Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 758 - JeepForum.com
 28Likes
post #11356 of 13412 Old 12-12-2013, 09:00 AM
Jpbooth
Originally Posted by magnetman View Post
Any of CS the colors can be used under ML. I do not personally recommend using the satin black on large areas under ML. Small spots are OK.
In the case of bare, clean metal... you MUST make that surface very rough or you could have adhesion issues with Chassis Saver. 50 - 60 grit sand scratching is best. No wire wheeling.
If you are gong to prime bare metal before ML (instead of using CS), use an automotive grade primer like our 2K epoxy or Universal primer. Local NAPA parts stores that sell paint will sell 2K epoxy primer in 2 quart kits.
For spray can primer, use Rustoleum "Automotive" primer available at Lowes or HD
In the spring we will have a few different spray can primers available for sale.
Ok. My next question is will there be a noticeable color difference with the desert sand monsta with the hood being primer gray and the rest of the Jeep being gold.
Thank you,
James
This is how the hood and roof look.
Jpbooth is offline
post #11357 of 13412 Old 12-12-2013, 02:28 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
There should be no difference over gray or gold. DSND covers very well
Thank you,
James
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11358 of 13412 Old 12-12-2013, 08:09 PM
Whobeme
2010 JK Wrangler
Can I apply more than 40 mils of material without any worries?
Whobeme is offline
post #11359 of 13412 Old 12-12-2013, 11:34 PM
Jpbooth
Thanks a ton for answering all my questions. I want to make sure I do this right, I don't want the Monsta to fail due to my failure of prep. I just placed an order for your 2k Epoxy Primer. I'm going to roll it on. Another question, on your site you say to dual action sand with 180-220 grit, would a random orbit sander get the job done?
Again thanks for answering all my questions!!!
Jpbooth is offline
post #11360 of 13412 Old 12-14-2013, 07:52 AM
SnowZone
Newbie
This is a bit of an odd question, but has anyone ever applied ML on/over Styrofoam, specifically medium density board (like the home insulation blue boards)? I have a project that needs a durable UV stable covering, and ML would work as long as it doesn't eat the foam!
SnowZone is offline
post #11361 of 13412 Old 12-15-2013, 12:22 PM
YoungGun
Got my rig sprayed in predator a few weeks ago and I absolutely love it. Great product.
Before:
After:
My project is about 90% done.
There is no "I" in jeep. Just a lot of money.
YoungGun is offline
post #11362 of 13412 Old 12-15-2013, 12:35 PM
98GCLimited
Looks many times better than before.
98GCLimited is offline
post #11363 of 13412 Old 12-15-2013, 12:53 PM
YoungGun
Thanks! I've been driving it around like that for almost a year lol
YoungGun is offline
post #11364 of 13412 Old 12-15-2013, 01:08 PM
lordryan93gt
has anyone used a wagner to spray monstaliner?
so I'm just wondering if I should spray or roll the ml on, I don't have a big compressor for a gun, but I do have a Wagner Control Spray Plus HVLP Low Overspray System, Model# 0518070 that is a 110v plug in, I have experience using Wagners, I sprayed plastic dip with this on a whole car, and turned out great, I'm just wondering if this is that much thicker then plastidip.
lordryan93gt is offline
post #11365 of 13412 Old 12-15-2013, 01:31 PM
YoungGun
Its pretty thick, and it thickens as you go. I'd recommend rolling it on.
YoungGun is offline
post #11366 of 13412 Old 12-15-2013, 11:30 PM
jeepwrangler97
Before:
After:
Looks much better
Build thread? I'd be interested to see the before, before pics...before the new front clip too
Sent by a messenger bird
jeepwrangler97 is offline
post #11367 of 13412 Old 12-16-2013, 09:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Wagner guns or any HVLP gun will not work with ML. Tip opening is way too small. Must use a shutz undercoat gun with compressor.
Connect with us on:
post #11368 of 13412 Old 12-16-2013, 09:36 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I suspect that the solvent in ML will start to dissolve that foam. You can seal the foam first with an industrial acrylic water base primer and it will protect the foam to use ML
If you want to do this I'll help you find a suitable primer as we don't make something like this rt now. You MAY be able to use a clear water base polyurethane sold in HD or Lowes designed for woodwork or wood floors. Will need to light scuff whatever is used before ML is put on top
Connect with us on:
post #11369 of 13412 Old 12-16-2013, 09:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You can use any small electric hand sander but be careful on corners, ridges, etc. It only takes one stroke to sand through to bare metal.
Connect with us on:
post #11370 of 13412 Old 12-17-2013, 04:49 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2013 Christmas - New Years
Vacation Notice & Shipping Schedule
Closed Friday Dec. 20th @ 4PM - Reopen Monday Dec. 30th @ 9 AM
Closed Tuesday Dec. 31st @ Noon - Reopen Thursday Jan. 2nd @ 9AM
Cutoff for new orders to ship before this weekend is 1:00 AM on Friday Dec. 20th
Monday & Tues (Dec. 30 - 31) will be light shipping days and we will not be back up to full shipping speed until Thurs - Fri (Jan 2 - 3)
Happy Holidays to ALL!!!
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
