Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 755 - JeepForum.com
 43Likes
post #11311 of 13541 Old 11-30-2013, 11:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by JeepComanche89 View Post
Looking to put on another coat of monstaliner on my bed. Washed it real good, gonns scuff it up with a pad, then acetone. Does that sound good or is there any special procedure for coating cured ml. Thanks
This is correct. Scuff till you generate some white dust. Don't smooth out texture. Flexible scuff pad is best as it will conform to surface.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11312 of 13541 Old 11-30-2013, 11:12 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by helmetface View Post
Hey Eric, what are your suggestions for getting sap off monstaliner? I had a good sized drop on my hood..tried taking it off with various alcohols and degreasers- to no avail.
Now it's cooked onto the hood and ugly as sin..probably too far gone at this point..but for future reference?
Did you try nail polish remover or acetone?
Connect with us on:
post #11313 of 13541 Old 11-30-2013, 11:13 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by familyguy5 View Post
Can you send me the mix ratios by weight for the liner mixed with the tint?
Sorry for delay
Will post this later today
Connect with us on:
post #11314 of 13541 Old 11-30-2013, 05:37 PM
eduardostewart
Originally Posted by magnetman View Post
Cold storage does not affect CS.
People have kept partial cans in refrig to preserve it. Just make sure material is at room temp for minimum 24 hrs before use
thanks eric, just got in my order!
eduardostewart is offline
post #11315 of 13541 Old 12-01-2013, 07:00 AM
Jpbooth
Very excited!! Just ordered desert sand 2 gallon kit. Can't wait to get it!
Jpbooth is offline
post #11316 of 13541 Old 12-01-2013, 05:07 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Mix ratios by weight
Connect with us on:
post #11317 of 13541 Old 12-02-2013, 04:09 PM
helmetface
Both. The nail polish remover ended up smearing brown swil marks as wide as my scrubbing area..probably 1ft.
helmetface is offline
post #11318 of 13541 Old 12-02-2013, 04:36 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Think I asked this once before...
Can you show me what that stuff is that you got on there?
Connect with us on:
post #11319 of 13541 Old 12-02-2013, 07:17 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
helmetface
I confused you with someone else.
For tree sap... have you tried regular mineral spirits?
Don't wipe it around immediately, just soak a piece of rag and hold it on the sap spot for a few mins, then see if it softens and dissolves
Connect with us on:
post #11320 of 13541 Old 12-03-2013, 02:51 AM
bbradUSMC
He magnetman,
I would like to remove my roll cage when I go to apply ML to the tub of my TJ so that I don't have to cut up the ML if I ever need to remove the cage in the future. Should I be worried about reinstalling the cage back on top of the ML? I am worried about cracking or tearing the ML at the edges of the cage base.
bbradUSMC is offline
post #11321 of 13541 Old 12-03-2013, 03:13 PM
lunchbox101
Question regarding the Chassis Saver. I put down one coat in the high touch areas. No problems with rust here. I am going to save the majority of the can for the undercarriage.
However, I installed the Chassis Saver approx. 10 hours ago. Temps here are cold, and it feels sticky to the touch. It does not rub off. Can I install MonstaLiner over it, or should I sand the Chassis Saver? Thanks.
lunchbox101 is offline
post #11322 of 13541 Old 12-03-2013, 03:51 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Coat it now with ML if you can to avoid having to scuff if you let it cure hard.
You still have up to 24 hrs to do this without scuffing
Connect with us on:
post #11323 of 13541 Old 12-03-2013, 06:04 PM
Loomie
is it possible to paint on top of monstaliner?
I'm looking to add a design, after I paint the body.
Loomie is offline
post #11324 of 13541 Old 12-03-2013, 07:51 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by bbradUSMC View Post
He magnetman,
I would not be concerned about this. Just place the cage back carefully when reinstalling so you don't gouge the fresh liner. Give it 2 days or more to cure before installing
Connect with us on:
post #11325 of 13541 Old 12-03-2013, 07:55 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You can paint over it but you need to scuff first if you wait long after cured
How extensive of a design?
Will it be freehand or with taping off or stencil?
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
