-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   New Viair AUTOMATIC DEPLOYMENT AIR SYSTEMS (ADA) Now @ ROCKRIDGE 4WD W/ BEST PRICE! (http://www.jeepforum.com/forum/f43/new-viair-automatic-deployment-air-systems-ada-now-rockridge-4wd-w-best-price-1422067/)
Rockridge4WD 09-28-2012 02:56 PM
4 Attachment(s)
Attachment 480473
VIAIR Corporation offers the most comprehensive line of air compressors & air accessories for both the on-and off-road markets available anywhere. Their quality engineered compressors and components are also used in the OEM segment, and have become the industry standard for both 12- and 24-volt automotive aftermarket applications worldwide. VIAIR compressors are currently deployed to every corner of the Globe; in the world's harshest environments from arctic climates to the world's most unforgiving deserts in a multitude of applications. VIAIR products are currently used by 12 of the Fortune 500 Companies (Non-Automotive), in market segments ranging from Oil Service to Aerospace, from Agriculture to Healthcare. VIAIR Corporation is recognized by its customers and peers alike as the leading manufacturer of high performance air compressors for mobile pneumatic applications.
"Our goal is to consistently deliver performance, reliability and value to our customers; providing the ultimate Vital Air Source - the heart of any mobile pneumatic system to our valued partners worldwide."
Attachment 480474
VIAIR Corporation is proud to offer our new Automatic Deployment Air (ADA) Systems in vehicle-specific, applications delivering incredible performance in a compact space. VIAIR ADA Systems incorporate a 12-port extruded aluminum air tank to provide a compact air locker and tire inflation station using either a 400C (Heavy Duty) or 450C (Constant Duty) compressor at its core. ADA Systems come complete with a pressure switch, automatic coupler, Digital Tire Inflation Kit, and a wiring harness to make the installation a plug & play process. Vehicle-specific ADAs for 2007-2011 Jeep JKs are equipped with a brake booster mounting bracket.
Using a 33% (Heavy Duty) duty cycle 400C compressor, tire inflation and air locker actuation is made possible in a very compact space. This ADA System comes complete with an onboard pressure switch, automatic coupler and a Digital Tire Inflation Kit. Additionally, a wiring harness is included to make the installation a plug & play process
VIAIR Corporation is proud to offer our new Automatic Deployment Air (ADA) Systems in universal applications delivering incredible performance in a compact space. VIAIR ADA Systems incorporate a 12-port extruded aluminum air tank to provide a compact air locker and tire inflation station using either a 400C (Heavy Duty) or 450C (Constant Duty) compressor at its core. ADA Systems come complete with a pressure switch, automatic coupler, Digital Tire Inflation Kit, and a wiring harness to make the installation a plug & play process. Universal models do not include a brake booster mounting bracket.
Rockridge 4wd knows the importance of having the ability to air down your tires for much improved offroad traction. We do it every time we head out for the trail. We also understand the necessity to quickly and efficiently air back up for a good safe drive home once your off the trail. There are a few different ways to go about an air system. You can simply install an aftermarket compact air compressor with one of our various mounting solutions or some customers chose to make a home brew setup which works great if you are on a budget. Co2 is often used amongst the offroad industry because of the simple fact that they pack a lot of punch when it comes to needing to be able to run air tools or re seat a tire bead on the trail. Co2 typically has a faster fill rate and is more portable(if you have multiple vehicles). Another reason for needing an on board air or Co2 system is for an air actuated differential locker. Whatever your reason if you need guidance on which route might be best for you, simply shoot us an email or give us a call at (509) 588-7800 and we would be glad to share the pro's and con's of both setups.
Rockridge4WD 09-28-2012 05:06 PM
1 Attachment(s)
Attachment 480542
Did we mention that we will meet or beat any other authorized distributors written estimate?!
Let Rockridge 4WD help you get more for your money!
Jeff
sales@rockridge4wd.com
Rockridge4WD 09-29-2012 01:59 PM
Rockridge4WD 10-02-2012 02:52 PM
Now in stock at ROCKRIDGE 4WD! Make air up a breeze when you are done off roading with this set up!
Erin@Rockridge4WD.com
Rockridge4WD 10-26-2012 11:29 AM
2 Attachment(s)
VIAIR UNIVERSAL ADA SYSTEMS 400C
No need for a tank! Just flip the switch and start airing up your tires. Mounts under the hood and out of the way! Now making airing down and airing up a breeze with this AUTOMATIC DEPLOYMENT AIR SYSTEMS.
In stock at ROCKRIDGE 4WD
Contact ROCKRIDGE 4WD today for your quote!
Rockridge4WD 11-07-2012 03:23 PM
Don't forget ROCKRIDGE 4WD Offers FREE SHIPPING on ALL VIAIR PRODUCTS!
Contact Erin for your quote!
Rockridge4WD 12-12-2012 04:26 PM
When you need to air down and dont have the means to get aired up at the end of the trail you need to fix that problem with a VIAIR AUTOMATIC DEPLOYMENT AIR SYSTEMS (ADA) these sweet ada kits offers a 12-port extruded aluminum air tank to provide a compact air locker and tire inflation station using either a 400C (Heavy Duty) or 450C (Constant Duty) compressor at its core. ADA Systems come complete with a pressure switch, automatic coupler, Digital Tire Inflation Kit, and a wiring harness to make the installation a plug & play process. Universal models do not include a brake booster mounting bracket.
Using a 33% (Heavy Duty) duty cycle 400C compressor, tire inflation or air locker actuation is made possible in a very compact space. Each ADA System comes complete with an onboard pressure switch, automatic coupler and a Digital Tire Inflation Kit. Additionally, a wiring harness is included to make the installation a plug & play process, with very little install time required.
Blake
www.rockridge4wd.com
Rockridge4WD 02-27-2013 03:29 PM
No need with a tank for this system! Compact and fits under the hood! Will fill up 35" tires in nothing flat!
Contact Erin@Rockridge4wd.com
Rockridge4WD 03-06-2013 02:33 PM
This ADA System is FREE SHIPPING to the lower 48!!
Contact Erin@Rockridge4wd.com for your quote today!
Rockridge4WD 05-15-2013 04:11 PM
We have Universal set ups, Jeep Wrangler JK 07-10 and for Jeep Wrangler JK 11-13 available!
Still always FREE SHIPPING!
Rockridge4WD 08-09-2013 10:45 AM
2 Attachment(s)
:2thumbsup:
Rockridge4WD 09-06-2013 01:14 PM
1 Attachment(s)
The Best and Durable On Board Air system on the market! ROCKRIDGE 4WD has you covered. CONTACT US TODAY FOR YOUR VERY OWN QUOTE!
CONTACT DERRAN@ROCKRIDGE4WD.COM
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
CALL US TOLL FREE 1-888-411-8493
:2thumbsup:
Rockridge4WD 09-16-2013 01:37 PM
Look no further contact ROCKRIDGE 4WD today for your VIAR QUOTE!
CONTACT DERRAN@ROCKRIDGE 4WD.COM
:2thumbsup:
Rockridge4WD 09-27-2013 02:52 PM
Awsome Air System! Contact Rockridge 4wd for your Viair On Board Air Quote Today!
:2thumbsup:
Jeffro06 09-27-2013 02:59 PM
Could we get a bigger picture?
The time now is 07:22 PM.
