Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 718 - JeepForum.com
 29Likes
post #10756 of 13469 Old 07-07-2013, 06:26 PM
eduardostewart
lowes was the only place i found it as well.
eduardostewart is offline
post #10757 of 13469 Old 07-07-2013, 07:44 PM
Therios
Home Depot had MEK replacement. Worked fine as previously stated. Regular MEK was not at our local lowes.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #10758 of 13469 Old 07-07-2013, 08:42 PM
lynskynbnd
1987 YJ Wrangler
Originally Posted by Hoovw View Post
.......Question though, I have been looking for MEK but everybody only has MEK substitute. Will it suffice?
I got MEK from CarQuest. About $25 for a gallon. You may have to ask them to talk to their paint specialist.
Originally Posted by bbradUSMC View Post
Great idea with the bolts. I will be using that trick. Only one thing, why did you scuff the CS? I thought you didn't have to if you sprayed before it cured.
Live Free,
Brad
I did not have time to ML within the 24 hour cure time of CS first coat. I did not scuff the second coat and sprayed the ML with in 12 hours. By the way, CS is a PAIN to scuff!!!
lynskynbnd is offline
post #10759 of 13469 Old 07-07-2013, 09:05 PM
Hoovw
Yea I checked Lowes, Ace, Walmart, local hardware store, all had substitute but not the real thing.
Hoovw is offline
post #10760 of 13469 Old 07-07-2013, 09:44 PM
DpDave
Hiya magnetman, without reviewing the previous 10,759 posts in this thread, I will just apologize in advance if this is a repetitive question.
I am getting ready to Monstaline my Jeep body tub, but it has an old, very worn bed liner material already in it. The existing coating is very beat up, and worn off in some spots. If needed I can provide a couple of pictures later this week when I get home. My question is whether or not I can just clean this existing mess up, MEK it and roll the Monstaliner on, or do I have to take it all back to metal and start from scratch?
I appreciate your help with this.
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
DpDave is offline
post #10761 of 13469 Old 07-07-2013, 10:16 PM
rodgers3
in all honesty i would take it back to metal so you don't have the ml start pealing because of poor adheason of the old liner
rodgers3 is offline
post #10762 of 13469 Old 07-08-2013, 01:01 AM
bbradUSMC
Ah I see, well I will be sure to lay it down within that timeframe then. I hate sanding!
Live Free,
Brad
bbradUSMC is offline
post #10763 of 13469 Old 07-08-2013, 04:56 AM
jeep63
jeep63's Avatar
I used acetone and have not had any problems.
jeep63 is offline
post #10764 of 13469 Old 07-08-2013, 10:04 AM
WranglerBuddy
Hey Magnetman or anyone else that would know. I recently bought a frame for my YJ for a frame swap and I would just like to know how much chassis saver I would need to do the outside? Also the frame isn't new it has a bit of surface rust here and there but overall it's in great shape to be a 93 frame. But do I need to scuff the areas where the paint is still nice and semi gloss? Thanks.
WranglerBuddy is offline
post #10765 of 13469 Old 07-08-2013, 12:55 PM
DpDave
Thanks Rodgers3, not the answer I wanted, but kind of the one I expected... :
My Build Thread:
DpDave is offline
post #10766 of 13469 Old 07-09-2013, 03:49 AM
boogernfo
I am getting ready to order a kit to line the tub of my '04 TJ, and am debating spraying vs rolling. I would like to compare any differences in surface finish, does anyone have some close-up pics of both finishes? Also, if spraying, how far will the product drift? I'm thinking in terms of protecting other equipment / vehicles when I actually do the deed.
Thanks in advance!
boogernfo is offline
post #10767 of 13469 Old 07-09-2013, 06:49 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Thanks in advance!
Sprayed will vary more than this.
Overspray is slight but not like regular paint spraying where you have a mist that will drift. I would still cover the surrounding areas w/plastic
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10768 of 13469 Old 07-09-2013, 11:13 AM
TXST8tj
TXST8tj's Avatar
delete
Patrick
TXST8tj is offline
post #10769 of 13469 Old 07-09-2013, 04:19 PM
boogernfo
Thanks for the photos! I think I'll roll it, I like the finish better. From the website, a 1 gallon kit will be enough, correct?
post #10770 of 13469 Old 07-10-2013, 11:06 AM
TXST8tj
TXST8tj's Avatar
order placed! thanks for the promo! ordered enough for two TJs and a golf cart. This should be fun.
Patrick
TXST8tj is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
