Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 761 - JeepForum.com
 43Likes
post #11401 of 13541 Old 01-02-2014, 01:54 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by onelow1ton View Post
Son of a b , I missed the chassis saver sale again oh well I still need a few quarts so I'll be ordering in the next day or so
Will extend this later to go through the weekend
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11402 of 13541 Old 01-02-2014, 01:59 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2 for 1 Chassis Saver Extended thru Sunday 1/05/14 at midnight
Happy New Year to All!!!
Originally Posted by magnetman View Post
Christmas to New Years Sale Starts Now!
BUY 1 GET 1 FREE CHASSIS SAVERô
Now thru Wednesday 1-01-14
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Valid thru Wednesday 1/01/14 at Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $39.90) Choose 2 of same color/finish or 2 different
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $111.75) Choose 2 of same color/finish or 2 different
To get the free item, YOU MUST PUT 2 ITEMS INTO YOUR CART FIRST AS IF YOU ARE BUYING BOTH, THEN
APPLY THE COUPON CODE AND WATCH A DISCOUNT APPEAR FOR THE FULL PRICE OF 1 OF THE ITEMS
Standard UPS shipping rates apply - $11.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
Connect with us on:
post #11403 of 13541 Old 01-02-2014, 09:01 PM
onelow1ton
1983 FSJ Wagoneer
Your the man Eric ! Ordering now , thank you sir
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
post #11404 of 13541 Old 01-05-2014, 07:49 AM
crenkz
Cold temperature impact
Magnetman,
I did my tub in tintable white when the temp was in the low 50's and probably dropped into the 40's overnight while it was drying. Will that cause it to not permanently cure or will it just take longer to cure? It's been a week and doesn't seem as hard as the black that I did previously after a week.
Also, I went a little light in some spots and would like to add another coat in several months when I do the exterior. Is it just a matter of scuffing and mek wipe down before the recoat?
Thanks
crenkz is offline
post #11405 of 13541 Old 01-05-2014, 01:35 PM
Blk92XJGuy
1992 XJ Cherokee
Originally Posted by crenkz View Post
Magnetman,
Thanks
I'd like to know about temperatures as well. I'll be doing mine in a temperature controlled garage in a few weeks in Chicago weather. It's warm enough in there to not need a jacket or anything, but I'll have to prop the door open a bit and blow the fumes outside.
92 XJ - 7''/SeriousOffroad long arms/Bilstein 5100/Aussie/33x12.50 15x8 Kumho KL71s/plus more
98 5.9 -Monstaliner bed liner exterior - 3'' Kolak exhuast - SCT Tuner - OEM rubber cup holder insert - 52mm Holley TB - Complete audio upgrade
Blk92XJGuy is offline
post #11406 of 13541 Old 01-05-2014, 09:25 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It will get harder just give it more time.
Yes on the scuff and MEK to add additional coats.
Magnetman,
Thanks
Connect with us on:
post #11407 of 13541 Old 01-05-2014, 09:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
When you're done and ready to leave the space after 2nd coat just close it up so the heat rises again and it will cure better/sooner than leaving it colder.
Connect with us on:
post #11408 of 13541 Old 01-05-2014, 11:12 PM
Shock96
In for some Chassis Saver. Then comes da Monstaliner.
Shock96 is offline
post #11409 of 13541 Old 01-05-2014, 11:29 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks for the order!
Connect with us on:
post #11410 of 13541 Old 01-05-2014, 11:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Hehe
72 in Black
Connect with us on:
post #11411 of 13541 Old 01-05-2014, 11:33 PM
Shock96
You bet! I will measure VanDOOM (my 82 E350 4x4) and see how much I will need. It's gonna be a lot...
I am thinking Envy with Desert for 2 tone. Not sure yet.
Shock96 is offline
post #11412 of 13541 Old 01-08-2014, 09:04 AM
Blk92XJGuy
1992 XJ Cherokee
Sounds good! Pay check comes in tomorrow morning, so be expecting an order tomorrow!
2 gallon kit for the ZJ, 2 coats, let it dry, right?
Thanks
post #11413 of 13541 Old 01-09-2014, 09:06 AM
Blk92XJGuy
1992 XJ Cherokee
Order placed!
http://www.shop.monstaliner.com/2-Ga...t-ML90RK2G.htm
post #11414 of 13541 Old 01-09-2014, 09:25 AM
Jpbooth
I think the Monsta has caught my ZJ.
Jpbooth is offline
post #11415 of 13541 Old 01-09-2014, 04:54 PM
Jpbooth
Magnetman. I have a quick question for you. I started rolling the tintable liner today and the humiditity has raised considerably due to rain. Is the recoat time still the same or am I looking at doing it a lot sooner?
Jpbooth is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
