Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 735 - JeepForum.com
 34Likes
post #11011 of 13506 Old 08-22-2013, 04:00 PM
Hoovw
When doing plastics and primer should we do adhesion promoter then primer then ML in that order?
Hoovw is offline
post #11012 of 13506 Old 08-22-2013, 08:23 PM
helmetface
Hey magnetman, just echoing a previous question: can you spray paint over monstaliner without adverse effects?
I was thinking of giving it a week to cure and then wiping with MEK followed by some small pinstriping.
helmetface is offline
post #11013 of 13506 Old 08-23-2013, 02:37 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by drespecki View Post
What is the best liquid metal? Permatex or the JB Weld steel stik?
http://www.amazon.com/Weld-8267-S-St...d+metal+filler
Eric, will there be any ill effect of Monstaliner on any of these liquid/epoxy hole fillers?
ML should be fine over epoxy filler. You could also use paintable seam sealer to fill small holes
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #11014 of 13506 Old 08-23-2013, 02:40 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Painting over ML is fine. I would usually recommend light scuffing but for pinstriping this may not be feasible.
Going over black or color ML?
Connect with us on:
post #11015 of 13506 Old 08-23-2013, 02:41 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Read the directions on the adhesion promoter you have. I don't think primer is needed
Connect with us on:
post #11016 of 13506 Old 08-23-2013, 02:44 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Hey magnetman, you mentioned we could thin with MEK instead of the S8 reducer, right?
For spraying that is.
S8 reducer is not generally used to thin ML for spray. MEK is the standard recommendation because it flashes off much faster
Note: S8 is compatible with ML and I would reserve it's use mainly for rolling applications if thinner was needed
Connect with us on:
post #11017 of 13506 Old 08-23-2013, 02:48 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
11k/800k
Connect with us on:
post #11018 of 13506 Old 08-23-2013, 03:03 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Connect with us on:
post #11019 of 13506 Old 08-23-2013, 06:13 AM
helmetface
Going over pyroclastic with some black spray paint.
Thanks for all the answers bud.
post #11020 of 13506 Old 08-23-2013, 08:50 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I've never tried painting over tintable ML
Considering the recoat window for recoating itself I would definitely scuff for painting over to make sure it sticks
Connect with us on:
post #11021 of 13506 Old 08-23-2013, 02:20 PM
YoungGun
Have a few questions...
I am going to be painting my jeep here soon. and I'm really considering monstaliner. I am going to be doing it myself, I have very limited automotive painting experience. But which would you recommend? I would roll it on but I am very concerned about runs and brush strokes in the tighter area. My OCD would go nuts if I could not have a uniform texture. How much paint would it take to paint a whole tj wrangler? How many coats do you recommend? I'm painting over red and black paint with one of your shades of yellow. And I heard from another bedliner company that yellow is the hardest to paint with because it shows paint underneath.
So here are my questions:
Spray vs. Rolled?
How much paint?
How many coats of yellow?
How much time should I allow for painting?
There is no "I" in jeep. Just a lot of money.
YoungGun is offline
post #11022 of 13506 Old 08-23-2013, 06:04 PM
Copperhead89
Hey magnetman,
I'm building this center console, and I want to cover the particle board parts with Pyroclastic Monsta. Is there any coating or paint I should apply before rolling on the Monsta? Will the Monsta make the particle board water resistant? If not, I was thinking of applying 2 coats of marine grade polyurethane before the Monsta. Your thoughts/recommendations?
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #11023 of 13506 Old 08-24-2013, 07:20 PM
Therios
I would like some parts of my garage to match my jeep. I think that would be cool! Do you know how this stuff would hold up compared to epoxy floor finish? I would love to roll this stuff down. Would make a pretty cool driveway as well other than it can be slick as heck when wet.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #11024 of 13506 Old 08-24-2013, 07:39 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by Copperhead89 View Post
Hey magnetman,
Sorry for the delay, I know you posted this before
Yes, 2 coats of a clear wood varnish/polyurethane will work well. Just scuff and solvent clean after last coat is cured and roll ML
Also, 1 coat of silver chassis saver does and awesome job sealing wood, scuff and clean same as w/varnish
Connect with us on:
post #11025 of 13506 Old 08-24-2013, 07:41 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I've had this Q before but never tested it on concrete
I forgot, What color are you doing jeep?
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
