Introducing the NEW 12000lb Synthetic Winch - JeepForum.com
post #1 of 2 Old 06-19-2012, 05:28 PM Thread Starter
JeepHut
The new 12000 Synthetic winch by Engo is now ready to ship or come pick one up at our store. 770-653-8860
http://thejeephut.com/engo-e12000-12...e-p-40600.html
The new ENGO E Series winches provide all the best features you
would want in a winch. Using state of the art Series Wound Motors,
efficient 3-Stage planetary gear train, automatic load-holding brake,
rugged hand remote, freespooling, power In and Out, stainless steel
fasteners and a standard 4 Way Galvanized Roller Fairlead. The new
E Series offers the perfect balance of speed and power giving you
the performance you need for your recovery applications.
ENGO is proud to provide the E Series winches for Jeep and Truck
applications with a limited lifetime warranty on mechanical
components with a 1-Year warranty on electrical components.
ENGO has an E Series recovery winch to handle every job imaginable
and offers the best all around performance and value of any winch
available.
Rated Line Pull 12,000 lb.(5454kg)
Motor 6.0 HP, Series Wound
Gearing 3-Stage Planetary
Gear Ratio 265:1
Brake Automatic Load Holding
Clutch Free Spooling
Fairlead Hawse
Cable or Rope Synthetic 3/8" x 85'
Net Weight 65 lb.(30kg)
Dimensions Length x Width x Height, 21.9" x6.3"x8.7"(555mm x 161mm x 222mm)
Drum Dimensions Diameter 2.5"(63mm) x Length 8.8"(224mm)
Mounting Bolt Pattern 10" x 4.5" (254mm x 114.3mm)
Warranty Limited Lifetime/ 1-Year Electrical
Model: 77-12000S
JeepHut is offline
post #2 of 2 Old 06-21-2012, 02:33 PM Thread Starter
JeepHut
thanks for the orders only synthetic left in 12k
706-692-5488
JeepHut is offline
Discounts on Synthetic Winch Line oconee offroad Vendor Display 68 10-07-2014 07:17 AM
You may not post new threads
