THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/Black Magic Brake Pads and RCV AXLES - JeepForum.com
post #1 of 32 Old 06-02-2014, 10:19 AM Thread Starter
Garza
You wanted it?! Well 4LowParts is happy to announce the NEW! VANCO DUAL MODE 15”/16″ Big Brake Kit with Black Magic Brake Pads and RCV AXLES COMBO!!!
***We are offering a special "combo-package" deal. BUT the Brake Kits and RCV axles are always available separately! We also have the combo deal on the 17" kits as well!
***Please be advised THE BIG BRAKE KITS are available on our site for pre-purchase on backorder, and will be shipping in 7-10 days!!
The NEW knuckles in this kit accept RCV Axles and are Pre-machined to eliminate any grinding by the customer which cures any fitment issues!!
Dual Mode Caliper mounting allows for both kits on the same knuckles with only a rotor swap to fit inside both 15” and 16” rims
This is a bolt in larger front rotor and dual piston caliper kit for the following Jeep Models:
1990-2006 Wrangler, TJ Wrangler in all trim levels including Rubicon and Unlimited Dana 30 and Dana 44 front axles
1990* Comanche
1990*-2001 Cherokee
1993-1998 Grand Cherokee
(*Kits will fit pre 1990 inner C if they are converted to TJ style unit bearings and upper balljoints)
Kits come standard with Black Magic Brake Pads.
Newly designed Big Brake kit with NEW High Strength Nodular Iron steering knuckles; not re-worked OEM to eliminate the hassle of added core charges and knuckle return shipping!
All new knuckles are ABS Compatible
New Knuckle is 100% made in the USA
Drivers-side Knuckle(only) can be ordered with a reverse taper for tie-rod flip.
Kit will work in both modes with either the early or late unit bearings used on the Wrangler.
The newly designed Vanco Dual Mode Big Brake Kit Includes:
Left and Right high strength nodular iron Dual Mode Steering Knuckles
New not re-manufactured corrosion resistant Zinc Plated 48mm dual piston Calipers
Optional Rotors for 16” rims
New Centric Premium Rotors (not re-manufactured)
Mounting Hardware including cotter pins, caliper saddle bolts and new banjo bolts with crush washers
Instruction pack
Optional RCV Axles
Thank you!
Garza
Garza is offline
post #2 of 32 Old 06-02-2014, 10:20 AM Thread Starter
Garza
Garza is offline
post #3 of 32 Old 06-02-2014, 10:46 AM
Border Dave
Got Sand?
Border Dave's Avatar
The second link you posted does't work, but I assume it's just the same as the first one?
Border Dave is offline
post #4 of 32 Old 06-02-2014, 11:07 AM Thread Starter
Garza
You are correct and it works now
Garza is offline
post #5 of 32 Old 06-02-2014, 12:06 PM
Border Dave
Got Sand?
Thanks, Ricky. Combo order with RCV shafts placed.
This is gonna be a HIGHLY polished Dana 30! lol
post #6 of 32 Old 06-03-2014, 08:30 AM Thread Starter
Garza
Thanks for the orders!
Garza is offline
post #7 of 32 Old 06-06-2014, 04:47 PM Thread Starter
Garza
Big brakes!!
Garza is offline
post #8 of 32 Old 06-06-2014, 09:22 PM
Border Dave
Got Sand?
I just got the RCVs today. Now the wait begins for the Vanco brakes...
post #9 of 32 Old 06-10-2014, 04:38 PM Thread Starter
Garza
Soon...very soon!
Garza is offline
post #10 of 32 Old 06-10-2014, 11:22 PM
Border Dave
Got Sand?
I hope so. I already have an appointment the day after tomorrow to take my Jeep into the shop. It'll be there a while while the motor gets pulled and sent back to the manufacturer, repaired, and then sent back and re-installed.
post #11 of 32 Old 06-16-2014, 11:36 AM Thread Starter
Garza
Garza is offline
post #12 of 32 Old 06-18-2014, 07:44 PM Thread Starter
Garza
Big Awesome Brakes!!!
Garza is offline
post #13 of 32 Old 06-24-2014, 11:46 AM Thread Starter
Garza
4LowParts is giving a little gift with any Big Brake kit purchase!!
Just tell us what size in the order notes upon checkout!
Thanks!
Ricky
Garza is offline
post #14 of 32 Old 06-24-2014, 01:10 PM
Border Dave
Got Sand?
Did I order mine too early to get one of these?
post #15 of 32 Old 06-24-2014, 01:51 PM Thread Starter
Garza
Nope, PM me your size!!
Garza is offline
You may not post new threads
