Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 784 - JeepForum.com
 43Likes
post #11746 of 13541 Old 04-06-2014, 08:07 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Co0kieMoBster View Post
OK Dumb Move NUMBER 2! ****! so I got ahead of myself counting and mixing the tintable monstaliner, then scraping the sides and mixing some more.... I forgot to put the catalyst in before putting it on the frickin jeep. WHAT DO I DO NOW!!!!!!!!! mix more with the catalyst and go over it quickly before it dries?...... wipe it all off and start again, most likely running out of the Color Monstaliner that I have before done the project? OI NOT A HAPPY CAMPER RIGHT NOW! and to add insult to injury, IT STARTED POURING RAIN!
What happened with this?
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11747 of 13541 Old 04-06-2014, 12:58 PM
jlp437
This spring I'm getting into a serious rust repair/rust prevention mode on my TJ, I am a previous and happy customer with a Black Monsta interior.
My qt of Chassis Saver was in an unheated shed all winter, with temps as low as -20F. Is this now unusable?
When might the next Chassis Saver buy one get one happen, Easter?
Are any the new colors going to come close to Jeep Silver?
Also, I just requested 2 color chips online, light and med quartz gray, Thanks!
jlp437 is offline
post #11748 of 13541 Old 04-06-2014, 04:48 PM
Co0kieMoBster
put it on
So I went ahead and put on a second coat that had catalyst in it... had to leave for the weekend for hockey... just back now. Took the tape off and it seems a bit soft but I sprayed it down with a bit of water to see if that will cure it up a bit harder. If not then I guess time will tell.
Co0kieMoBster is offline
post #11749 of 13541 Old 04-06-2014, 04:49 PM
Co0kieMoBster
this is what it looks like.
post #11750 of 13541 Old 04-06-2014, 04:55 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Heat and humidity are enemies of CS and ML.
Either product stored in cold will be fine. They don't freeze. They will get thicker and will work as normal as long as material is brought to room temp for 48 hrs prior to use.
Next 2 for 1 CS sale will be Memorial Day.
Metallic ML colors will happen but I can not say when. From the work we have done so far they will likely work for spray only. There are some other tricks we are working on with silver but I can't discuss until we do more testing.
Connect with us on:
post #11751 of 13541 Old 04-06-2014, 04:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
ML without catalyst will still get hard but it will take considerably longer.
How long... I don't know for sure. Don't abuse it.
It looks really good
Connect with us on:
post #11752 of 13541 Old 04-06-2014, 08:37 PM
jlp437
Thanks for the fast response, I am still a little unsure about what colour to go with, Smurfadelic or Desert Sand are tempting as well.
If it isn't too much to ask, can I have those two colour chips included in the sample request I put in online? It was for Light and Med Quartz Gray, going to St. John's, Newfoundland.
jlp437 is offline
post #11753 of 13541 Old 04-06-2014, 09:30 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Chips added to request
Connect with us on:
post #11754 of 13541 Old 04-06-2014, 09:32 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Appx 1 week till this thread hits 1,000,000 views
Connect with us on:
post #11755 of 13541 Old 04-06-2014, 10:05 PM
jameslinn83
I am interested to see the new colors. I like road rash but would love a metallic orange as well.
jameslinn83 is offline
post #11756 of 13541 Old 04-07-2014, 09:17 AM
roughknight69
Me too holding out until I see all the new colors
Build thread
roughknight69 is offline
post #11757 of 13541 Old 04-07-2014, 05:13 PM
jlp437
Me three, at some point this spring/summer..... my exterior is getting coated in Monsta
jlp437 is offline
post #11758 of 13541 Old 04-07-2014, 08:33 PM
jawasan
Oh boy...without having to go back thru a ton of pages..... Question -
I have the Zombie Sunset and I AM POSITIVE I will be touching things up.....If I purchase a tintable quart of Zombie, are there ratios Eric, so I can mix smaller amounts at a time instead of the whole quart...or gallon, whichever. I am thinking there must be ratios for mixing a small amount? Being that there are 3 parts to mix i want to get it proper.
http://www.jeepforum.com/forum/f22/finally-starting-yj-5-3l-bdturnkey-4l60e-novak-swap-2935953/
jawasan is offline
post #11759 of 13541 Old 04-07-2014, 08:43 PM
jawasan
Nice work!
jawasan is offline
post #11760 of 13541 Old 04-08-2014, 09:04 AM
Letterman52
So applying chassis saver over a spray bomb job would turn out how do you think?
Letterman52 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
