-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   JEEP JK LED HEADLIGHTS DOT APPROVED! TRUCK LITE available at ROCKRIDGE 4WD FREE SHIP! (http://www.jeepforum.com/forum/f43/jeep-jk-led-headlights-dot-approved-truck-lite-available-rockridge-4wd-free-ship-1484529/)
Rockridge4WD 02-25-2013 04:11 PM
5 Attachment(s)
Truck-Lite's 27270CK LED Headlamp Kit utilizes a completely new light delivery method, adopting parabolic reflector technology to create a smooth, even light output. The use of metalized reflector optics provides a clean and homogeneous spread of light, more uniform than other options, without any targeted or focused beams or projector-type color artifacts. Truck-Lite Used the latest in computer-assisted optics design software to create a reflector-based system that provides an optimum lighting pattern. We essentially increased visibility to the driver, while minimizing glare to oncoming traffic, providing illumination that's safer to everyone on the road. The lamp is designed with Omni-VoltĀ® technology to accommodate both 12 and 24 volt headlamp applications, providing crisper and whiter light output than halogen alternatives, while extending product life and adding greater dependability. The maintenance-free lamp uses a solid-state, bulb-free system that's impervious to damage caused by shock and vibration, with a military grade, die-cast aluminum housing, non-yellowing polycarbonate lens and a scratch-resistant hard coating to protect against damage from impact, roadside debris and other hazards. Advanced LED technology has significantly reduced LED headlamp current draw compared to halogen products, to 3.6a high beam and 1.8a low beam, allowing more power for other vehicle requirements & extending alternator life.
Fits 2007 To 2013 Wrangler, Rubicon and Unlimited
2 and 4-door models
Sold as a pair with JK Wrangler headlight adapters
Hard coated polycarbonate lens
Anodized aluminum housing
Parabolic reflector technology
Encapsulated circuitry
Die cast aluminum housing
3-year limited warranty
DOT approved
Do you want a light that is SUPER bright, hardly uses power, durable (can be thrown across parking lot and not BREAK) then you need TRUCK LITE
Contact Erin@Rockridge4wd.com to get the ULTIMATE Lighting System!
Rockridge4WD 02-26-2013 12:31 PM
Killer deal going on Truck Lite LED HEADLIGHTS! Awesome lights!!
Rockridge4WD 02-27-2013 03:27 PM
This is the NEW headlight! Very durable, long lasting and bright! DOT approved!!
:highfive:
shooters_7 02-27-2013 06:34 PM
Plugs right in to CJs as well and works great!
Rockridge4WD 02-28-2013 10:44 AM
YES it does!! As well as TJ's!!!
:cheers2:
Rockridge4WD 03-14-2013 12:15 PM
TRUCK LITES will be in the ROCKRIDGE JK here soon!! Can't wait they are an AWESOME light!
Contact Erin@Rockridge4wd.com for your quote on some killer lights!
Rockridge4WD 03-22-2013 12:42 PM
WOOP WOOP!! Just got more Truck Lites in!! These are flying off the shelf!! Hurry up and get your set! Good for Jeep JK, TJ or even CJ as well as will fit you Harley or any bike with a 7" Round light!!
Contact Erin@Rockridge4wd.com or PM!
Rockridge4WD 03-27-2013 04:08 PM
These are flying off of our shelves!! These will fit in CJ, TJ and JK or your bike whatever has a 7" round they will work!!
Deacon 03-27-2013 04:27 PM
Any example/test images to share? Do they flicker when connected to factory lighting, requiring a separate relay harness powered directly from the battery?
Rockridge4WD 03-27-2013 04:42 PM
I will post some pictures here in a few of my JK with the old versus TRUCK LITE! They are killer!! The JK's do require a Pig Tail wire harness for install other's do not.
Keep watching for the Pictures!
Rockridge4WD 03-27-2013 04:46 PM
2 Attachment(s)
Truck Lite versus Sylvania Ultra's
Attachment 595089
Pure Truck Lite
Attachment 595090
Deacon 03-27-2013 05:06 PM
Cool, but I meant more sitting behind the wheel and seeing the pattern, distance, etc, of the lighting.
Rockridge4WD 03-27-2013 05:31 PM
Got it!!
Click here to watch their video!
Rockridge4WD 04-18-2013 04:49 PM
3 Attachment(s)
Rockridge4WD 04-25-2013 12:51 PM
NEED THOSE TRUCK LITES? WE HAVE YOU COVERED! CONTACT ME TODAY FOR YOUR QUOTE!
:wave:
The time now is 10:14 PM.
