Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 795 - JeepForum.com
 43Likes
post #11911 of 13541 Old 05-23-2014, 04:19 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by jski701 View Post
I've read through this entire thread over time and don't remember the answer to this (old age….I guess), so does Monstaliner adhere well to plywood and plastic ?? I'm considering building a project with materials I already have and know how to work with and want to know if these materials work well together.
Plastic needs adhesion promoter. What kind of plastic do you have?
http://www.monstaliner.com/documents...ng_Plastic.pdf
Raw wood needs to be sealed to avoid needing more than 2 coats of ML.
Clear oil base polyurethane like used on floors works well. Scuff when dry and put ML over it.
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11912 of 13541 Old 05-23-2014, 07:13 PM
jski701
The plastic is styrene
jski701 is offline
post #11913 of 13541 Old 05-23-2014, 11:15 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Polystyrene is much lower density than fender flare material and you may get better adhesion but this is not something we have tested.
What are you building? Is the plastic in sheets?
Connect with us on:
post #11914 of 13541 Old 05-24-2014, 12:16 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I was bored so I made some smartphone wallpapers.
#2 look great on my Galaxy S3
Connect with us on:
post #11915 of 13541 Old 05-24-2014, 12:30 PM
jawasan
I would imagine so. I can tell you for sure it sticks to tires! My goodness I got a bit on there and it does NOT just peel off! lol
Being that wood has such much texture, even when sanded fine, I can see no reason it wouldn't adhere.
http://www.jeepforum.com/forum/f22/finally-starting-yj-5-3l-bdturnkey-4l60e-novak-swap-2935953/
jawasan is offline
post #11916 of 13541 Old 05-24-2014, 08:40 PM
jski701
Yes the styrene is in flat sheets, but I'm leaning towards not using it. I want to build a new bed for my utility trailer and I'd like for it to have a military look. If I proceed, most likely I'll build it with plywood, seal it and monstaline the entire thing and then bolt it to the trailer.
jski701 is offline
post #11917 of 13541 Old 05-26-2014, 07:48 PM
Thbugman
1978 CJ7
How much would i need to line my Fiberglass CJ7 interior? Any special precautions?
Thbugman is offline
post #11918 of 13541 Old 05-27-2014, 05:09 PM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
Crap! Figures that I check out this thread on w day after the memorial day sale. Es no muy bueno.
koolaid5 is offline
post #11919 of 13541 Old 05-28-2014, 02:44 AM
scottcurry8948
still got to make mind up on exterior color.
scottcurry8948 is offline
post #11920 of 13541 Old 05-29-2014, 03:04 PM
ScooterScott
2009 JK Wrangler
Planning on doing this this summer. Can't wait to get this all ordered!
2009 Wrangler Unlimited X
ScooterScott is offline
post #11921 of 13541 Old 05-29-2014, 04:32 PM
jawasan
Same Color maybe? That looks nice man!
jawasan is offline
post #11922 of 13541 Old 05-30-2014, 12:39 PM
Billys86CJ7
Pyroclastic - Looks great!
Pyroclastic
Rolled
1 qallon, had plenty for two thick coats on floor, tailgagte, firewall, and sides by doors. Had a little extra left over, but not much.
Used rolled up balls of blue masking tape to plug all the holes.
Taped the tube drain holes from underneath with masking tape so it wouldn't drip.
Remove the masking tape right after the 2nd coat other wise it may tear the new liner.
Make sure you do it in a well ventilated area.
Prep work was the key, lots of wire wheel, sanding and MEK for final wipe down.
Start to finish about 7 hours (with prep work)
SIMPLE TO DO, LOOKS AWESOME!
Billys86CJ7 is offline
post #11923 of 13541 Old 05-30-2014, 05:55 PM
Neudiin
Originally Posted by magnetman View Post
Looking for some measurements.
Can a few people with 2 door Jeeps other than a JK please measure between door hinges like arrows in the pic. Thanks!
Post measurement here or PM is fine also
on my '98 - 9 1/8
Neudiin is offline
post #11924 of 13541 Old 06-05-2014, 12:42 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1 gallon kit for interior. If it's painted fiberglass you treat it same as painted metal, scuff and solvent clean
Raw/new fiberglass needs epoxy primer first
Connect with us on:
post #11925 of 13541 Old 06-05-2014, 12:43 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Very nice job!
Originally Posted by Billys86CJ7 View Post
Pyroclastic
Rolled
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
You may not post new threads
