Jeep YJ/TJ/JK Wrangler Universal Spare Tire Adapter
#1 | |
Vendor
We all know that CJ's came with a 5 on 5.5 bolt pattern and that YJ's, KJ's, XJ's, ZJ's and TJ's came with a 5 on 4.5 pattern. Well, just to screw up the mix the new 2007 Wrangler JK comes with a 5 on 5 pattern. Suppose you upgraded your stock axles on your TJ to the larger 5 on 5.5 pattern, but your tire carrier only holds the stock smaller pattern, and you haven't ordered your AtoZ Spare Tire Carrier yet...you need some way to mount your larger pattern 5 on 5.5 wheels to your tail gate. We have the solution! The AtoZ Universal Jeep Spare Tire Adapter allows you to mix any Jeep pattern to any Jeep pattern. If your running wheel adapters to fit the new JK 5 on 5 wheels...you can now run a matching spare. This also allows the JK Wrangler to run a larger tire on the stock carrier as it moves the tire up and out to miss the bumper and the third brake light. Simply install the wheel studs, included in the kit along with a nifty installation helper, to match the pattern you need and your all set. You can now run the rim of your choosing and it moves it up and out about 3 inches over all! This is a unique item that only AtoZ Fabrication can offer you.
![]() Order these online or give us a call!
Have a great day!!! Zach Vaughn. AtoZ Fabrication, Inc. 570-385-3931--shop 570-385-3932--fax MADE IN AMERICA---and proud of it!!! Now scheduling cage/custom work so call now to get on the calendar. CHECK OUT OUR DIY FAB PARTS FOR SALE!! We also offer the best prices available on: Advance Adapters Clayton Offroad Suspension Amsteel Winchline and accessories Staun beadlocks and deflators |
#2 |
Vendor
These things are going fast....get'm while they last! You know you need one...they fit any Jeep bolt and adapt to any Jeep pattern so you can don't have to worry about if you can carry a spare tire...or if the tire will fit or not!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
