Official Chassis Saver Rust Preventive Truck & Auto Underbody Thread - Page 15 - JeepForum.com
post #211 of 412 Old 08-01-2011, 08:39 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Black turns color in direct sun exposure, meaning facing the sun
Underbody does not change that much except in wheel wells where sun gets in
Silver is different because it starts off dull and the aluminum does not change much
If you put 3 thin coats of silver I have seen it stay nice for 7 + years
Biggest mistake people make with CS is putting 1 coat and thinking they are done. Where high peaks of remaining rust and rough areas are too close to the top of the dry film, moisture can get back in and start rusting again so final film thickness is important to make sure surfaces are sealed in well
Originally Posted by Erik T. View Post
No, I meant the Chassis Saver that this thread is about. :P
Sorry to confuse.
You mentioned it starting to gray at some point, so I went with the Silver. But my question is, how long before we'd need to reapply this stuff? Just a general answer, I'm aware that the NE would need it monthly in the winter.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #212 of 412 Old 08-02-2011, 07:21 AM
Erik T.
Erik T.'s Avatar
Ah I got you now, had I know that there was small chance of it turning gray I would have gone with black I think. Oh well, I'll give silver a try.
Thanks for the info!
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #213 of 412 Old 08-02-2011, 07:46 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Silver looks really awesome and it's different
If you want in the well areas where it shows outside you can just spray black over it
Connect with us on:
post #214 of 412 Old 08-02-2011, 08:20 AM
TESmith
Hmmmm sounds like that could be really different
If I was going to do silver CS on the under sides, (I only have a quart) could I put a coat or two of black first and overlay the silver as a top coat (I have a gallon of black cs) or will the quart do me for two or three quarts under neath?
Also as I am doing this from underneath, out of curiosity How is CS with heat, do I need to take extreme care to not get any on my exhaust while I am covering the rest?
And a Final note , Magnetman, do not know if you recall we talked about the Harbor Freight LVLP Gun that only had a 2.0 nozzle......I rolled the dice and got one in and will be trying it with the CS, Yes I will keep you posted Not ready to do it yet but not too far away!
95 YJ, 99 TJ and 86 Comanche
Love them all in their own way!
TESmith is offline
post #215 of 412 Old 08-02-2011, 09:03 AM
55willystruck
So it sounds like this silver CS fills small cracks/voids nicely? I'm wondering if I might be better off ordering this silver do to my buddies M416 tub with as a base. He's thinking he wants to have Maaco shoot a cheap matching paint on it to match his JK color. Would it be good for that? The tub has a lot of weld work done on it now and seeing how good the black CS did over my tub, it nearly wiped them all out entirely and especially with the Monsta over the top. I grafted a Jeep logo to the back of the tub and hard a really hard time with smoothing out the rounded corners I have a few tiny little cracks and I know after working with the black CS it would do great and cover them nicely. Just thinking maybe I should try the silver and see the differences between it and black, then also be easier to coat over with a white paint. I'll probably prime with magnapoxy as well so the paint can stick good but would it be necessary?
Decided I'd wait and put up pics of the two trailers after I get all the stuff back on them-fenders, doors, etc... Will look a little better that way even though I still have a lot of work left to do on them...
Best of Luck,
Mike
55willystruck is offline
post #216 of 412 Old 08-02-2011, 09:38 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You can put the silver over the black and you may only need 1 quart under so it's your choice. You can also break up gallon into some new quart cans from Hm Dep or paint store to save spoiling full gal.
No problem with CS and heat. Won't burn when dry and any on the exhaust will just change over time and constant heat
Remember the 2.0 gun, do let me know how that works.
Connect with us on:
post #217 of 412 Old 08-02-2011, 09:42 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
CS silver fills some but it not thick at all, actually it's thnner than black. It just works different and looks diff over rusty metal than black
Best of Luck,
Mike
Connect with us on:
post #218 of 412 Old 08-03-2011, 05:31 AM
Erik T.
Erik T.'s Avatar
So a quart will only do about one coat on a TJ frame?
And how quickly does the 2nd and 4rd coat need to be applied? Any time frame?
-Erik.
Erik T. is offline
post #219 of 412 Old 08-03-2011, 10:44 AM
2000GrayTJ
Only took me about 3/4 of a quart (maybe just over) sprayed for 2 fairly solid coats of my entire frame (had the body off)
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #220 of 412 Old 08-03-2011, 12:00 PM
Jbecker
Quick question about CS Application temps.
I know there is a minimum application temp, what about a max?
It's been around 95-103 here in the St. Louis area for the past 2 weeks(feels like years), along with very high humidity. I hope to start painting the inside of my tub next weekend with CS as a primer for Monstaliner. Any reason I should wait until it cools down before I apply the CS?
Only place I can paint is outside. Painting in the drive in basement wouldn't go over so well...
Jbecker is offline
post #221 of 412 Old 08-03-2011, 07:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
No you have to get at least 2 coats on that type of frame from 1 quart
Successive coats can be applied in as little as 5 - 6 hrs with a 24 hour max recoat before you need to scuff before next coat
Connect with us on:
post #222 of 412 Old 08-03-2011, 08:03 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
No reason to wait unless you rather sleep or be at the beach
Applying CS in hotter temps will just make to dry faster to recoat. You just don't want to paint HOT surfaces that were sitting in sun. Need to find some shade or work before sun gets too high say past 10-11AM
Connect with us on:
post #223 of 412 Old 08-04-2011, 03:14 PM
55willystruck
Well sad day-I just used up about 1/2 of my last quart of Chassis Saver on the last M416 tub/fenders, etc. In about 5 hours, I'll have no more... This stuff is cool! Has been great for these projects here lately. Kinda sad I'm out now... OH well, means more Magnapoxy then Monsta to go...
Best of Luck,
Mike
post #224 of 412 Old 08-05-2011, 06:50 AM
Jbecker
Thanks.
I knew that you weren't supposed to apply Monstaliner when it was hot and humid since it dries too fast. Looks like the floor of the TJ is getting a couple coats of CS next weekend!
A quart should do the interior of a TJ tub with 2-3 coats right?
Jbecker is offline
post #225 of 412 Old 08-05-2011, 10:34 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks.
Quart covers 90 sq ft so 1-1/2 times around the tub, but maybe 2 full coats as it should be brushed thin
Connect with us on:
Frame rust , frame rust paint how , monstaliner , POR 15 , por15 , rust prevention , rust proofing , rust repair
CHASSIS SAVERô 2 for 1 Sale Starts Now! - Insane Cyber Monday Mega Promo magnetman Vendor Display 62 02-09-2012 09:57 AM
Hurricane Irene CHASSIS SAVERô Blowout - 2-for-1 Sale - 4 Days Only! magnetman Vendor Display 0 08-26-2011 07:31 AM
Insane Black Friday Mega Promo - CHASSIS SAVER™ 2 for 1 Sale! magnetman Vendor Display 59 07-30-2011 04:55 PM
You may not post new threads
