THE NEW! VANCO DUAL MODE 15"/16″ Big Brake Kit w/Black Magic Brake Pads and RCV AXLES
You wanted it?! Well 4LowParts is happy to announce the NEW! VANCO DUAL MODE 15"/16″ Big Brake Kit with Black Magic Brake Pads and RCV AXLES COMBO!!!
***We are offering a special "combo-package" deal. BUT the Brake Kits and RCV axles are always available separately! We also have the combo deal on the 17" kits as well!
***Please be advised THE BIG BRAKE KITS are available on our site for pre-purchase on backorder, and will be shipping in 7-10 days!!
The NEW knuckles in this kit accept RCV Axles and are Pre-machined to eliminate any grinding by the customer which cures any fitment issues!!
Dual Mode Caliper mounting allows for both kits on the same knuckles with only a rotor swap to fit inside both 15" and 16" rims
This is a bolt in larger front rotor and dual piston caliper kit for the following Jeep Models:
1990-2006 Wrangler, TJ Wrangler in all trim levels including Rubicon and Unlimited Dana 30 and Dana 44 front axles
1990* Comanche
1990*-2001 Cherokee
1993-1998 Grand Cherokee
(*Kits will fit pre 1990 inner C if they are converted to TJ style unit bearings and upper balljoints)
Kits come standard with Black Magic Brake Pads.
Newly designed Big Brake kit with NEW High Strength Nodular Iron steering knuckles; not re-worked OEM to eliminate the hassle of added core charges and knuckle return shipping!
All new knuckles are ABS Compatible
New Knuckle is 100% made in the USA
Drivers-side Knuckle(only) can be ordered with a reverse taper for tie-rod flip.
Kit will work in both modes with either the early or late unit bearings used on the Wrangler.
The newly designed Vanco Dual Mode Big Brake Kit Includes:
· Left and Right high strength nodular iron Dual Mode Steering Knuckles
· New not re-manufactured corrosion resistant Zinc Plated 48mm dual piston Calipers
· Black Magic Brake Pads
· Optional Rotors for 16" rims
· New Centric Premium Rotors (not re-manufactured)
· Mounting Hardware including cotter pins, caliper saddle bolts and new banjo bolts with crush washers
· Instruction pack
· Optional RCV Axles
Thank you!
Garza
1990* Comanche
1990*-2001 Cherokee
· Instruction pack
Thank you!
Garza
