JK Upper Control Arm Kit! DIY - JeepForum.com
post #1 of 24 Old 11-27-2013, 04:13 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
These take your weak and hardly flexible upper links and make them strong AND Highly Flexible!
KIT INCLUDES:
2--14" of 1.5" X .25" wall DOM tubing
2--3/4" X 3/4" Bore Heat & Cryo Treated Chromoly Heims
2--3/4" Tube Adapters (1" Tube ID)
2--3/4" Jam Nuts
4--3/4" to 1/2" Stainless Steel Misalignment Spacers
This kit is designed for two things. The first is it comes with 2 pieces of 1.5" x .25" DOM tubing to sleeve over your existing upper link arm and make it a lot stronger than stock. The second is it comes with two 3/4" heims to replace the upper bushings and allow your suspension to flex more than it had before.
Notes: The OD of your stock link is powder coated and might need to be ground off a little to slide the DOM over it.
Welding is required and should be done by a professional.
Here is what you start with and how to go about it!
You replace this bushing end with the Heim Joint...
And you put the pieces together and end up with this!
Weld'em and get more articulation and less expectation of bending them
If yours are already bent just cut them off shorter. The tube you use to replace the factory 1" x .120" wall is 1.5" x .25" wall and almost 3.5 times stronger so cutting them off shorter would never be a problem.
http://www.ruffstuffspecialties.com/...JKUFL-KIT.html
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 24 Old 01-16-2014, 09:48 AM Thread Starter
Dan Fredrickson
Vendor
To the top for you JK guys!
Dan Fredrickson
post #3 of 24 Old 01-23-2014, 07:16 PM Thread Starter
Dan Fredrickson
Vendor
Glad you guys like these so far, we have sold quite a few!
Dan Fredrickson
post #4 of 24 Old 02-06-2014, 08:52 AM Thread Starter
Dan Fredrickson
Vendor
Getting close to the weekend! Hope you guys have plans to hit the trails!
Dan Fredrickson
post #5 of 24 Old 02-18-2014, 08:46 AM Thread Starter
Dan Fredrickson
Vendor
This is moving up the JK favorite list!
Dan Fredrickson
post #6 of 24 Old 02-26-2014, 08:56 AM Thread Starter
Dan Fredrickson
Vendor
These are climbing the favorites list!
Dan Fredrickson
post #7 of 24 Old 03-25-2014, 08:59 AM Thread Starter
Dan Fredrickson
Vendor
Order your parts today to make sure you get them before the weekend!
Dan Fredrickson
post #8 of 24 Old 11-19-2014, 07:48 AM Thread Starter
Dan Fredrickson
Vendor
Check out our JK section on our site for more cool stuff like this!
Dan Fredrickson
post #9 of 24 Old 03-10-2016, 10:15 AM Thread Starter
Dan Fredrickson
Vendor
It's been a little while! These kits are still selling, and it is time to make this simple and easy upgrade that gets you so much extra strength!
Dan Fredrickson
post #10 of 24 Old 03-22-2016, 10:24 AM Thread Starter
Dan Fredrickson
Vendor
Give your Upper Arms the beef they need!
Dan Fredrickson
post #11 of 24 Old 03-29-2016, 11:37 AM Thread Starter
Dan Fredrickson
Vendor
These are an easy way to get the performance of a Heim, while still keeping the stock bushing for a little comfort on the axle side.
Dan Fredrickson
post #12 of 24 Old 04-13-2016, 06:20 PM Thread Starter
Dan Fredrickson
Vendor
An easy way to make your stock arms a lot stronger, and a little bit longer if you want.
Dan Fredrickson
post #13 of 24 Old 04-21-2016, 10:54 AM Thread Starter
Dan Fredrickson
Vendor
It's your control arm, only stronger!
Dan Fredrickson
post #14 of 24 Old 04-27-2016, 05:44 PM Thread Starter
Dan Fredrickson
Vendor
Inexpensive, and a serious strength upgrade.
Dan Fredrickson
post #15 of 24 Old 05-16-2016, 08:46 PM Thread Starter
Dan Fredrickson
Vendor
It doesn't always take big bucks to have heavy duty control arms, you can do it on a budget and still have real strength!
Dan Fredrickson
You may not post new threads
