Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 91 - JeepForum.com
 34Likes
post #1351 of 13505 Old 05-07-2010, 01:20 PM
Rynoman27
Originally Posted by mattman8706 View Post
I am going to have everything sanded and prepped in the week before so friday night I can just pull drivers seat and it will be ready.
How long does it take for a coat to dry?
I guess that would work. I would wait until the day of the coat to wash it out and then MEK it just to get all the crap out from the week.
Drying time will depend on your humidity, more humid, faster dry. I waited about 5 and a half hours on mine and it wasnt a very humid day.
'97 TJ 4" Skyjacker lift, 33" Wrangler MTR w/ Kevlar, KC's, monstalined, JKS Quicker Disconnects
Rynoman27 is offline
post #1352 of 13505 Old 05-07-2010, 01:25 PM
LuckRider
LuckRider's Avatar
MattMan, read that install thread that was posted. There is a lot of information about timing in there.
Basically, if you prep through the week and just tape and sand under the driver's seat, you could do one coat on Friday, and maybe two on Saturday (since you will have enough with 2 gallons), and put the interior back together later on Sunday (or at least the drivers seat so you can drive to work).
I did something almost stupid by putting everything back together the next day, and that caused me to chip the rear bumper (oh well.... patch worked well).
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #1353 of 13505 Old 05-07-2010, 01:35 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I am reading through the writeup right now.
This looks doable in a weekend.
-Matt
mattman8706 is offline
post #1354 of 13505 Old 05-07-2010, 01:40 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by TxFireman1972 View Post
What kinda of brush did they say to buy if you need extras?
cheap, cheap throw away
bargain basement nylon, polyester, etc (black bristle)
You can use a cheap chip brush with tan hairs but pull out all loose stuff before using
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #1355 of 13505 Old 05-07-2010, 01:44 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Everyone offered good advice.
Just get your prep/scuffing done ahead of time because that is the tiring part
Even if you cruise with driver seat only for a week.
On 1st coat, get all tough spots with brush, wait 4 to 6 hours or just overnight for 2nd coat.
If left overnight, make sure can is sealed tight. In the AM, add 4 to 6 oz MEK to remaining coating and roll 2nd coat. Pull tape right away when done.
Connect with us on:
post #1356 of 13505 Old 05-07-2010, 02:07 PM
01ClassicXJ
I am really interested in stripping the interior from my cherokee and doing this and doing the rockers while im at it but it looks like ill have to wait till july to do this.
01ClassicXJ is offline
post #1357 of 13505 Old 05-07-2010, 04:35 PM
jkl
Thinking about using monstaliner on my scrambler project. Do you think 1 gallon would cover the whole inside?
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #1358 of 13505 Old 05-07-2010, 04:46 PM
LuckRider
LuckRider's Avatar
Do a quick measure.... MagnetMan says 60 sqaure feet at 2 thick coats. It is just barely enough for a 4 door JK, and is enough for an LJ. How large is the interior of the Scrambler? I would imagine no more than 10'x5', so you should be fine with 1 gallon.
Support Our Troops!
JFI Member #7:
post #1359 of 13505 Old 05-07-2010, 10:37 PM
aerojeeptj
I finally finished my liner today, it feels good to get it over now! I also did a brief write up with pics
http://www.jeepforum.com/forum/f9/mo...0/#post9423860
aerojeeptj is offline
post #1360 of 13505 Old 05-08-2010, 07:55 AM
TxFireman1972
I was going to mist my down today....do you just mist it with a hose and leave it sit? Wipe it up? Soak it good?
TxFireman1972 is offline
post #1361 of 13505 Old 05-08-2010, 09:14 AM
LuckRider
LuckRider's Avatar
I kind of skipped that part. I probably should have done it, but whatever. I believe it is supposed to be a light misting.
Support Our Troops!
JFI Member #7:
post #1362 of 13505 Old 05-08-2010, 09:19 AM
TxFireman1972
Light misting and leave it on there?
post #1363 of 13505 Old 05-08-2010, 09:23 AM
mattman8706
2009 JK Wrangler
how much does 1 quart of chassis saver cover?
-Matt
post #1364 of 13505 Old 05-08-2010, 09:24 AM
LuckRider
LuckRider's Avatar
I would say wipe it up after a while, but I can't imagine it hurting to leave it on.
Support Our Troops!
JFI Member #7:
post #1365 of 13505 Old 05-08-2010, 09:24 AM
LuckRider
LuckRider's Avatar
Same as 1 gallon of Monstaliner.
Support Our Troops!
JFI Member #7:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
phillirl
You may not post new threads
