NEW 07-12 Jeep JK Wrangler Inverted Drag Link, Frame Brace & Track Bar Drop Bracket - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > NEW 07-12 Jeep JK Wrangler Inverted Drag Link, Frame Brace & Track Bar Drop Bracket
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePoison Spyder JK Body Mounted Tire Carrier2014 Spartan Locker Special - While Supplies Last! Dana 3
Unread 02-29-2012, 09:51 AM   #1
Baseline 4x4
1979 CJ5
Rugged Ridge Frame Brace with Track Bar Drop Bracket, 2007-2012 Jeep JK Wrangler
Rugged Ridge Inverted Drag Link, 2007-2012 Jeep JK Wrangler
The heavy duty Frame Brace and Inverted Drag Link have been designed to reduce front end movement and shimmying on lifted Wranglers. The redesigned drag link is inverted or flipped up over the knuckle. With the frame brace it is up to 50% stronger than the factory drag link. to help eliminate front end shimmy and other alignment issues. The Frame Brace includes a trackbar drop bracket to help maintain the proper steering geometry. The kit is recommended on any Wrangler with 3” of more of left and an adjustable trackbar. Welding is required for installation.
Baseline 4x4 Outfitters
Baseline 4x4 is offline   Reply With Quote Quick reply to this message
