Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 719 - JeepForum.com
 36Likes
post #10771 of 13514 Old 07-12-2013, 12:35 PM
Jakemcshibby
I cant find mek anywhere (in canada) or an mek substitue. but I found liquid hardner which is MEKP (methyl ethyl keytone peroxide) im going to use it to thin monstaliner to spray it. and what type of primer should I use over bare metal?
Jakemcshibby is offline
post #10772 of 13514 Old 07-12-2013, 12:45 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
DO NOT add that to Monstaliner
Get acetone!
Find a rustoleum oil base metal primer or equivalent in quarts (no spray cans)
let it dry 2 days befor putting ML over it
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10773 of 13514 Old 07-12-2013, 01:54 PM
Jakemcshibby
Get acetone!
I dont think you could make that any clearer. thanks for the warning, will it explode or something? lol or just thicken really badly?
can I speed up the primer drying process at all? I was planning on monstalining tomorrow.
post #10774 of 13514 Old 07-12-2013, 02:06 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
MEKP is fiberglass resin catalyst. It is not a solvent for thinning.
Really not sure what it would do.. could create a 5 minute pot life with ML giving you a nice paper weight
How much sq footage are you needing to prime?
Connect with us on:
post #10775 of 13514 Old 07-12-2013, 02:11 PM
Jakemcshibby
TJ drivers side floor pan and that should be about it. so less than 2sqft
post #10776 of 13514 Old 07-12-2013, 02:20 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Home Depot or Lowes should sell this which is fine for what you describe and it will dry fast. Spray 2 coats and check directions for how fast they say you can topcoat it
Connect with us on:
post #10777 of 13514 Old 07-12-2013, 04:29 PM
HDWrangler
A couple questions.
I am painting the hood on my 94 YJ Acopolypse and then the hood bulge in black. With the texture of the ML will I be able to get a decent tape line, or will the black bleed under the tape? I plan to use 3M fine line tape. How long does the 'base coat' need to set up before I can apply tape to it?
I will need to prime a few small spots of bare metal. Through my work I have available SEM 42000 series aerosol primers. They are a High Build Primer Surfacer. It is not an etching primer. Will it work okay??
HDWrangler is offline
post #10778 of 13514 Old 07-13-2013, 02:21 PM
mike_breaker_5
as far as the tape line goes...
i was able to get a decent tape line to do my stencils over the ML. it took me a few tries to get it right but if all you are doing is taping b/n colors i would say that a good painters tape and plenty of rubbing to get it to stick properly would leave you with a good clean line, maybe someone who has actually used tape can chime in with any methods they used.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #10779 of 13514 Old 07-13-2013, 03:51 PM
DodgerFan98
Hey guys, I was wondering if anyone with the Moss Green painted jeep had done the inside of their tub with Monstaliner Jungle Love color. I am kind of going back and forth a little between that and black. Or perhaps a camel color to match my dash..but im not thinking that would look all that great. Just wondering how well the colors match up..Maybe some pictures if you have them?? Thanks
DodgerFan98 is offline
post #10780 of 13514 Old 07-13-2013, 04:05 PM
roughknight69
What about brown eyed girl? Would compliment the driftwood interior and the moss green paint.
Build thread
roughknight69 is offline
post #10781 of 13514 Old 07-13-2013, 04:20 PM
DodgerFan98
Thats an idea..Although probably pushing into being a few to many colors on my jeep lol..I actually am currently trying to find out what company makes a good interior paint for my dash and everything. When I bought the jeep it was already a little faded and old looking everywhere and I just recently replace my half doors with full hard doors..managed to find them in the same color paint also..score. Problem is the doors interior is a different tan then the rest of my interior..So along with monstalining my tub I get to paint my interior with something that isnt going to come off the first type it gets scraped.
post #10782 of 13514 Old 07-13-2013, 04:25 PM
roughknight69
Ah I see, you can check out my build thread to see what it would look like.
Build thread
post #10783 of 13514 Old 07-15-2013, 01:12 PM
HDWrangler
Thanks Mike!
Anyone have an idea how long the ML should cure before applying masking tape over it???
post #10784 of 13514 Old 07-15-2013, 01:45 PM
mike_breaker_5
Originally Posted by HDWrangler View Post
Thanks Mike!
i would guess 6-8 hours. this may be a question best answered by eric however.
post #10785 of 13514 Old 07-16-2013, 08:34 PM
Hoovw
Question. The owner of my jeep before me repainted it and did a really bad job. The clear coat is flaking off everywhere and the paint in some areas is chipping down to bare metal and he clearly didn't use a flex additive on the plastics. Should do anything special or chip off as much as I can and then featheredge what won't come up or just sand and scuff everything like normal?
Hoovw is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
