Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 753 - JeepForum.com
 32Likes
post #11281 of 13493 Old 11-12-2013, 07:57 AM
DNFJ
Originally Posted by magnetman View Post
Will def do something. Should be about 4 months for another 125K views which will coincide with our escape from NY
Haven't checked in in awhile, where you guys moving to?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #11282 of 13493 Old 11-12-2013, 08:41 AM
spk454
1983 CJ8
questions.
Considering monstaliner for my inner fenders (steel, epoxy primed) and tub (fiberglas). I want to put down lizard skin first as sound insulation. Can monstaliner go over that? If the epoxy is cured do I need to scuff to apply the liner? Will it be resistant to chips or should I put undercoating over it in the fenders for sound/chip protection?
Thanks in advance. Also how much would you recommend for the inside of a scrambler tub, firewall and both inner fenders?
spk454 is offline
post #11283 of 13493 Old 11-12-2013, 08:54 AM
eduardostewart
w00t
eduardostewart is offline
post #11284 of 13493 Old 11-12-2013, 09:10 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Cullman, AL
Waiting on 700 yds concrete
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is online now
post #11285 of 13493 Old 11-12-2013, 09:13 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Let the Liz Skin cure 3 days, very light scuff, clean with mineral spirits and let dry thoroughly then put ML
Most 2 part epoxy primers must be scuffed if fully cured before recoating
Undercoat is not required but can go over ML in the wells if it makes you feel better
Connect with us on:
post #11286 of 13493 Old 11-12-2013, 11:01 AM
spk454
1983 CJ8
so quick scuff with scotch brites? 320 grit? can the epoxy be cleaned with a PRE paint prep or mineral spirits as well? how much monstaliner should I get? thanks, sorry so many questions, painting newbie...
spk454 is offline
post #11287 of 13493 Old 11-12-2013, 01:05 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
GOOB just ask what you want to know
I will be putting in a new floorpan on 1 side. some parts of tub will have chassis saver/por15. Im just wondering about prepwork before application.
prime the new steel, sand and apply? and over the existing paint, just sand, clean and apply? See these questions are mundane thats why I was looking for faq.
also will be swapping roll bar when I do this and wondering if I should line before i put it in, will the thickness throw off the bar to the tub alignment
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #11288 of 13493 Old 11-12-2013, 07:05 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
320 is prob too fine. I would go gently with 180 grit or use the brown pads supplied with the ML kits. Extras pads are also available in the ML shop cart.
Min spirits is fine after scuffing the epoxy just let it evap for a few hrs before coating over it.
Tub needs 1 gal but I'm not sure of the footage on the firewall and fender surfaces. Qt does 15 sq ft / gal does 60 sq ft
I would do some measurements
Connect with us on:
post #11289 of 13493 Old 11-13-2013, 08:07 PM
cole_slaww
I am interesting in ordering Monstaliner for for 02 wrangler. It is patriot blue currently and I am torn between white and ww11. Do you think that if i do white I am going to have to go with a primer first? Also, are you doing any deals for the holidays coming up?? Thanks
cole_slaww is offline
post #11290 of 13493 Old 11-13-2013, 09:42 PM
vortechYJ
My Predator kit just arrived, once my flat fenders arrive the work will begin. Ill post pics once its started. Predator on the exterior and black on the flares.
vortechYJ is offline
post #11291 of 13493 Old 11-14-2013, 01:01 PM
Sparrows
Make sure you share a lot of pics. I'm contimplating the same scheme!
Cheers
June '13 YJOTM
Sparrows is offline
post #11292 of 13493 Old 11-18-2013, 08:18 AM
familyguy5
Can you send me the mix ratios by weight for the liner mixed with the tint?
familyguy5 is offline
post #11293 of 13493 Old 11-18-2013, 04:05 PM
helmetface
Hey Eric, what are your suggestions for getting sap off monstaliner? I had a good sized drop on my hood..tried taking it off with various alcohols and degreasers- to no avail.
Now it's cooked onto the hood and ugly as sin..probably too far gone at this point..but for future reference?
helmetface is offline
post #11294 of 13493 Old 11-20-2013, 11:03 AM
burnswhenip
2010 JK Wrangler
Got my kit in today. Opened it up to find no catalyst. Gave them a call and was told they will look into it. Guess it will be a while before they figure out why they didnt send me the cataylst. Was really looking forward to installing it this week. Guess I will be unprepping the Jeep. I wonder if this is a sign that I should return everything and try something else
burnswhenip is offline
post #11295 of 13493 Old 11-20-2013, 08:02 PM
helmetface
Don't be a drama queen. They are a company and like any other company they are subject to ****ing up here and there.
You know what, go ahead and return it and buy some raptor liner and enjoy it falling apart. Monstaliner is for the non*****.
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
