JD Squared BEAST Notcher - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > JD Squared BEAST Notcher
Oconee Off-Road Free Shipping Lifts Tires Bumpers Tops andUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-26-2014, 08:31 AM   #1
JDSquaredInc
Vendor
JDSquaredInc's Avatar
Beast Notcher
The Beast is the ultimate in hole saw tube notching. Able to easily handle straight notches, offset notches, angled notches, and notches in bends.
The weight of the BEAST notcher is 50 lbs. This helps with the chatter and saves longer on your hole saws.
List Price - $499
Features:
* Capacity of 3/4" to 3" OD
* Angles up to 50°
* Can offset notch up to half the tube diameter.
* 1" Ground & Polished Stainless Steel shaft
* Double sealed needle bearings.
* Clamps allow you to notch on a bend.
* Requires an ordinary 1/2" hand drill
Ryan Miles - Sales & Marketing
JD Squared, Inc.
Phone: (423) 979-0309
Fax: (423) 979-2426
Made in the USA
www.JD2.com
JDSquaredInc is offline   Reply With Quote
Unread 03-26-2014, 11:25 AM   #2
JDSquaredInc
Vendor
Jeep Forum members receive a 10% discount for all online orders. Visit www.jd2.com and put in coupon code jeepforum.
If you need a quote feel free to PM us or send us an email to sales@jd2.com. Thanks!
JD Squared, Inc.
Fax: (423) 979-2426
Made in the USA
www.JD2.com
Unread 04-10-2014, 03:33 PM   #3
JDSquaredInc
Vendor
If anyone should need a quote send a PM or email us at sales@jd2.com.
All Jeep Forum Members receive a 10% discount on online orders. Use coupon code JeepForum when ordering at www.jd2.com.
JD Squared, Inc.
Fax: (423) 979-2426
Made in the USA
www.JD2.com
Unread 04-22-2014, 09:03 AM   #4
JDSquaredInc
Vendor
If anyone should need a quote send a PM or email sales@jd2.com.
JD Squared, Inc.
JD Squared, Inc.
Fax: (423) 979-2426
Made in the USA
www.JD2.com
Unread 07-03-2014, 12:25 PM   #5
JDSquaredInc
Vendor
JD Squared, Inc.
Fax: (423) 979-2426
Made in the USA
www.JD2.com
