Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 96 - JeepForum.com
 32Likes
post #1426 of 13493 Old 05-12-2010, 06:28 PM
LuckRider
LuckRider's Avatar
I have those numbers. Looks like it is going to be just under 60 Square Feet for the outside of a TJ/YJ/CJ. Here is the math (all done in inches, then divided by 144 to convert to feet).
Originally Posted by Luckrider
Grill :756"
Tail :1440"
Fender:252" x 2 =504"
Door :864" + 98" x2 = 962" =1924"
Hood :3286" - 371" =2915"
Rear :288" + 128" x2 = 416" =832"
Total :8371" = 58.13194444444 Square Feet
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #1427 of 13493 Old 05-12-2010, 08:30 PM
Polecat
Polecat's Avatar
So we all know what the interior of a Jeep looks like with Monstaliner. But what about the front grill? Well...here ya go.
I used a different (but similar) roller on the front and you can see that the texture is a lot more aggressive than what it would normally be. It's just one coat and the liner was pretty thick when I put it on. I suppose I could have thinned it down a little more with MEK. I did the interior on Sunday and the grill on Monday. I'm happy with the way it turned out and I like the protection it will give me from stone chips on the road and branches sticking out on the trail.
Magnetman...I'll get you some better pictures over the weekend in case you want to post them on your site.
Polecat is offline
post #1428 of 13493 Old 05-12-2010, 08:38 PM
LuckRider
LuckRider's Avatar
That looks great. I think the texture is really nice. It looks tighter, but also a bit sharper. I love how clean the tape lines came out.
So... what is the thing on the bumper that says up?
Support Our Troops!
JFI Member #7:
post #1429 of 13493 Old 05-12-2010, 09:43 PM
inglisleslie
Just finished my second coat I will Post more pics when I install the interior:
inglisleslie is offline
post #1430 of 13493 Old 05-12-2010, 10:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by TomJ View Post
Just ordered my kit - can't wait for it to get here.
thanks for that JF deal, magnetman. Made me bite the bullet...saved me $50 too
Got your order, thanks!
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #1431 of 13493 Old 05-12-2010, 10:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thank you!
Connect with us on:
post #1432 of 13493 Old 05-12-2010, 10:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That looks great! More photos would be cool, thanks.
What was the roller you used?
Connect with us on:
post #1433 of 13493 Old 05-12-2010, 11:01 PM
LuckRider
LuckRider's Avatar
No problem. I even drew a tiny little diagram of each section that was measured.
Support Our Troops!
JFI Member #7:
post #1434 of 13493 Old 05-13-2010, 12:54 AM
Goobersbro
Hahaha I'm going to get flamed yet again haha but uhm that mek stuff you have will it take off an undercoating....I finally got my tub off today to start working on the frame and the parts under the tub that arn't rusted have like a linex or something on them and its failing and I need to get it all off most of it is scraping pretty easy but down in the cracks and stuff its a little hard and some of the big open spaces its like cured real hard.... So yea what would you recommend for removal of this undercoating crap....
My marshmallow build
Goobersbro is offline
post #1435 of 13493 Old 05-13-2010, 12:58 AM
LuckRider
LuckRider's Avatar
Sounds like it is just undercoating like you said. MEK seemed to tear into that stuff. It is worth a shot. I don't know if you really want to play with a propane torch, even with the body off (yep, I saw that pic... Nice man ).
Support Our Troops!
JFI Member #7:
post #1436 of 13493 Old 05-13-2010, 12:59 AM
Goobersbro
thanks man its a ton of work haha how much mek should I buy...??
post #1437 of 13493 Old 05-13-2010, 01:02 AM
LuckRider
LuckRider's Avatar
A quart should be enough, but if you are going to line your tub too, I would get the gallon. I know they sell the quart at Home depot here for $12 and the gallon at Lowes (right across the street, and both only carry those sizes) for $24. 4 times the amount for 2 times the cost seems worth it to me.
Support Our Troops!
JFI Member #7:
post #1438 of 13493 Old 05-13-2010, 01:10 AM
Goobersbro
Alight, I may be ordering some of the rust preventive you guys offer too. I need to do the frame and the bottom of the tub. I don't have enough Por-15...Is the stuff really as good as Por? I know its way cheaper which is sweet, but does it cure the same way and will it do the same job....Rust preventives are kind of like bedliners a lot of companys have them but only some are good...So I would like some confirmation that its a solid product because I know for a fact Por-15 is and I don't want to take the cheaper route here and regret it.
post #1439 of 13493 Old 05-13-2010, 01:14 AM
LuckRider
LuckRider's Avatar
Holey lack of punctuation. Considering they included many free quarts, I would imagine that someone in here can help you out with Chassis Saver. I haven't used it yet personally, but I am planning on keeping away the surface rust by coating mine this summer. I hate NY winters.
Support Our Troops!
JFI Member #7:
post #1440 of 13493 Old 05-13-2010, 05:59 AM
BoneyMan
Polecat, what kind of roller did you use on your tj's grille?
From TJ to WK...
BoneyMan is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
