Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 725 - JeepForum.com
 29Likes
post #10861 of 13469 Old 07-24-2013, 01:06 PM
phil8825
Originally Posted by Therios
I had the same issue with my rollbars. I "thought" that I would be oh so awesome at getting around them. Not! Now I have ordered a Quart of touch up so that when I stop being lazy and remove the 10 bolts or so to get the rollbar out. Anything that is removable, do so. Trust me here! I know this is lays recommended but with monstaliner you will have a far better time if there is no obstruction and you can be consistent.
No one will ever really see the back side of your bumpers. But you will. Take the extra 30 minutes to unbolt hem and do them in an easy place to get to them. You really will be happier with the process and you will have perfect coverage and you will never have a regret. If you don't, you will be planning every weekend over the next year on removing the tubes and doing a touch up because you see the pots every day.
Also, don't sweat the first coat. When I rolled mine on I could not handle the few little peak through spots that were thin. He second coat will get them. Don't overwork the first coat. Just get it on complete and even. Spend the time on getting a good smooth base and final coat and let the overage work itself out.
On my window mounted guard and lightbar, I used etching priner, followed by chassis saver, and when I get the rollbar out in the next few weeks, the new bumper, plastic fenders, lightbars, will all get the black ML.
I learned from experience by cutting corners and taking the apparent quick and easy method. Now I have to do touch ups and twice the work. Not worth it at all.
Just my two cents. Hope it helps someone.
Oh ya, and the most important things. Read my post on what I learned. Also just do it. Stop wondering and being timid. Spend the 6 bucks, order the samples and just do it. If you wanna see how it works then buy a quart of black and do your bumpers. MEK and/or its substitute works just fine. Do all of it in two sessions. It won't save for another project. It will skin over in an hour or two and you can touch the thick parts and actually feel the soft parts as they cure. I put an old piece of carper padding down and drove it after 24 hours but really babied it. Upside down carpeting did not get removed until the week was over. Now I don't have stupid carpet and drain the pan when needed and never worry about it any more. Wish that I could encapsulate the entire dash and make it all waterproof.
Good point on taking everything off. That is the plan. I have my side steps off and am prepping those now. Doing all the prep and then ordering the stuff. I know if I order it now Ill grow way to impatient and rush to put it on and see what it looks like.
I read that ML does not adhere very well on bare metal. My question is I have some small bare spots here and there after sanding the sidestep
Spot prime?
Some are. Super small and a few others a little bigger, maybe an
Inch or two in length and a 1/4 wide
phil8825 is offline
post #10862 of 13469 Old 07-24-2013, 02:57 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Find this at HD or Lowes for the bare spots you refer to
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10863 of 13469 Old 07-24-2013, 03:10 PM
phil8825
Thank you for the info.
Just out of curiosity would that be an acceptable primer for prepping an entire bare metal surface area or rather just bare spots
phil8825 is offline
post #10864 of 13469 Old 07-24-2013, 04:12 PM
Therios
Autozone has this. It worked great for ma as I had the same issue.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #10865 of 13469 Old 07-24-2013, 08:49 PM
Riley8807
So I'm new to this thread and to Monstaliner , it says won't chalk and is guaranteed for 5 years. What happens down the road at 7-10 years or longer? If I spend the money and do roll my entire jeep, I want to know what I'm getting into in the future.
Riley8807 is offline
post #10866 of 13469 Old 07-25-2013, 02:58 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Welcome Riley8807
We do offer a 10 year guarantee.
The 2nd 5 years costs double what you spend now on Monstaliner and then if you have a problem after 5 years we give you a free materials to re-do it. It's called "MONSTASURANCE"
Seriously... purchase a new car and maybe you get a 5 year paint guarantee, more likely 3 yrs. (with all sorts of disclaimers)
We tested ML and determined that 5 years was reasonable because we know it's UV stable.
We have no control over prep, application or what you do with your vehicle after you install Monstaliner.
Monstaliner is no different than automotive paint when it comes to appearance.
If you disregard doing anything to maintain it you can forget about it looking good in 5 years.
Treat your investment like you would the paint on a car and it will still look good in 5 years.
Washing it regularly, etc. Not scrubbing it when it's muddy and sandy. Armorall, spray wax, etc will keep it looking fresh.
So basically.. what you're getting in the future is what you put into it along the way to keep it looking good.
Connect with us on:
post #10867 of 13469 Old 07-25-2013, 03:04 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I've always advised against self etch primers only because I've seen and heard of too many adhesion issues. This is not to say they don't work.. but for the same effort a regular primer will work more universally and not cause any issues
These products are not like they used to be. Old school self etch was 2 component with much higher phosphoric acid content. The new rattle can self etchers are a short cut in my opinion to capture DIY market share
Connect with us on:
post #10868 of 13469 Old 07-25-2013, 01:53 PM
Therios
Thanks for the clarification.
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10869 of 13469 Old 07-26-2013, 01:12 PM
Loomie
I plan on going with black for my tub and either white or od green for my body. I know I need the chassis saver for the rust spots on both tub and body. On top of that I want to do the frame to help protect from the upstate ny winters. I was planning on going with the gloss black.
2 questions....
1. Is their any issues with the white or od green completely hiding the chassis saver?
2. This for me is a multi stage project. Once I pop the chassis saver, how long is it good for. I'm guessing with $$$ constraints its going to take 1.5-2 months to finish.
Loomie is offline
post #10870 of 13469 Old 07-26-2013, 07:40 PM
eduardostewart
2 questions....
hi bud, now i havent cracked open my CS ir ML so take this with a grain of salt, but bought 4-1qt empty paint cans from home depot (~$3 a piece). a friend told me this and i believe i saw it on here as well... cup the CS as opposed to pouring so it doesnt clog the rim/lip of the can into the little quarts. top them off with some mek so it doesnt harden or form a skin on top. place some plastic or maybe grocery bag down the top and smack the lid on.
if im wrong please somebody correct me. i can understand the precaution because of $$$
eduardostewart is offline
post #10871 of 13469 Old 07-26-2013, 07:45 PM
DezertTJ
I've been interested in this, but what happens after it fades a longtime from now? Basically just sand it all off and put new liner on?
DezertTJ is offline
post #10872 of 13469 Old 07-26-2013, 08:16 PM
Therios
If and when it happens, I assume it will be similar to the stupid rhino in my old truck. I just had to re-line it every two years. Successive coats went further than did the initial. I am really hoping that this stuff lasts far longer b
I have only had it in my tub for a month now and I am WAY happy with what I have. I can already tell it is a far superior product. Just getting ready to begin reassembly of my 69 beetle that will be fully cs and ML.
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10873 of 13469 Old 07-27-2013, 01:41 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Go with the silver CS and covering with the white is no issue, ODG is never an issue with black CS
Read this on handling CS
http://www.magnetpaints.com/MSDS-TECH/TDS_UCP99.pdf
2 questions....
Connect with us on:
post #10874 of 13469 Old 07-27-2013, 01:43 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This is exactly right, tin foil works also
Connect with us on:
post #10875 of 13469 Old 07-27-2013, 02:03 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
ML is made from all UV stable components, it won't fade from sun exposure
Mud, dirt and sand are abrasives. These are what can dull any surface. If you clean your jeep regularly and even use some Armor All or liquid wipe on wax you will protect against the effects of abrasion.
ML can be scuffed and recoated at any time. If you use waxes on the surface you would need to do a thorough solvent removal of the wax before scuffing to recoat
Connect with us on:
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
