Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 756 - JeepForum.com
 25Likes
post #11326 of 13378 Old 12-03-2013, 08:04 PM
Loomie
Originally Posted by magnetman View Post
You can paint over it but you need to scuff first if you wait long after cured
How extensive of a design?
Will it be freehand or with taping off or stencil?
Nothing to crazy. Looking to tap off a design in the center of the hood black.
Loomie is offline
post #11327 of 13378 Old 12-03-2013, 11:36 PM
bbradUSMC
I would not be concerned about this. Just place the cage back carefully when reinstalling so you don't gouge the fresh liner. Give it 2 days or more to cure before installing
That is what I was hoping to hear. Thanks
bbradUSMC is offline
post #11328 of 13378 Old 12-04-2013, 07:18 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
So how hard is it to get a vinyl decal to stick to monstaliner?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #11329 of 13378 Old 12-04-2013, 11:56 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Regular window vinyl sticks
Stretchy vinyl used for wraps seems to stick better
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11330 of 13378 Old 12-05-2013, 12:02 AM
Jpbooth
I have also been wondering the answer to this question..
Jpbooth is offline
post #11331 of 13378 Old 12-05-2013, 12:04 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
We cut these decals in-house from cast vinyl which is the stretchy stuff
Connect with us on:
post #11332 of 13378 Old 12-05-2013, 04:38 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Damn that thing looks good.
Previous:
DNFJ is offline
post #11333 of 13378 Old 12-06-2013, 09:05 AM
lynskynbnd
1987 YJ Wrangler
I have a close up of the round decal that I can post tonight
I used a light spray of glass cleaner and pressed and pressed and pressed...
It took time and patients, but they have held up well so far.
lynskynbnd is offline
post #11334 of 13378 Old 12-06-2013, 09:28 AM
familyguy5
Glass cleaner first to clean/prep the area, or glass cleaner under sticker? Want to make sure I get it right... Jeep looks great now and don't want to mess it up.
familyguy5 is offline
post #11335 of 13378 Old 12-06-2013, 09:44 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Here's what I know:
Wait at least 7 days before putting decals over ML
Wash with Dawn and hot water and let dry
Glass cleaner or Isopropyl alcohol is fine also to clean surface to remove oils from your skin
Use clean, lint free rags only to clean surface
Connect with us on:
post #11336 of 13378 Old 12-06-2013, 11:07 AM
jski701
jski701's Avatar
I work for a sign shop, we use alcohol to prep before applying decals. If its something big we use application fluid to put it down, but a squirt bottle full of water mixed with 2-3 drops (literally) of dish soap can be used too. A wet application, would require completely wetting the surface, removing the paper from the decal, wetting the glue side of the decal and lay in place. Wetting both surfaces allows you to move the decal to the correct location, then squeegee out the water from the middle out, using a felt covered squeegee. Should dry overnight...
jski701 is online now
post #11337 of 13378 Old 12-06-2013, 11:11 AM
lynskynbnd
1987 YJ Wrangler
-Both-
I always use glass cleaner when applying decals. Once it drys the decal will stick the same as if you did not use it. The advantage is being able to move the decal around to get the perfect positioning and it makes it very easy to get bubbles out with out using a pin to pop them. A clean surface is also very important.
post #11338 of 13378 Old 12-07-2013, 11:24 AM
lynskynbnd
1987 YJ Wrangler
post #11339 of 13378 Old 12-09-2013, 02:20 PM
lordryan93gt
Kerosene heater
I'm in a little bit of a predicament here it's about 15 degrees in Wisconsin and im waiting to apply monster liner on the floor of the Jeep but I know the instructions say it has to be at least 50 degrees my garage gets about 45 degrees with my kerosene heater on so I was wondering if the chemicals in the monster liner would do damage from the kerosene heater. thanks
lordryan93gt is offline
post #11340 of 13378 Old 12-09-2013, 02:31 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I think I'd be more concerned about the heater doing damage to you and your house if you burn yourself up
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
