Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 772 - JeepForum.com
 21Likes
post #11566 of 13352 Old 02-21-2014, 05:32 PM
lordryan93gt
Originally Posted by magnetman View Post
Test it out if you going to have some extra. Need to prime the bare metal
Did you purchase liner yet?
I'm sure this has been asked before. But is it ok if I just apply chassis saver to the tub first before applying monstaliner liner ? I understand I'm going to have to scuff the CS before I apply the ML. Is it ok if I go over the whole body with 80 or 120 grit DA before the CS ? Some parts of the tub is sanded to metal and most is just scuffed up stock paint.
Thank you. Its about 30° out here in Wisconsin and about 45° in my garage.. so I'm just about ready to apply CS..
lordryan93gt is offline
post #11567 of 13352 Old 02-21-2014, 06:35 PM
jeepwrangler97
Someone can correct me if I'm wrong, but you don't even need to scuff if you apply the ML soon enough after the cs is applied. I don't remember the window of time, but you can definitely do it that way. Obviously, it needs to be dry before the ML goes on though....
Iirc, I think I may have done might cs the night before & the ML the next morning.
I used cs inside my whole tub before the ML went in.
Sent by a messenger bird
jeepwrangler97 is offline
post #11568 of 13352 Old 02-22-2014, 06:17 AM
85cjrenegade
Kit ordered
85cjrenegade is offline
post #11569 of 13352 Old 02-22-2014, 08:58 AM
lordryan93gt
Alright thanks, That should save me some elbow greese. Did you apply any mek to the cs to clean it before the ml ?
post #11570 of 13352 Old 02-22-2014, 09:58 AM
Showjyr
Ordered mine yesterday...along with the free quart of Chassis Saver, some extra rollers, and the small/detail roller kit.
Hoping it works well on my tube fenders, mini boat rockers, swing out tire carrier, and grill hoop.
What's everyone using for spray can primer? Is the Rustoleum 2K good stuff?
Showjyr is offline
post #11571 of 13352 Old 02-22-2014, 10:24 AM
jeepwrangler97
That, I don't remember...but I don't think so. I think the cs would start coming up a little if you used MEK on it too soon. Maybe magnetman can verify
post #11572 of 13352 Old 02-22-2014, 12:56 PM
Blk92XJGuy
1992 XJ Cherokee
Heading out to the garage to sand since the liner is going on tomorrow!
Quick question. Hood has some hail damage. Thoughts on what to do? Heat gun? Dent puller? Or just sand and line over?
92 XJ - 7''/SeriousOffroad long arms/Bilstein 5100/Aussie/33x12.50 15x8 Kumho KL71s/plus more
98 5.9 -Monstaliner bed liner exterior - 3'' Kolak exhuast - SCT Tuner - OEM rubber cup holder insert - 52mm Holley TB - Complete audio upgrade
Blk92XJGuy is offline
post #11573 of 13352 Old 02-22-2014, 03:04 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Depends on how bad dents are and whether you want to not see it under liner.
Dent puller will make holes needing repair.
If you can get someone to help and hammer gently from under against a piece of steel against the front side you may minimize them
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11574 of 13352 Old 02-22-2014, 03:14 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If Chassis Saver is cured enough to scuff it, a light fast MEK wipe will not hurt it.
You can use mineral spirits also to wipe up the dust. Tack rag works also with no solvent.
Connect with us on:
post #11575 of 13352 Old 02-22-2014, 03:16 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks for the order
the rustoleum 2K epoxy spray will be good
Connect with us on:
post #11576 of 13352 Old 02-22-2014, 05:37 PM
Blk92XJGuy
1992 XJ Cherokee
They're actually not as bad as I thought.. Should be fine with leaving them alone.
So tell me how this looks. Was sanding it for pretty much most of the day.
Just starting out:
After:
Walked around with a flashlight looking for a reflection. Everything is taped off and ready to go for tomorrow, assuming this is the recommended finish needed for the bed liner. I just need to go over everything with a cloth or something to get all the powder off.
Started this tonight as well.
post #11577 of 13352 Old 02-22-2014, 11:48 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You're good to go on the body with that scuffing
Connect with us on:
post #11578 of 13352 Old 02-23-2014, 12:10 AM
Blk92XJGuy
1992 XJ Cherokee
Great! FWIW, we couldn't find the right pads for the orbital sander. Two different packs and they wouldn't attach to the velcro thing, so I guess there's a third type.. We bought like a 50 pack or something of 220 disc shaped sanders for it, which we ended up doing by hand. Didn't take that long with two people. Started on different sides and made a circle, then walked around with a flashlight to look for glare.
Oh and applying the liner on the bumper was easy as can be. Ventilation is key, I was right next to propped open door with wind constantly blowing in. Masks aren't ideal when you're bearded, so.. All in all though I'm loving the product and can't wait for tomorrow!
post #11579 of 13352 Old 02-23-2014, 04:49 PM
jurt
This is sprayed PYRO, more enhanced bumpiness but not rough
Do you have any full pictures of this truck? I have a 1994 chevy k1500, I am really considering monstalining my truck this summer. From what i am understanding i would need 2 gallons for my color for exterior and another gallon for my actual bed? Does this sound correct?
Thanks!
jurt is offline
post #11580 of 13352 Old 02-23-2014, 05:07 PM
Blk92XJGuy
1992 XJ Cherokee
Dat first coat.
Left it for 2 hours after I finished and the spot I started in was pretty close to dry. Didn't want to risk it since there's no rush and going back sometime next week for the second coat. This stuff is great to work with and apply. PITA to get off the skin, but it's a small price to pay haha.
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
TX-YJ
You may not post new threads
