Introducing MONSTALINERô UV Permanent DIY Roll On Bed Liner - Page 700 - JeepForum.com
 29Likes
post #10486 of 13469 Old 05-31-2013, 04:55 AM
DarthLEGO
Love the stuff and thanks for the awesome promo codes! Just order my 2 gallon kit and accessories this morning.
And thank you for the tips on the heat issues. We are always above 85 now here in Florida, so I know it is going to be an issue. "Luckily" we have 80+% humidity almost all the time now, so I know I will have a quick turnaround time between coats. =)
DarthLEGO is offline
post #10487 of 13469 Old 05-31-2013, 07:56 AM
eduardostewart
looking into getting some MEK, only to find out the clean-strip brand has discontinued it?
http://www.wmbarr.com/product.aspx?catid=85&prodid=103
eduardostewart is offline
post #10488 of 13469 Old 05-31-2013, 08:14 AM
Therios
That is what I found out as well. Home Depot only carries the MEK substitute. Will that work?
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #10489 of 13469 Old 05-31-2013, 08:31 AM
eduardostewart
looks like lowes has mek of a different company - crown - never heard of them.
gonna go up after work and read the fine print. if someones taking it off the shelves, thats the good stuff, and i want it.
post #10490 of 13469 Old 05-31-2013, 08:35 AM
Therios
Wonder if a paint company will have some. Time to look a little harder. Sure was easy when the big box home improvement stores had it. Local lowes did not have real MEK here yesterday. If I can find a reliable supply, I will post.
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #10491 of 13469 Old 05-31-2013, 08:37 AM
eduardostewart
did you see the crown stuff? is that another "substitute"
http://www.lowes.com/pd_206493-34228...ductId=3024048
post #10492 of 13469 Old 05-31-2013, 08:40 AM
jrp78
Yes, that's what I used and I verified with MagnetMan. It's completely fine to use.
jrp78 is offline
post #10493 of 13469 Old 05-31-2013, 09:06 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
MEK substitute is fine or Acetone also but be careful with acetone as it's very flammable
Any company brand of these things is fine
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #10494 of 13469 Old 05-31-2013, 10:07 AM
bedwards24676
I used the crown from lowes 1 gallon like $20. Works good its the real stuff. Hope this helps
bedwards24676 is offline
post #10495 of 13469 Old 05-31-2013, 10:48 AM
eduardostewart
yes thank you!
post #10496 of 13469 Old 06-01-2013, 12:57 PM
jrp78
Here are my results with Monstaliner. I did my Kubota RTV bed and the foot wells. I also did the tailgate on my truck but no pics of that yet. The foot wells have a much more textured surface because I went back over them. I left the bed semi smooth.
jrp78 is offline
post #10497 of 13469 Old 06-02-2013, 09:07 AM
CaveyDM
I am looking at doing a Hardtop, Door Latches, Tub and Rocker Panels in Dessert Sand on my 2006 LJ Rubi. The jeep is Metallic Khaki and I am looking at eliminating a lot of the black on the jeep to cut down on heat as well as common UV/Weather wear areas. Has anyone done their hardtop or door latches before?
Best Regards,
Dale
2006 2DR LJ RUBICON UNLIMITED / Old Man Emu (OME) 2.5" HD Lift / ARB Quadratec Edition Front Stubby / LOD Signature Series Rear Bumper & T/C
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
CaveyDM is offline
post #10498 of 13469 Old 06-02-2013, 11:40 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Spice hardtop
Black
Connect with us on:
post #10499 of 13469 Old 06-02-2013, 11:43 AM Thread Starter
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Here's a 3 color job, ODG, PYRO with DSND top
Connect with us on:
post #10500 of 13469 Old 06-03-2013, 08:56 AM
pods8
Originally Posted by Bryan-B View Post
I'm at about 4500 feet for elevation here in WY, air is pretty dry here, anybody have experience with it in similar conditions?
Yup, I've over 5k' here. I coated the top half of my project a month ago, as MM noted its the temp that factors in the most in recoat/tack free times. I didn't even any issue with final cure and low humidity.
I've got some more work to do till the bottom half is ready but I'll be looking for a cool day on the horizon (or start the job really early in the day) now that the hotter weather is coming around.
pods8 is offline
bed liner , Bedliner , diy , herc , herculiner , liner , monstaliner , POR 15 , protection , raptor , rust , upol , vendor
You may not post new threads
