Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 717 - JeepForum.com
 19Likes
post #10741 of 13307 Old 07-05-2013, 12:07 PM
TXST8tj
TXST8tj's Avatar
Originally Posted by magnetman View Post
Is the body original fiberglass?
Any paint on it?
What condition is it in? Post pic here if you like
1 gallon does 60 sq ft so I would do some quick measurements to see what you have
It is a standard Ez-Go cart. Original fiberglass body. No paint.
Patrick
TXST8tj is offline
post #10742 of 13307 Old 07-05-2013, 07:24 PM
Therios
First coat. Love the color! The coverage on the first coat is questionable as far as I am concerned but I know it will be fine second coat. By the way, whoever recommended ear plugs to plug the screw holes has never worked with me! I ended up with a dozen big old flipping warts attached loosely to my roller, brush, fingers and driveway. All I had to do was look at them and the came out.
But got the first coat done anyway!
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #10743 of 13307 Old 07-05-2013, 07:36 PM
eduardostewart
im curious for when i get time to do mine. as opposed to ear plugs, how about a variety pack of corks from a craft store?
eduardostewart is offline
post #10744 of 13307 Old 07-05-2013, 08:38 PM
Therios
I am thinking that I shoulda spent ten bucks or whatever for cheapo bolts to sacrifice from the hardware store. Just paint them and back them out 1/4 inch or so and the do second coat. Pull them all the way. I do have many of the larger bolt holes that worked. They are the large torx like for the set belts and such. Those stayed in fine.
I do find it humorous that I could not work tith these ear plugs. I have used near half dozen pair a day for the last 10 years at work. I know how they work and how to use them. Maybe I was just out of it or something. I guess I will be chasing threads soon if I even wanna put my rear seat back in....
What I learned:
1) tape off everything you don't want monstaliner on. No kidding. Take the time. Do it well.
2) work in small batches like the instructions say
3) plan your route. This is especially important with help. I dragged my beard through the edges. I have it on arms and legs. Just work methodically. Better to follow person with brush with your roller.
4) leave it alone when it begins to set. I found that it was easy to overwork it.
5) if you dribble or run, fix it immediately.
6) if you don't want it there remove the extra immediately and then wipe clean with MEK ASAP.
7) wear gloves. I don't and my hands are orange and bothered by the MEK
More final pictures in a couple of hours.
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10745 of 13307 Old 07-05-2013, 08:45 PM
Therios
What I learned:
Better picture that is not through the kitchen screen!
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10746 of 13307 Old 07-05-2013, 09:06 PM
Therios
The bars will get black monstaliner when I can finally get some. Any recommendations on doing the round bars and getting then even?
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10747 of 13307 Old 07-06-2013, 06:44 AM
jeep63
YJ Collector
jeep63's Avatar
Are you planning to coat the entire rollbar?
I just did mine where they are not covered by the rollbar pad. Simply measured up and put a tape line. The liner never dripped or ran when I applied it to the rollbar.
I also found it easier to take them out; both for the tub lining and the rollbar lining. Too late for this though!
Looks good!
jeep63 is offline
post #10748 of 13307 Old 07-06-2013, 11:16 AM
Hoovw
Is the promo still good?
Hoovw is offline
post #10749 of 13307 Old 07-06-2013, 12:04 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Yes ignore the dates
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10750 of 13307 Old 07-06-2013, 12:15 PM
TXST8tj
TXST8tj's Avatar
I guess what my questioning comes from is what is the prep required to spray this on fiberglass? I know I won't need a full gallon to cover it, but I can use it for another project.
I just need to know what other products to buy/use to prep the fiberglass for the liner. What is the prep work required?
Patrick
TXST8tj is offline
post #10751 of 13307 Old 07-07-2013, 12:51 AM
Hoovw
Perfect! Will be ordering soon once I get my color chips
Question though, I have been looking for MEK but everybody only has MEK substitute. Will it suffice?
Hoovw is offline
post #10752 of 13307 Old 07-07-2013, 10:23 AM
lynskynbnd
1987 YJ Wrangler
I used bolts. I brushed the CS and sprayed the ML. Rolling the ML could be a pain with the bolts in the way. I removed the bolts to scuff each time.
prepping the bolts with tape. the tape sealed the top of the threads stopping and paint from seeping in.
bolts installed. Scuffed and ready for CS
Shiny CS
Scuffed CS
Monstaliner sprayed on
All the bolts are still usable. I used some to bolt the seats down.
More details here: http://www.jeepforum.com/forum/f59/m...l#post15393479
lynskynbnd is offline
post #10753 of 13307 Old 07-07-2013, 02:04 PM
bbradUSMC
Shiny CS
Scuffed CS
Great idea with the bolts. I will be using that trick. Only one thing, why did you scuff the CS? I thought you didn't have to if you sprayed before it cured.
Live Free,
Brad
bbradUSMC is offline
post #10754 of 13307 Old 07-07-2013, 02:46 PM
Therios
Yes. I had that question and was already answered in a previous post. I just finished mine and worked perfectly.
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10755 of 13307 Old 07-07-2013, 07:15 PM
Cuder
Have ya looked at Lowes for MEK?
My Build Thread:
Cuder is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
Supertrunk
You may not post new threads
