JK Rear Adjustable Control Arms! - JeepForum.com
post #1 of 17 Old 04-16-2014, 08:41 AM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
This is an awesome kit to replace those wimpy stock Rear Lower links.
Comes with all that you see pictured, the tubing with the weld bungs already in place, 2-1.25" Heat and Cryo Treated Chromoly Heim Joints with Jam nuts and Misalignments for 9/16" Bolt. Flexible yet durable Poly bushings are included as well with the inner sleeve for a 9/16" Bolt.
Fully welded and ready to install! Should only be a 10 minute job. Fits 2007-2014 Jeep JK's.
http://www.ruffstuffspecialties.com/...KRLAL-KIT.html
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 17 Old 04-22-2014, 09:20 PM Thread Starter
Dan Fredrickson
Vendor
Compare whatever brand you are using and you will agree, there is nothing to compare!
Dan Fredrickson
post #3 of 17 Old 05-15-2014, 02:29 PM Thread Starter
Dan Fredrickson
Vendor
The right strength in the right place!
Dan Fredrickson
post #4 of 17 Old 11-19-2014, 07:51 AM Thread Starter
Dan Fredrickson
Vendor
Time for a bump!
Dan Fredrickson
post #5 of 17 Old 06-08-2016, 04:44 PM Thread Starter
Dan Fredrickson
Vendor
Get the beef where it counts!
Dan Fredrickson
post #6 of 17 Old 08-12-2016, 08:01 PM Thread Starter
Dan Fredrickson
Vendor
Time to get out of that stock side and come over to the dark side
Dan Fredrickson
post #7 of 17 Old 09-12-2016, 09:11 AM Thread Starter
Dan Fredrickson
Vendor
Beefy and adjustable for whatever the hell you've got going on under there! ;-)
Dan Fredrickson
post #8 of 17 Old 09-29-2016, 05:53 PM Thread Starter
Dan Fredrickson
Vendor
The last control arm you will ever need!
Dan Fredrickson
post #9 of 17 Old 10-24-2016, 10:51 AM Thread Starter
Dan Fredrickson
Vendor
1/4" Wall DOM Tube and 1-1/4" Heims will get you where you need to go.
Dan Fredrickson
post #10 of 17 Old 11-11-2016, 11:23 AM Thread Starter
Dan Fredrickson
Vendor
Turn a weak-spot into a strong-point!
Dan Fredrickson
post #11 of 17 Old 11-25-2016, 10:41 AM Thread Starter
Dan Fredrickson
Vendor
You always want to be overbuilt... don't be the guy with the stock suspension that gets in way over your head.
Everyone loves to watch you get stuck, but nobody want to help get you out....
Dan Fredrickson
post #12 of 17 Old 01-02-2017, 09:38 AM Thread Starter
Dan Fredrickson
Vendor
Get strength AND adjustability all in one stop!
Dan Fredrickson
post #13 of 17 Old 01-17-2017, 09:12 AM Thread Starter
Dan Fredrickson
Vendor
I can't come up with a good reason not to get a set of these if you care about your JK.
Dan Fredrickson
post #14 of 17 Old 03-14-2017, 09:35 AM Thread Starter
Dan Fredrickson
Vendor
Unless you just really love replacing stock links I guess....
Dan Fredrickson
post #15 of 17 Old 06-06-2017, 01:32 PM Thread Starter
Dan Fredrickson
Vendor
Much stronger, and gives you some adjustment for whatever you might have done, or are about to do.
Dan Fredrickson
You may not post new threads
