Originally Posted by 95YJIL
Magnetman, have you ever given any thought to creating a product something like this from Eastwood?
Internal Frame Coating w/Spray Nozzle
I am trying to figure out a way to spray the inside of my frame to coat it with CS
Originally Posted by magnetman
I just discussed that Eastwood item with someone last week.
There is a way to do this with Chassis Saver.
The tube and spray tip that comes with that product is commercially available. Need help to find where to buy them. Does Eastwood sell that tube/spray tip alone, not with the internal frame coating?
Originally Posted by Jims-87YJ
Yes Eastwood does sell the nozzles separately for like $7 each. I do not have a part number off hand, but you would have to check if the spray head fits the can?
Glad to see someone is quicker than me. Here is the link.
Aerosol Nozzle w/ 18" Extension Hose
I have heard of people using a toilet brush and extension to paint the inside of their frame.This may be a dumb question, but could you reduce CS enough to spray it out of a pump sprayer?
OK, here's the lowdown on this
Chassis Saver as we know has no problem being sprayed. Add 10 to 15% S8 Reducer or xylol/xylene and you can spray through any gun with compressor.
In the past, we tested putting CS in spray cans. At first, the stuff sprayed ok but if the can is put aside for a few hours the tip fouls and you can't
use the can a second time. Long term stability in the spray cans was also an issue that could be solved with some reformulation of the propellant
used in the can.
There are 2 items available in paint stores to spray CS without a gun and compressor.
1st which many have heard of is called the "Preval Sprayer". It comes with an aerosol propellant can that screws on top of a glass jar. Works well but the glass is bad.
2nd is the "CROWN Spra-Tool". (Spelling is correct) This one we love. An aerosol propellant can that piggybacks on the side of a plastic bottle.
It has a regular spray can nozel on top. You thin down the CS and fill the bottle.
Not sure if that Eastwood extension can replace the spray tip on this unit. The only concern I have with the Eastwood item is that the
end of that hose looks weird and not like a tip to atomize paint correctly. This is just an observation as I have never had one of these in my hand.
Pump sprayer may work. Depends on the tip. You won't get good atomization unless it was designed to spray paint.
I'll be back later today with something else if I can find it.
PS: I'll ship you my toilet brush if you want to try it
