Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 767 - JeepForum.com
 29Likes
post #11491 of 13442 Old 02-02-2014, 01:24 PM
Cuder
Originally Posted by khselwa View Post
Has anyone lined their flame red TJ with "Lady In Red?" I was going to color match my bedliner to the body but I ordered the paint chips and it looks like a pretty good match.
Yes it's a good match. It was mixed to match at Dr Eric's Lab.
My Build Thread:
Cuder is offline
post #11492 of 13442 Old 02-02-2014, 05:28 PM
khselwa
Thanks! That's awesome, can't wait to line mine!
khselwa is offline
post #11493 of 13442 Old 02-02-2014, 10:11 PM
Cuder
Look in my build thread link posted below and there are pictures of the Monstraliner that I rolled.
My Build Thread:
Cuder is offline
post #11494 of 13442 Old 02-06-2014, 08:48 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
New document download available
Purchasing and using automotive paint tints with Tintable Monstaliner
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11495 of 13442 Old 02-09-2014, 03:56 PM
Blk92XJGuy
1992 XJ Cherokee
So the weather still isn't warm enough, but I have other things that need to be done to the Jeep anyway, so I don't mind.
I was wondering if I could find out how much Monstaliner I'll have left over after putting the 2 coats on the ZJ. I have a winch bumper coming and I'd like to line it as well. I'm wondering if I should order like a quart or something for it.
Also, I'm doing black on the Jeep. How do you think a bumper lined in Pyroclastic would look?
92 XJ - 7''/SeriousOffroad long arms/Bilstein 5100/Aussie/33x12.50 15x8 Kumho KL71s/plus more
98 5.9 -Monstaliner bed liner exterior - 3'' Kolak exhuast - SCT Tuner - OEM rubber cup holder insert - 52mm Holley TB - Complete audio upgrade
Blk92XJGuy is offline
post #11496 of 13442 Old 02-09-2014, 05:29 PM
Grangler
Im sure this has been asked but i dont feel like reading 700 pages worth of comments.How many coats/gallong would I have to do to coverage outside of a tj? Could I just coat it right over my old paint? Also is it possible to ever get this off if needed?
Grangler is offline
post #11497 of 13442 Old 02-09-2014, 05:50 PM
Blk92XJGuy
1992 XJ Cherokee
Correct me if I'm wrong, but the 2 gallon kit should be enough for the TJ, since I've been told it's more than enough for an XJ/ZJ, and I'll be using the 2 gallon kit for my ZJ.
You'd need to sand off the existing paint down to bare metal for it to adhere to the body.
And I'm sure it's possible to come off. I mean with enough sanding and work I'm sure it'd come off..
post #11498 of 13442 Old 02-09-2014, 05:52 PM
roughknight69
Originally Posted by Blk92XJGuy
Correct me if I'm wrong, but the 2 gallon kit should be enough for the TJ, since I've been told it's more than enough for an XJ/ZJ, and I'll be using the 2 gallon kit for my ZJ. You'd need to sand off the existing paint down to bare metal for it to adhere to the body. And I'm sure it's possible to come off. I mean with enough sanding and work I'm sure it'd come off..
No need to take it down to bare metal just to monstaline it.
Build thread
roughknight69 is offline
post #11499 of 13442 Old 02-09-2014, 06:10 PM
rodgers3
Monsta does not like bare metal. It needs an non etching primer underneath it for best results.
rodgers3 is offline
post #11500 of 13442 Old 02-09-2014, 07:28 PM
Blk92XJGuy
1992 XJ Cherokee
Good to know!
So bare metal, non etching primer, Monstaliner?
post #11501 of 13442 Old 02-09-2014, 07:36 PM
Richard_
from what I understand , scuff up the existing paint to take off the clear coat and scuff up the paint to give it something to bond to
Richard_ is offline
post #11502 of 13442 Old 02-10-2014, 12:00 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Every exterior job varies slightly depending on who is applying. Coverage estimates for rolling is not as accurate as spraying because some people roll heavier. Also depends on what color you will be using and what color you're covering. You may get the bumper from the same 2 gals... you may not. ZJ will use more than a Wrangler. Most I have seen done used most of 2 gals if not all.
Connect with us on:
post #11503 of 13442 Old 02-10-2014, 12:02 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The normal job when existing paint is in good condition is to scuff well, solvent clean and install Monstaliner.
Never intentionally sand off existing paint unless there are problems with it peeling, cracking, badly chalking, etc. Correct surface prep is done by scuffing the existing clear coat until you generate a fine white powder off the surface. You are not removing the clear coat only busting the gloss off. In the case where you do remove the paint to bare metal, you never put ML directly to this surface so primer is needed. No self etch primers, only 2 part epoxy primer is recommended under Monstaliner.
Good to know!
Connect with us on:
post #11504 of 13442 Old 02-10-2014, 12:13 AM
Blk92XJGuy
1992 XJ Cherokee
Would you recommend I pickup an additional quart or something then, or just do a lite first coat, and a slightly heavier second coat? I'm fine with allocating the whole 2 gallon kit to the ZJ, since I've not yet decided what color I want to do to the bumper. I just don't want to run out of bed liner when I'm 90% done with the ZJ haha.
post #11505 of 13442 Old 02-10-2014, 12:23 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What color is your rig now, what color ML you doing?
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
