Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 741 - JeepForum.com
 21Likes
post #11101 of 13352 Old 09-05-2013, 06:00 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by bigman7878 View Post
I'll be ordering Apocalypse tomorrow but before I do...I have some small patches of surface rust on my rockers. I'm guessing I could use the "Repair Kit *BLACK* 8 Ounce" to sand and repair the area before applying the Monstaliner? If not, what do you recommend to sand and primer the area?
Monstaliner repair material is only used to fix or patch an existing ML installation and you never want to put ML direct over rust or bare metal.
I would coarse sand (50 grit) those spots to the bare metal and use Chassis Saver as a primer. Let that cure, scuff surface and put ML over the CS.
Alternate primer would be a spray can of Rustoleum automotive primer after same coarse sanding to bare metal.
Got to be careful with rockers. I've seen too many problems with blisters coming up after coating or rust coming back through so you're best off removing it completely first.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11102 of 13352 Old 09-05-2013, 06:32 PM
bigman7878
Will do. Thanks. Excited to get this put together!
bigman7878 is offline
post #11103 of 13352 Old 09-05-2013, 07:05 PM
jlp437
Got my Monstaliner and CS yesterday.
Just put a coat of CS down on the floor of the jeep. Seems to be great stuff and has awesome coverage even on rust.
100% humidity here and 70 degrees so it should dry pretty hard and fast too
jlp437 is offline
post #11104 of 13352 Old 09-05-2013, 07:12 PM
BRODY881975
Quick question. For the hard to reach places when sanding, can I just spray some etching primer on them before I apply the magnapoxy?
BRODY881975 is offline
post #11105 of 13352 Old 09-05-2013, 08:17 PM
MARIN3RMAN
1994 ZJ
How long do I have once Monstaliner is opened before it goes bad? I plan on doing my jeep soon and my dads truck bed later on down the road if possible.
Hunter
94 ZJ
MARIN3RMAN is offline
post #11106 of 13352 Old 09-05-2013, 08:46 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Nooo, etch primer does not work well under ML
Are these areas bare metal or with paint?
Connect with us on:
post #11107 of 13352 Old 09-05-2013, 08:48 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's a 2 part product. You mix the catalyst and you have 6 - 8 hrs to complete your job
Connect with us on:
post #11108 of 13352 Old 09-05-2013, 09:22 PM
MARIN3RMAN
1994 ZJ
Ok thanks. For some reason I thought only the colors had two parts and the black was just one. Dumb me haha
Hunter
94 ZJ
post #11109 of 13352 Old 09-05-2013, 09:37 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Colors are 3 parts, liner + catalyst + color
Black is 2 parts, liner + catalyst
Connect with us on:
post #11110 of 13352 Old 09-05-2013, 10:24 PM
BRODY881975
It's bare aluminum right now. I'm shooting your magnapoxy over the aluminum then the ML over the magnapoxy. So your saying etching primer would not be good under the magnapoxy?
post #11111 of 13352 Old 09-05-2013, 10:54 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's bare aluminum right now. I'm shooting your magnapoxy over the aluminum. So your saying etching primer would not be good under the magnapoxy?
That is correct
Epoxy primer has the best adhesion of anything to bare steel and aluminum so using self etch under it is a waste of time and will be a weaker bond.
Connect with us on:
post #11112 of 13352 Old 09-06-2013, 06:58 AM
BRODY881975
That is correct
So what can I do for the hard to reach places, scuffing up wise? Will it be okay if I can't scuff it?
Sorry for the dumb questions man. I'm learning.
post #11113 of 13352 Old 09-06-2013, 07:08 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
What are you coating?
How hard to reach are these areas?
There's no dumb Qs that's what this thread is for
Connect with us on:
post #11114 of 13352 Old 09-06-2013, 07:10 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I take that back, there are dumb Qs sometimes
Connect with us on:
post #11115 of 13352 Old 09-06-2013, 07:34 AM
BRODY881975
The aluminum is the tub. Hard to reach areas are like up in cracks. They'll be noticed to the eye but probably not gonna see any touching of feet, hands and what not. The doors and hood are bare steel. I will need a little filler work done on them if that is okay before the epoxy. My front fenders are primed already but I've had to do mods to them so there's bare steel in spots. Those I can take down to bare steel if need be before shooting the epoxy.
I feel these are dumb questions lol. I'm anal as all get out man and I want this to be perfect and done once. Thanks for answering all this.
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
