Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Liner - Page 734 - JeepForum.com
 34Likes
post #10996 of 13504 Old 08-20-2013, 09:37 AM
bobthecatkiller
Originally Posted by eduardostewart
you guys have just been taping around the windshield? these pics are looking very clean, i'd swear some of you had ripped out the seal around the windows and then reinstalled after you monstalined.
i have a tj: what have you (the public) been doing about the random bolts...tailgate, windshield frame, door hinges? removing or just going over them? I plan to take off the taillights, flares, soft top - what about the hood latches?
I did rip out my windshield on my xj to paint.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #10997 of 13504 Old 08-20-2013, 06:09 PM
Copperhead89
Hey Eric, I'm building this center console, and I want to cover the particle board parts with Pyroclastic Monsta. Is there any coating or paint I should apply before rolling on the Monsta? Will the Monsta make the particle board water resistant? If not, I was thinking of applying 2 coats of marine grade polyurethane before the Monsta. Your thoughts/recommendations?
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #10998 of 13504 Old 08-20-2013, 09:10 PM
drespecki
1983 CJ7
I have been reading till my eyes have crossed, but what does one do with the large drain holes (I have a CJ7 with several in the front and a few in back bed area) I am good with the bolt holes, etc..
Also, is it good to remove all the earplugs, bolts, etc. before Monstaliner dries or wait for it to cure? I cannot find the answer..
It only hurts while you're breathing..
drespecki is offline
post #10999 of 13504 Old 08-21-2013, 05:58 AM
Loomie
almost got all my carpet tore out....
I have to grind out the bolts under the back seat to get the last bit out. Also It looks like I'll have to fix a few rust spots that are to far along. I'll know more after take a wire brush to the tub and get a chance to vacuum it out.
Loomie is offline
post #11000 of 13504 Old 08-21-2013, 06:08 AM
jeep63
jeep63's Avatar
When I did my YJ, pretty much identical drain holes, I left them open. I am getting plugs for them for the winter, but I did nothing special when I rolled the Monsta.
I removed all the earplugs, bolts, tape, etc.. just after the second coat was down.
jeep63 is offline
post #11001 of 13504 Old 08-21-2013, 08:06 AM
Therios
If you don't remove before cured, you will have a tough time. You will have to cut it out. The beauty of ML is how toughie is and it will be tough to get anything off/out when cured. Just treat it like anything else you paint. Do it and then remove it. It is not going to flow around.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #11002 of 13504 Old 08-21-2013, 08:15 AM
helmetface
Hey magnetman, you mentioned we could thin with MEK instead of the S8 reducer, right?
For spraying that is.
helmetface is offline
post #11003 of 13504 Old 08-21-2013, 09:13 AM
drespecki
1983 CJ7
Would cardboard rolls or something like a tapered cotton candy paper holder work in those big holes or would it be best to let the ML ooze over and coat the edges of the hole? Will it make the plastic plugs too snug to fit?
Thanks...!!
Cotton candy cones:
http://www.amazon.com/Cotton-Candy-E.../dp/B004X631G2
post #11004 of 13504 Old 08-21-2013, 09:31 AM
jeep63
jeep63's Avatar
Thanks...!!
Cotton candy cones:
I suppose it will not hurt to use the cotton candy cones (never thought about those; good idea).
I may find the plugs do not fit now that I let the edges build up with ML.
I'll know come November!
good luck.
jeep63 is offline
post #11005 of 13504 Old 08-21-2013, 10:32 AM
lynskynbnd
1987 YJ Wrangler
good luck.
I sprayed my interior and the plugs fit fine.
lynskynbnd is offline
post #11006 of 13504 Old 08-21-2013, 11:03 AM
drespecki
1983 CJ7
Is there a good source for the good fitting, drain hole plugs? ALSO, I have about 16 random screw holes from odd stuff mounted over the years... What is the best way to fill them prior to going over everything with the Monstaliner?
post #11007 of 13504 Old 08-21-2013, 01:38 PM
ktw23
I was wondering the same thing. Wasn't sure if using a filler would be ok
2002 TJ 4.0, 4" Pro Comp on 33x12.50's 3.73's D30 & D44 - Daily Driver
1995 YJ 4.0, 4" Rough Country on 33x12.50's 3.07's D30 & D35 - SOLD
1994 ZJ 5.9 Laredo - SOLD
Just Empty Every Pocket
ktw23 is offline
post #11008 of 13504 Old 08-21-2013, 02:11 PM
drespecki
1983 CJ7
What is the best liquid metal? Permatex or the JB Weld steel stik?
http://www.amazon.com/Weld-8267-S-St...d+metal+filler
Eric, will there be any ill effect of Monstaliner on any of these liquid/epoxy hole fillers?
post #11009 of 13504 Old 08-21-2013, 09:43 PM
jlp437
Woohoo, ordered my kit yesterday. Jon P in Canada.
Cant wait to get it in the tub for the Winter coming soon here in Newfoundland.
Great service too btw Eric.
jlp437 is offline
post #11010 of 13504 Old 08-22-2013, 02:04 AM
bobthecatkiller
Rubber expansion plugs from any plumbing section in a hardware store.
That's what I used for the "drain plug" holes in my xj.
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
