have a problem send a PM or come over here or the ML thread to ask questions.
Is there anything out of the ordinary with whatever you are coating?
Connect with us on:
post #296 of 414 Old 02-09-2012, 10:53 PM
JPetru82
JPetru82's Avatar
out of the ordinary? I don't think so. Just wasn't sure about the need for sanding and what not before you put CS on
JPetru82 is offline
post #297 of 414 Old 02-09-2012, 10:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Putting CS in the tub only or where else?
Is there any bare metal?
Connect with us on:
post #298 of 414 Old 02-10-2012, 05:35 AM
inovermyhead2
Just ordered your monstaliner/chassis saver combo promo last night and I have a couple of questions. If I have bare metal sand throughs in my tub, how should those areas be treated? Epoxy primer? Spray can primer? 1 or 2k self etch primer? Also, how long is the window after application of the chassis saver to apply the monstaliner without having to scuff sand the chassis saver and apply directly? BTW, sorry about last night, I think you got a raw deal. I tried to go to bat for you but some people are just ignorant. Joe
inovermyhead2 is offline
post #299 of 414 Old 02-10-2012, 06:54 AM
Jeepican
1976 CJ5
can't you just scuff bare metal really good and apply the CS?
-Barney Fife-
Jeepican is offline
post #300 of 414 Old 02-10-2012, 07:06 AM
JPetru82
JPetru82's Avatar
I'm applying it just to the underside, unless there's extra left over and people think I should apply it else where.
JPetru82 is offline
Frame rust , frame rust paint how , monstaliner , POR 15 , por15 , rust prevention , rust proofing , rust repair
CHASSIS SAVERô 2 for 1 Sale Starts Now! - Insane Cyber Monday Mega Promo magnetman Vendor Display 62 02-09-2012 09:57 AM
Hurricane Irene CHASSIS SAVERô Blowout - 2-for-1 Sale - 4 Days Only! magnetman Vendor Display 0 08-26-2011 07:31 AM
Insane Black Friday Mega Promo - CHASSIS SAVER™ 2 for 1 Sale! magnetman Vendor Display 59 07-30-2011 04:55 PM
You may not post new threads
