Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 760 - JeepForum.com
 29Likes
post #11386 of 13469 Old 12-19-2013, 10:58 AM
98GCLimited
Originally Posted by Jpbooth View Post
Does anyone with experience rolling an entire ZJ/truck have advice on where to start rolling the monsta for best ease of application?
I did roof first so I wasnt leaning against any fresh Monsta on the sides while doing the roof.
I had the front and rear bumper covers removed and the front fenders as well.
Fenders arent necessary to remove but I had to get to a rust spot so I removed them. I would recommend removing the bumper covers so you can paint them fully but its up to you.
98GCLimited is offline
post #11387 of 13469 Old 12-19-2013, 08:30 PM
Jpbooth
Thanks everyone!
Jpbooth is offline
post #11388 of 13469 Old 12-23-2013, 10:39 AM
familyguy5
Any problems golf through car wash after lining the outside?
familyguy5 is offline
post #11389 of 13469 Old 12-23-2013, 11:58 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Golf clubs may rust in the car wash but you can run ML through there with no problem
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11390 of 13469 Old 12-23-2013, 01:11 PM
familyguy5
Damn autocorrect..
Thanks
post #11391 of 13469 Old 12-25-2013, 03:19 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Merry Christmas everyone!
Connect with us on:
post #11392 of 13469 Old 12-25-2013, 03:46 PM
Blk92XJGuy
1992 XJ Cherokee
I'll be purchasing a 2 gallon kit from you guys when you open up next year for my ZJ. I figured 2 gallons should be enough for it.. right? And with that purchase I get a gallon of chassis saver? Also I was reading the posts on the other page.. Do you guys recommend a primer? Or just bare metal?
Can't wait to make my purchase and get this on! It's going to look great!
92 XJ - 7''/SeriousOffroad long arms/Bilstein 5100/Aussie/33x12.50 15x8 Kumho KL71s/plus more
98 5.9 -Monstaliner bed liner exterior - 3'' Kolak exhuast - SCT Tuner - OEM rubber cup holder insert - 52mm Holley TB - Complete audio upgrade
Blk92XJGuy is offline
post #11393 of 13469 Old 12-25-2013, 04:27 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2 gals should be enough
Promo includes 1 free quart CS (not gallon)
ML can not go direct to bare metal, must use primer unless it's small spots involving rust where you can coarse sand (50 - 60 grit) to bare metal and use CS as a spot primer.
Connect with us on:
post #11394 of 13469 Old 12-25-2013, 04:29 PM
Jpbooth
Hey I also have a ZJ. I was told 2 gallons would be enough. And magnetman said that if it is clean bare metal to prime it with a quality automotive primer. I went ahead and bought his 2k epoxy primer. I believe that if it's heavy rust chassis saver will be fine as a primer so long as it's ruff enough for the chassis saver to stick to. What color were you planning on doing? I went with desert sand.
Jpbooth is offline
post #11395 of 13469 Old 12-25-2013, 04:50 PM
Blk92XJGuy
1992 XJ Cherokee
Oh OK. So bare metal as in what I'm sanding right? Not fresh bare metal or anything like a bumper? I was thinking of black although I'd like to see that color that's similar to gun metal on a vehicle. I was going to Plastidip my ZJ gun metal then maybe matte black after that, but I don't live in a great area and my vehicles, and others, keep getting keyed, so I decided to fix that issue lol.
post #11396 of 13469 Old 12-25-2013, 05:00 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Christmas to New Years Sale Starts Now!
BUY 1 GET 1 FREE CHASSIS SAVERô
Now thru Wednesday 1-01-14
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Valid thru Wednesday 1/01/14 at Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $39.90) Choose 2 of same color/finish or 2 different
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $111.75) Choose 2 of same color/finish or 2 different
To get the free item, YOU MUST PUT 2 ITEMS INTO YOUR CART FIRST AS IF YOU ARE BUYING BOTH, THEN
APPLY THE COUPON CODE AND WATCH A DISCOUNT APPEAR FOR THE FULL PRICE OF 1 OF THE ITEMS
Standard UPS shipping rates apply - $11.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
Connect with us on:
post #11397 of 13469 Old 12-25-2013, 06:42 PM
Blk92XJGuy
1992 XJ Cherokee
Oh OK. I'll be missing the deadline then. So I was watching a video on applying the liner with a roll on. Pretty sweet how the roller gives it that texture. Could I use a different roller for a different outcome or is that not advised?
post #11398 of 13469 Old 12-25-2013, 10:06 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Regular promo will renew after 12/31
Not advised.. We've tested every alternate roller we've found that was a possibility all with poor results
Connect with us on:
post #11399 of 13469 Old 12-27-2013, 09:20 AM
Blk92XJGuy
1992 XJ Cherokee
Oh ok good to know. Wouldn't mind the chassis saver. And that's fine. I like how it looks with the black. Can't wait to get this on!
post #11400 of 13469 Old 01-02-2014, 01:30 PM
onelow1ton
1983 FSJ Wagoneer
Son of a b , I missed the chassis saver sale again oh well I still need a few quarts so I'll be ordering in the next day or so
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
