05-24-2012, 10:50 AM
#1
Vendor
JK Wrangler 3.5" Game Changer Suspension by Metalcloak
With the advent of the Revolutionary 6Pak™ Shock Absorbers allowing for Long Travel shocks in a compact location, Metalcloak's engineers focused their attention on the JK Suspension System.
Their goal? Create a simple, bolt-on suspension kit that exceeds all current standards for flex and quality of ride.
The result?
The Metalcloak JK Wrangler Game-Changing Mid Arm Suspension System beats most long-arm kits in travel, articulation and flex at a fraction of the overall cost. Period.
Featuring the latest in suspension technology including the (Patent Pending #61/520,240) 6Pak™ Long Travel Shocks, Metalcloak Dual Rate Coils, Duroflex™ Control Arms with our (Patent Pending #13/368,570) Duroflex Joint, and front & rear Solid Chromoly Track Bars.
Our kit is changing the game in off-road suspension systems. Read the details below see why.
05-24-2012, 11:13 AM
#2
Vendor
Examining the Components of the Game Changer Suspension
WHAT'S IN THE KIT?
This is our ultimate kit. Containing all our Game-Changing suspension products. Just for you.
- 1414-GC-A: 6PAK SHOCK, 14 TRAVEL X 14 COMPRESSED
- 1213-GC-A: 6PAK SHOCK, 12 TRAVEL X 13 COMPRESSED
- SS-2001: DUAL RATE COIL SPRINGS, JK FRONT 3.5 4DR
- SS-2002: COIL SPRINGS, JK REAR 3.5 4DR
- 7105: DUROFLEX CONTROL ARMS, JK WRANGLER
- 7020: 6PAK, SHOCK MOUNT KIT, JK LOWER REAR
- 7021: 6PAK, SHOCK MOUNT KIT, JK UPPER FRONT
- 7015: SWAY BAR LINKS, JK 12.25 LENGTH
- 7032: BUMP STOPS, 2.0-4.0 JK REAR
- 7040: SELECTABLE BUMP STOPS, 1.0-4.0 JK FRONT
- 7016: TRACK BAR, JK FRONT, SOLID CHROMOLY
- 7106: TRACK BAR KIT, JK REAR, SOLID CHROMOLY
- SS-1100: BRAKE LINE KIT, JK FRONT OR REAR 24.5
WHY IS IT THE BEST? IT STARTS WITH THE SHOCKS
The design of the 6Pak didn't just revolutionize shocks, it changed the suspension game forever.
68 DEGREES OF MISALIGNMENT. THAT'S MAKES IT FLEXY.
The Duroflex™ Joint is the key to getting the greatest flex in a JK Wrangler bolt-on suspension kit. Period.
Metalcloak has taken the best features of the most widely used control arm joints and combine those features to create the Duroflex Joint, producing a Low-Maintenance, High-Misalignment (34˚), Self-Centering, Rebuildable Joint with an OEM quality ride.
WHY DUAL RATE COILS? 'CUZ IT TAKES TWO TO TANGO.
MetalCloak JK Wrangler Dual-Rate coils have the longest free length in the industry for greater articulation without sacrificing the OEM ride quality.
STOP THE GUESS WORK. BUMP IT UP!
Our Adjustable Bump-Stops remove the guess work on your Jeep and lets you build the bump stop you need, when you need it.
05-24-2012, 11:25 AM
#3
Vendor
HOW DO YOU MOUNT THE 6PAKS? JUST BOLT 'EM IN... SERIOUSLY.
The 6Pak Shock Mounting Kits for the JK Wrangler are simple. Easy. Period.
6Pak Front Shock Mounting Kit for JK Wrangler- Bolt-On (No Welding Required)
- Laser Cut, CNC Formed, 3/16 Steel
- Bolts Directly into Factory Shock Locations
- Designed Specificatlly for the 6Pak Shocks
- Gold Zinc Plating
6Pak Rear Shock Mount Kit, JK Wrangler
Brackets: - Gain 3" of Ground Clearance
- Easy Installation, Just Bolts On
- CNC Formed, Laser Cut 3/16 Steel
- Gold Zinc Plating
- Outboard Offset for 6Pak Body Clearance
Bar Pin Eliminators: - Specially Designed for 6Pak Shocks
- Inboard Offset for 6Pak Body Clearance
- Allows 6Pak to Bolt into Stock Location
- Gains 1/2" of Additional Down Travel
LONGER SHOCKS AND MORE CLEARANCE!
Up to 3" of the stock JK shock mount is eliminated with the 6Pak Shock Mount System. That's 3" added to your departure angle.
05-24-2012, 11:40 AM
#4
Vendor
SOLID CHROMOLY FRONT TRACK BAR KEEPS YOU... WELL... ON TRACK.
Formed for ultimate Up-Travel & Down-Travel the JK Wrangler Front Track Bar gives unprecedented strength, clearance, and improved ride stability.
More Information >>> http://www.metalcloak.com/JK-Front-Track-Bar-p/7016.htm
JK WRANGLER REAR TRACK BAR - A FIRST IN HI-CLEARANCE!
The Solidy Chromoly track bar is uniquely designed to clear on up-travel as well as downtravel. No other track bar is designed with up-travel in mind.
BOLT ON BRACKET IS A KEY COMPONENT
The bolt-on relocation and clearance bracket provides an easy to install solution that keeps the track bar... on track.
More Information >>> http://www.metalcloak.com/JK-3-5-Suspension-Phase-2-Long-Travel-Rear-Sway-p/7106.htm
09-05-2012, 09:29 PM
#5
Has anyone purchased and installed the game-changer? I am thinking about purchasing but haven't seen many comments or reviews.
09-05-2012, 11:54 PM
#6
MetalCloak'd
Thank you for the interest in the Game Changer...
You can see some reviews on our website... http://www.metalcloak.com/JK-Wrangle...Kit-p/7110.htm
And on various threads there have been comments about the products. One of the most prominent one is here:
http://www.jkowners.com/forum/showth...=71064&page=22
Hope this helps.
09-06-2012, 01:14 PM
#7
Whens the big sale on the whole ultimate kit? Looks like a great complete setup. Would love to have Nemesis flat fenders, Posions Spyder bumpers, 37s/38s and your Game Changer suspension/shock system.
09-11-2012, 11:56 AM
#8
MetalCloak'd
Just missed our free shipping sale... sent you a PM.
09-18-2012, 09:58 AM
#9
MetalCloak'd
Another shot of the Game-Changer but with a twist... this is the Game-Changer "Lite" --- substituting Old Man Emu Nitrocharger Sports for the 6Pak Shocks.
09-21-2012, 11:25 AM
#10
MetalCloak'd
Great photo from our friends at HeavyMetal Concepts.
09-26-2012, 11:36 AM
#11
MetalCloak'd
Got Articulation?
The LJ Rubicloak with the TJ/LJ 3.5" Game Changer.
10-15-2012, 10:43 AM
#12
MetalCloak'd
TJ Suspension Video... just finished... let us know your thoughts...
