Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 901 - JeepForum.com
 36Likes
post #13501 of 13514 Old 08-11-2017, 08:44 AM
Supertrunk
1981 CJ7
I did under the hood hinges, door hinges, tailgate hinges, under the wiper pivots, everywhere on my CJ7 and no problems with reassembly.
Hope this helps.
Supertrunk is offline
post #13502 of 13514 Old 08-11-2017, 09:59 AM
robblue6412
1980 CJ7
Originally Posted by YJDave View Post
Not 100% sure if this is the best answer but I'm having my hinges CeraKoted flat black right now and I'm only going to do one coat of ML underneath the windshield hinge location. I'm not really worried about the hood hinge spots.
Thanks YJDave. Let me know how it turns out!
Hope this helps.
It helps Supertrunk, thanks much. I'm going to go ahead and line everything and assemble after it dries.
1980 CJ7 all original, 304, 4sp, ps, pb
robblue6412 is offline
post #13503 of 13514 Old 08-15-2017, 09:27 AM
Jeeples
Jeeples's Avatar
@magnetman
I have a small block Chevy that I'm rebuilding and sitting on my shelf is a quart size can of black Chassis Saver.
Rather than spend $30 in engine enamel, am I able to give the block a coat of Chassis Saver instead?
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #13504 of 13514 Old 08-15-2017, 11:46 AM
Bdk4life
Originally Posted by magnetman View Post
Be careful using Monstaliner in extreme heat.
Better off rolling in the early AM as soon as the sun is up.
This means your prep needs to be done at least the day before you plan to roll.
DO NOT try to prep and roll in the same day which would mean you are applying later in the day when it's hotter.
If you can't get away from the heat, delay the job for cooler temps.
Ask questions here or PM me for more tips on hot temperature applications.
Our S8 Reducer is a better alternative to MEK or Acetone for the solvent float in the open can between coats (top of Pg 5 in the install guide).
Also, a spray bottle with S8 in it can be used to spray a mist over your roller tray to prevent the coating from starting to skin over in the tray.
Do not put MEK or acetone in a spray bottle.
I live in central Florida where it stays stupid hot and humid for a long time. What do you consider extreme heat? I was wanting to coat my ride next month but we will still have 90+ degree days with humidity in 70%+ for what I am sure will be all month. What would the ideal temp be to apply the liner? Do I need to wait until October when we might sneak a chance at a few days in the 70's?
Bdk4life is offline
post #13505 of 13514 Old 08-20-2017, 11:39 AM
phillirl
I apologize if someone already asked this, but can i return unused gallons (tint, catalyst, and gallon of base)? I bought the 2 gallon kit but only used one. Can i return the unused or should i just put a third coat on the jeep?
phillirl is offline
post #13506 of 13514 Old 08-20-2017, 03:11 PM
jski701
Probably wouldn't be worth the shipping to return it, I'd use it up
Sent from my iPhone using Tapatalk
I aint saying its right, but I understand......Chris Rock
My off road trailer build - M416 copy:
jski701 is offline
post #13507 of 13514 Old 08-21-2017, 10:17 AM
AstroGuy
1976 CJ7
And I would keep it for touch ups, over the next couple of years.
On a unrelated note....Any one do any art work using this product? or even just stencil or two tone applications? tried browsing the pics...but so many are lost to photobucket or whatever it was..
AstroGuy is offline
post #13508 of 13514 Old 08-21-2017, 05:28 PM
jski701
A few pages back, Magnetman posted some pics of a great looking camo jeep, if thats what you're looking for
jski701 is offline
post #13509 of 13514 Old 08-21-2017, 05:31 PM
jski701
post 13464 page 898...... sorry not camo
AstroGuy likes this.
jski701 is offline
post #13510 of 13514 Old 08-24-2017, 08:59 PM
fauxerXJ
So I just bought my first jeep! Its in decent shapefor its age ('88 cherokee) except for the paint. I've decided to go with the desert tan option of monstaliner with some black on thebottom a few inches , but am not sure how many gallons I need, and what if any kits I need. The website is kind of confusing.
fauxerXJ is offline
post #13511 of 13514 Old 08-30-2017, 11:56 PM
Heavyopp
Just registered for the site -- Am a member of a few others but this one seems to be the authority on Monstaliner
Question -- Has anyone ever tried to coat the headliner insert of a XJ?
Prep it, clean all the cloth and foam but instead of re-lining it with cloth use monstaliner instead -- Thoughts? Pics? Comments?
Thanks, Jer
Heavyopp is offline
post #13512 of 13514 Old 08-31-2017, 07:46 PM
supereclipse
I love yalls stuff. When will the dirt bag color be put on your website? IM looking to paint my LJ in that color
supereclipse is offline
post #13513 of 13514 Old 09-01-2017, 09:41 AM
Jeeples
Jeeples's Avatar
@magnetman
Any sales for Labor Day?
Also, for those interested, Monstaliner just introduced 3 new colors on Facebook, one is a match for FDE (Flat Dark Earth), one is a match for Coyote Tan, and the third looks to be similar to Foliage Green.
Jeeples is offline
post #13514 of 13514 Old 09-05-2017, 01:43 PM
Devildog0311
want to know how much to order
I have a 95 Wrangler I am wanting to coat the inside and outside of the tub. Will be going od green for the exterior and the quartz grey for the interior, just curious as to how much I should be ordering. Looking to roll it on, was thinking 2 gallons for the outside and 2 for the inside. Does that seem about right?
Devildog0311 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
