Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 706 - JeepForum.com
 25Likes
post #10576 of 13378 Old 06-10-2013, 11:03 AM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
Originally Posted by DNFJ View Post
Not sure who this is directed to.
It was directed at you.
I threw Eric in there because I saw his blue name as I scrolled down.
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #10577 of 13378 Old 06-10-2013, 11:11 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
It's good to be back
And we just past 700,000 views
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10578 of 13378 Old 06-10-2013, 11:11 AM
CrawlingForward
Originally Posted by magnetman View Post
Med sand sponges work also
The ones that come in the kit are big enough to just cut into smaller pieces. We had 4 guys helping out and I didn't need to buy any extra.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #10579 of 13378 Old 06-10-2013, 11:15 AM
CrawlingForward
On another note:
I'm rebuilding an old Heald Hauler UTV as a mini-version of our Islander and was debating Monstalining the bed and footwell.
How much would I need for that small of an area? A gallon seems excessive, but the quarts wouldn't be enough, would they?
post #10580 of 13378 Old 06-10-2013, 11:17 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Originally Posted by CrawlingForward View Post
On another note:
Do you know the dimensions? I think 2 quarts would probably do it.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #10581 of 13378 Old 06-10-2013, 11:23 AM
CrawlingForward
Not exact, but approximately 4'x4'x1' bed with a 4'x1' footwell....ish.
post #10582 of 13378 Old 06-10-2013, 11:35 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You have 32 sq ft in the bed, that 1/2 gal (2 qts)
Connect with us on:
post #10583 of 13378 Old 06-10-2013, 11:37 AM
CrawlingForward
Awesome, thanks!
post #10584 of 13378 Old 06-10-2013, 06:38 PM
ayycharlay92
I already posted a thread about this, but I just found this one.
I'm currently in the market to purchase monstaliner to do the entire exterior of my WJ, I have concluded it should take 3 gallons to make 2 nice coats, but I was wondering if I need to prime it first or if I can just sand down my paint. Also is it more recommended to use the spray gun or the roll on brushes that you can get with the kit ?
ayycharlay92 is offline
post #10585 of 13378 Old 06-10-2013, 06:47 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
2 gallons should be plenty to do the exterior of your wj. Priming will always make a finish better, but as long as you don't sand down to bare metal, priming isn't necessary with monstaliner. As far as gun or spray that is a personal choice however you will have to thin it with mek slightly to spray it. Either way it will be textured.
If you primer it, I'm sure Eric can get you a deal on 2k epoxy primer.
Previous:
DNFJ is offline
post #10586 of 13378 Old 06-10-2013, 08:40 PM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Most people do not prime when the current finish is in good condition. Just good scuff and solvent cleaning is needed. What color is your rig now and what color are you thinking of doing?
Connect with us on:
post #10587 of 13378 Old 06-11-2013, 06:42 AM
ayycharlay92
The current color is like the tannish / gold, I replaced both my passenger doors and they are a deep blue, I was planning on doing it in either jeep spice or desert sand, thinking more along desert sand, it matches my interior a lot more.
post #10588 of 13378 Old 06-11-2013, 06:43 AM
ayycharlay92
What is Mek? Will it look the actual look of it be the same ? Like is it easier to get a more evn layer with the spray gun, or will the brushes leave like a "roll on look"
post #10589 of 13378 Old 06-11-2013, 07:22 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
If you have 2 diff colors of paint now you should consider priming first to make everything even
MEK is the solvent used to clean surfaces after scuffing and also to reduce for spray. Rolling can be done to look very uniform if you take your time.
These are rolled
Connect with us on:
post #10590 of 13378 Old 06-11-2013, 07:38 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Also Eric now that I have my nice camera I'll take some shots for you to use once we get a nice day out here.
Depends on your skill, rolling is easy and as long as you are patient about it you will have a great looking finish. The inverse of that is, even if you are good at spraying, if you hurry or don't put the time in to prep, it won't look as good. Either way you are going to end up with a texture, that is the nature of ML.
MEK or MEK Substitute is sold at most lowes or home depots.
Previous:
DNFJ is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
