JEEP JK LED HEADLIGHTS DOT APPROVED! TRUCK LITE available at ROCKRIDGE 4WD FREE SHIP! - JeepForum.com
post #1 of 43 Old 02-25-2013, 04:11 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Truck-Lite's 27270CK LED Headlamp Kit utilizes a completely new light delivery method, adopting parabolic reflector technology to create a smooth, even light output. The use of metalized reflector optics provides a clean and homogeneous spread of light, more uniform than other options, without any targeted or focused beams or projector-type color artifacts. Truck-Lite Used the latest in computer-assisted optics design software to create a reflector-based system that provides an optimum lighting pattern. We essentially increased visibility to the driver, while minimizing glare to oncoming traffic, providing illumination that's safer to everyone on the road. The lamp is designed with Omni-VoltĀ® technology to accommodate both 12 and 24 volt headlamp applications, providing crisper and whiter light output than halogen alternatives, while extending product life and adding greater dependability. The maintenance-free lamp uses a solid-state, bulb-free system that's impervious to damage caused by shock and vibration, with a military grade, die-cast aluminum housing, non-yellowing polycarbonate lens and a scratch-resistant hard coating to protect against damage from impact, roadside debris and other hazards. Advanced LED technology has significantly reduced LED headlamp current draw compared to halogen products, to 3.6a high beam and 1.8a low beam, allowing more power for other vehicle requirements & extending alternator life.
Fits 2007 To 2013 Wrangler, Rubicon and Unlimited
2 and 4-door models
Sold as a pair with JK Wrangler headlight adapters
Hard coated polycarbonate lens
Anodized aluminum housing
Parabolic reflector technology
Encapsulated circuitry
Die cast aluminum housing
3-year limited warranty
DOT approved
Do you want a light that is SUPER bright, hardly uses power, durable (can be thrown across parking lot and not BREAK) then you need TRUCK LITE
Contact Erin@Rockridge4wd.com to get the ULTIMATE Lighting System!
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 43 Old 02-26-2013, 12:31 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Killer deal going on Truck Lite LED HEADLIGHTS! Awesome lights!!
post #3 of 43 Old 02-27-2013, 03:27 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
This is the NEW headlight! Very durable, long lasting and bright! DOT approved!!
post #4 of 43 Old 02-27-2013, 06:34 PM
shooters_7
Plugs right in to CJs as well and works great!
shooters_7 is offline
post #5 of 43 Old 02-28-2013, 10:44 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
YES it does!! As well as TJ's!!!
post #6 of 43 Old 03-14-2013, 12:15 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
TRUCK LITES will be in the ROCKRIDGE JK here soon!! Can't wait they are an AWESOME light!
Contact Erin@Rockridge4wd.com for your quote on some killer lights!
post #7 of 43 Old 03-22-2013, 12:42 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
WOOP WOOP!! Just got more Truck Lites in!! These are flying off the shelf!! Hurry up and get your set! Good for Jeep JK, TJ or even CJ as well as will fit you Harley or any bike with a 7" Round light!!
Contact Erin@Rockridge4wd.com or PM!
post #8 of 43 Old 03-27-2013, 04:08 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
These are flying off of our shelves!! These will fit in CJ, TJ and JK or your bike whatever has a 7" round they will work!!
post #9 of 43 Old 03-27-2013, 04:27 PM
Deacon
Shining Adonis
Deacon's Avatar
Any example/test images to share? Do they flicker when connected to factory lighting, requiring a separate relay harness powered directly from the battery?
Deacon is offline
post #10 of 43 Old 03-27-2013, 04:42 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
I will post some pictures here in a few of my JK with the old versus TRUCK LITE! They are killer!! The JK's do require a Pig Tail wire harness for install other's do not.
Keep watching for the Pictures!
post #11 of 43 Old 03-27-2013, 04:46 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Truck Lite versus Sylvania Ultra's
Pure Truck Lite
post #12 of 43 Old 03-27-2013, 05:06 PM
Deacon
Shining Adonis
Deacon's Avatar
Cool, but I meant more sitting behind the wheel and seeing the pattern, distance, etc, of the lighting.
Deacon is offline
post #13 of 43 Old 03-27-2013, 05:31 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Got it!!
Click here to watch their video!
post #14 of 43 Old 04-18-2013, 04:49 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Now in stock and ready to ship!!!!
post #15 of 43 Old 04-25-2013, 12:51 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
NEED THOSE TRUCK LITES? WE HAVE YOU COVERED! CONTACT ME TODAY FOR YOUR QUOTE!
You may not post new threads
