"JEEPFORUM.COM" Discount Coupon - Under Cover Fabworks
#46 | |
Vendor
The long strut goes on the driver side.
Matt Walton http://undercoverfab.com http://blog.undercoverfab.com sales@undercoverfab.com (334) 797-7113 Check us out on Facebook
#47 |
#48 |
Under Construction
Hey Matt, do you have any plans of making bumpers for the XJs? Maybe a DIYT kit?
#49 |
Vendor
Not at this point.
#50 |
Under Construction
Any way you could do a truss like the D44 I bought off of you, but for a D30?
#51 |
Vendor
Sure there is... Are you looking for something just to mount the upper to for a 3-link front?
#52 |
Under Construction
Kind of, yeah. But the more I think about it, maybe I should just go with a full front truss? I kind of bent my current one, so I'm picking up a HP30, and looking at options to keep it from happening again. I was thinking about sleeving it and maybe one of your trusses, but it might be easier to just truss it all the way.
#53 | |
Vendor
#54 |
I have a new used 2005 LJ Automatic (stock). I have a short wife and 2 small kids so a lift is not in the cards, it's hard enough for them to get into the stock
![]() Just crawled underneath to look around and noticed it has skid plates(?) at about the driver position and back, I'm guessing from the factory. But no oil pan skid plate. Is that correct? What are my options for removing the stock ones, replacing/adding more protection? This is a daily driver with a baby trail run maybe once or twice a year and a bit of off-road/disaster response stuff a few times a year. I see this one: Under Cover Fabworks, LLC - '03-'06 TJ/LJ Transfer Case Skid Plate (No Body-Lift Req'd)(Carbon Steel) But doesn't that just replace what I have now from the factory(?), obviously better quality though. I'm new to skid plates/under carriage protection so correct my ignorance please. -Tyler
www.mychicagogarden.com - When not in your Jeep you gotta have another hobby! 2005 LJ - JKS 1.25"BL/1"MML, Hellroaring Battery Isolation, KargoMaster Congo Cage/Rack, Rock Hard Rear Bumper, UCF Deep Cover Skid Plate System, MetalCloak Front Bumper Last edited by mysigp226; 03-29-2010 at 06:31 PM.. |
#55 | |
Vendor
Under Cover Fabworks, LLC - '03-'06 TJ/LJ Transfer Case Skid Plate (No Body-Lift Req'd)(Carbon Steel) and this to protect the engine: Under Cover Fabworks, LLC - '03-'06 TJ/LJ Carbon Steel Engine Skid Plate (4.0l) These are the steel versions. They represent the best value (3/16" TC skid is $50 cheaper than 1/4" steel) if you don't wheel it hard and don't already have it overloaded with other gear. This system will protect everything from the front of the exhaust to the rear of the transfer case. They work with everything else as stock. Thanks,
#56 |
awesome..on my parts list. thanks!
Any concern with running naked with the steel? or should I coat it with something. I live in Chicago winters.
www.mychicagogarden.com - When not in your Jeep you gotta have another hobby! 2005 LJ - JKS 1.25"BL/1"MML, Hellroaring Battery Isolation, KargoMaster Congo Cage/Rack, Rock Hard Rear Bumper, UCF Deep Cover Skid Plate System, MetalCloak Front Bumper |
#57 |
Vendor
The steel skid plates need to be cleaned, primed and painted. It would be bad to leave it bare!
#58 |
You also forgot to mention that he won't get hung up as much because there is more clearance
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas |
#59 | |
#60 | |
Vendor
Edit: Be sure to let the primer cure for a couple hours. It looks dry in 5 minutes but don't be fooled. If you paint on top of it too soon it will scrape off easily.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
