JK Front Axle Truss - Page 5 - JeepForum.com
post #61 of 73 Old 02-19-2014, 06:30 PM
4wdjeepguy
Talking about for a jk axle
4wdjeepguy is offline
post #62 of 73 Old 02-20-2014, 02:45 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Not for the stock axle. See explanation below.
Casting - Initially when we were designing the JK truss, we wanted to bridge over the casting as all our other trusses do. But after alot of testing and discussion, bridging over the casting and not tying into it actually resulted in a weaker design because you have hug the casting (to avoid clearance issues) in a weird shaped truss that doesn't actually transfer load in the way it needs to. If you look at the axle, the pumpkin is the strongest part of the axle. The weak parts are right where the tube enters the casting and the tube itself. So essentially, a truss that only attaches to the tube, then makes a weird shaped bridge over the top that's not directly inline with the rest of the truss is in fact only keeping the tube from bending and not reinforcing the junction of the tube and casting. By welding to the casting and tube and having everything tied together, it reinforces everything directly and its attaching to the strongest section, the main casted section. It also means you keep the factory driver side UCA mount that is cast instead of having to cut off that very strong mount and replace it with an inferior bracket.
We've sold thousands of the JK trusses with great success. We run them on our JK with 40s. No need for a bridge that goes over on the stock axle. The ONE TON SWAP needs it because there is no cast in mount on the dana 60.
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #63 of 73 Old 07-07-2014, 12:22 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Another customer satisfied with his #artecexperience and one of the best selling trusses on the market.
Almost ready to install. My, new to me, high pinion dana 30. Has your truss, inner C gussets, and LCA mounts. Also has an Eaton E-locker, 4.56s and chromo shafts. Should be a solid replacement for my stock low pinion TJ axle. Thank you for the excellent product. Fit was awesome with very little fitting needed.
-Josh Fleming‎
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #64 of 73 Old 08-20-2014, 12:16 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Hey pay attention!
I'm going to let all yall on Jeepforum in on a little secret! We are now shipping all of our armor kit front trusses with paper instructions! Not that it was hard to install (or download instructions from the website) but hey we're nice guys looking to make your #Artecexperience even better.
The trusses currently shipping with instructions are
JK trusses to be put on Dana 30's and 44's
TJ, LJ, and ZJ also for Dana 30's and 40's aaaaaaand...
XJ trusses for Dana 30's.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #65 of 73 Old 08-26-2014, 11:35 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Now with all that right there we can see why this is one of the best selling trusses on the market!
Strength and Style!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #66 of 73 Old 08-28-2014, 10:09 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Pre-boxed on the shelf ready to ship.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #67 of 73 Old 09-04-2014, 11:46 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Favorite two colors right there well done!!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #68 of 73 Old 09-17-2014, 04:09 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
New shipment finishing up in the press break ready to go!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #69 of 73 Old 10-01-2014, 01:28 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Preboxed and instructions inside! Gets shipped out fast as
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #70 of 73 Old 10-03-2014, 05:00 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
I know I've said this before but when I say these things ship fast I mean they ship FAST!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #71 of 73 Old 10-15-2014, 11:15 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
There is a simple question that must be asked here. Why not? if you have a legitimate reason ok but don't kid yourself these trusses will save you in the end.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #72 of 73 Old 10-28-2014, 12:59 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
For that awesome one off custom look you gotta go with these artec trusses
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #73 of 73 Old 12-12-2014, 11:42 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
New Ruffstuff 9" Truss! Dan Fredrickson Vendor Display 9 08-29-2012 02:17 PM
Dana 44 axle truss ARTEC Vendor Display 0 06-29-2012 06:05 PM
Barnes 4wd Axle Truss Barnes4wd Vendor Display 56 01-12-2012 11:44 AM
You may not post new threads
