JKS now at Rockridge 4WD!! Premium quality, you can't go wrong with! - JeepForum.com
post #1 of 2 Old 05-20-2014, 03:13 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
JKS is now at Rockridge 4WD!!!
Have you seen the Acos Adjustable Coil Spacers? These are on the ROCKRIDGE 4WD XJ Build. These things are sick!
Conveniently adjust ride height without removing any suspension components
Compensates for uneven load distribution, spring settling, and sagging
Eliminates need to replace coil springs to accommodate future modifications
Instantly increases vehicle ride height upon installation for immediate benefits
Technically advanced design and billet construction dramatically enhances suspension appearance
New Dura-Thane™ isolators utilized to prevent noise transfer, and bump stops for durability
Front Adjustable Coil Spacers for 1.5-3.75" of lift. Sold in pairs. Compatible with TJ Rubincon and Unlimited models.
Adjusting ride height on coil sprung Jeeps® is fast, convenient and easy with Adjustable Coil Spacers from JKS. Whether adding clearance for larger tires, compensating for heavy accessories, or trimming an unlevel vehicle, these extraordinary spacers provide convenient control of ride height without removing any suspension components!
JKS Adjustable Coil Spacers feature billet aluminum construction, providing an appearance as impressive as their function. The threaded design accommodates changes to your vehicle with a level of precision impossible with ordinary poly spacers. Heavy duty adjustment rings are easy to operate with the suspension unloaded, using only an allen wrench to lock and unlock.
Mounted to the OE spring retainers, the Adjustable Coil Spacer functions as the upper spring seat using a new Dura-Thane™ isolator pad to dampen road noise. Installation automatically raises your Jeep at least one full inch for immediate clearance benefits. Ride height can be increased even more by rotating the billet aluminum adjustment ring. See below for the exact range of adjustment for your vehicle.
Has JKS created the perfect coil spacer?
By design, coil springs are more sensitive to load changes because they lack the inherent friction produced by leaf springs. As a result, simple modifications—like installing a bumper, winch or second battery—can easily affect vehicle ride height enough to create tire clearance problems.
Poly spacers are often used to improvise, although not recommended due to a lack of proper sizes and abundance of inferior designs. And purchasing new coil springs to compensate for each modification simply isn't practical, yet most Jeep® owners have had no other choice...that is, until now!
This set can work on XJ, MJ and ZJ
Contact Erin@Rockridge4wd.com for your quote today!
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 2 Old 05-20-2014, 03:16 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
These adjustable spacers are also sold for TJ and JK applications
TJ
JK
You may not post new threads
