The TREKSTM Offroad Equipment Front Bumper for the Jeep JK is the perfect balance between not enough and too much. Our winch bumper stays out of the way on the trail and allows you to get the tires to the obstacle. With the great approach angles designed into the bumper and included skid plate, you can tackle the toughest terrain.
Looking for an integral winch mount, included skid plate, factory fog light mounts, 1" shackle mounts and light weight? This is the bumper for your JK!
Key Features:
- 3/16" formed steel bumper
- Formed steel skid - dimpled for strength
- 100% Bolt-on install
- 1" shackle mounts
- Reuses Factory Fog Lights
- Crafted in the USA
- Integrated winch mount, nothing else is needed to mount your winch; drop in, bolt on and go! Accommodates most common winches up to 9500 lbs, including the massive Warn Powerplant HP.
- Reversible fairlead mount, allows center or offset placement of your winch and fairlead. Accepts roller or hawse fairlead. Offset position must be used for WARN Power Plant HP
- 1" clevis mounts are fully welded to the bumper and mounting system
The TREKS
TM Offroad Equipment Full-Width Rear Bumper for the Jeep JK is the perfect balance between full body protection and excellent departure angle. Looking for rugged mounting, tire carrier option and added illumination behind your JK?
Our bumper is constructed of 3/16" steel for ultimate strength without excessive weight penalties. Our full-width bumper stays out of the way while offroad with great departure angles all while maintaining smooth clean lines for a night on the town.
- 100% Bolt-on Install
- Integrated back-up light cut outs are standard, light kit optional.
- Multi-mount mounting system. 14 points total! Compare that to the competition.
- Utilize your factory receiver hitch for towing duties or as a third pull point, our bumper fits around the factory hitch.
- 1" shackle mounts are fully welded to the bumper and frame mounting system.
- Accommodates up to a 35" tire on the stock tire mount.
Looking to get the tire weight off the tailgate OR carry a larger tire? Look at our optional bolt on tire carrier!
Optional Tire Carrier
Key Features
- Bolt-on accessory for TREKSTM rear bumper
- .120" wall tubing construction - decreased weight
- Rattle free latch mechanism
- Adjustable tire mounting system
The TREKSTM Offroad Equipment Swing-out Tire Carrier for your TREKSTM Rear Bumper is the perfect accessory for the back of your Jeep. Looking for rugged mounting, smooth operation and capacity for a 37" tire for your JK?
This is the carrier for your JK!
Our swing-out carrier keeps your tire out of the way while offroad, gives rattle free highway cruising and silky smooth operation all with an adjustable tire mounting mechanism to accommodate just about any wheel & back-spacing combination.
TREKSTM Offroad Equipment accessories are assembled per your order; please allow 2-3 weeks for delivery. At this time our accessories are only available in bare steel.
Call 307-775-9565 to order!
Rod
T&T Customs, Inc
