Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 708 - JeepForum.com
 29Likes
post #10606 of 13469 Old 06-12-2013, 07:10 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Ok... I would like to request some assistance for a genuine cause.
Tyler (ratmonkey) Hodson past away on Memorial Day and his presence on JeepForum will be sorely missed.
Tyler was a great forum mod, an awesome jeeper, a walking encyclopedia of jeep know how, but most important... Tyler was
the best friend since kindergarten of Mike (mike_breaker_5) Dixon who was the first jeeper on earth to ever have a complete
exterior Monstaliner job.
We are asking for small donations.. $2, $5, $10, $20 which will go directly to Tylers mom to help settle his estate.
Please help if you can!
R.I.P. Tyler Hodson
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10607 of 13469 Old 06-13-2013, 11:55 AM
Bludgeon
Very sorry to hear of the loss.
I have a somewhat boring question regarding Monstaliner as an exterior paint product. What is the best way to wash it? Just a power washer and hand soaping or are automatic car washes fine as well? Also, is there any product recommended to be used on top such as wax or anything?
I realize these are probably covered elsewhere but a search proved fruitless and I'm genuinely interested in doing my entire XJ soon. Thanks in advance.
Bludgeon is offline
post #10608 of 13469 Old 06-13-2013, 01:36 PM
mike_breaker_5
i have taken mine through car washes and power washed it all the same. i have yet to have any problems with it after 2 years.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #10609 of 13469 Old 06-15-2013, 08:31 PM
BEETROOT
Hey magnetman,
Can I/should I apply Monstaliner over bare metal? I stripped all of the paint from my tub.
I have a gallon of chassis saver with no plans for it...would it be better to put down the chassis saver first and then the Monstaliner?
BEETROOT is offline
post #10610 of 13469 Old 06-15-2013, 08:32 PM
rodgers3
monsta doesn't like bare metal.
rodgers3 is offline
post #10611 of 13469 Old 06-15-2013, 08:37 PM
BEETROOT
Is that true? I read the FAQ and the install instructions and didn't see any mention of bare metal.
Previous owner of my Jeep covered the entire interior with rattle can spray bedliner. I've spent 15+ hours with paint stripper and wire wheel getting this **** out...
BEETROOT is offline
post #10612 of 13469 Old 06-15-2013, 08:41 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by BEETROOT View Post
Hey magnetman,
Why did you remove all the paint and how rough is the metal in the tub now?
Connect with us on:
post #10613 of 13469 Old 06-15-2013, 08:47 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Which chassis saver finish do you have?
Connect with us on:
post #10614 of 13469 Old 06-15-2013, 09:08 PM
BEETROOT
I stripped the whole thing in order to remove the spray can bedliner the previous owner put in it. It was uneven and rough and looked like garbage.
I'm at smooth bare metal right now.
BEETROOT is offline
post #10615 of 13469 Old 06-15-2013, 09:09 PM
BEETROOT
Gloss black.
BEETROOT is offline
post #10616 of 13469 Old 06-15-2013, 09:24 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
At this point you have two choices
Coarse scuff the bare metal with 50 grit and put CS as primer or get a regular metal primer to put on smooth surface
CS will not stick to smooth steel and ML can not go on bare steel
Connect with us on:
post #10617 of 13469 Old 06-16-2013, 02:07 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
There's some kind of glitch in my account which may have caused this thread to disappear last night. I've brought it to the attention of some moderators
Connect with us on:
post #10618 of 13469 Old 06-16-2013, 04:58 PM
Copperhead89
Glad to see its back!!
Dave
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #10619 of 13469 Old 06-16-2013, 08:10 PM
BEETROOT
I went this route.
Should I MEK in between the CS and the ML?
BEETROOT is offline
post #10620 of 13469 Old 06-16-2013, 10:15 PM
Copperhead89
I went this route.
Magnetman is the best person to answer this, but I'll go out on a limb and say that you should ML over the CS within a certain window of time (read the CS directions about the re-coat window). MEK is used for removing dirt and oil/grease from the surface, and obviously there shouldn't be any of that stuff on a fresh coat of CS.
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
JeepCalledNomad
You may not post new threads
